How do I pull stats off my Canon EOS Rebel T6?
gedansky Forum Member • Posts: 51
I’m trying to determine which prime lenses I would get the most use out of.  Several users suggested I pull stats off my camera to determine what focal lengths I use the most.
Can anyone directly on how to do that?
Is there a better way to get that information?
Thanks!
Canon EOS Rebel T6 (EOS 1300D)
thebustos Veteran Member • Posts: 3,373
Re: How do I pull stats off my Canon EOS Rebel T6?
They probably mean to check the pictures you've taken.  Depending on your photo viewer you might have the option to load a folder of photos and sort them by focal length to get a count. But I don't think there is a way to pull that straight off the camera as it's in the individual photos exif data.
Good luck and happy shooting!
 thebustos's gear list:thebustos's gear list
Sony SLT-A77 Sony DT 35mm F1.8 SAM Sony DT 50mm F1.8 SAM Sony DT 30mm F2.8 Macro SAM Sony DT 16-50mm F2.8 SSM +17 more
Mark Scott Abeln
Mark Scott Abeln Forum Pro • Posts: 13,959
Exif viewers
That information is stored in metadata written by the camera within the image files. Lightroom can catalog this metadata and you can pull up a list of all the focal lengths used, along with the count of the number of images for each length. Exif viewers can pull up that data for individual images, along with a large number of other values, such as shutter speed, white balance, ISO, etc.
This article lists a number of Exif viewers:
http://carlcheo.com/best-exif-viewers
 Mark Scott Abeln's gear list:Mark Scott Abeln's gear list
Nikon D200 Nikon D7000 Nikon D750 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF Nikkor 50mm f/1.8D +2 more
khunpapa
khunpapa Senior Member • Posts: 2,638
google "exif statistics tool", download software, read manual, use s/w.
That's all.
Flashes of my Memory.
 khunpapa's gear list:khunpapa's gear list
Sigma DP2 Sigma DP3 Merrill Olympus E-M1 Panasonic Lumix G X Vario 35-100mm F2.8 OIS Sigma DP1 +10 more
Bill Ferris
Bill Ferris Veteran Member • Posts: 4,374
Thanks!
Do you use Lightroom? If so, it's fairly straightforward to sort photos by focal length used in the Library module. You may be able to do this in Adobe Bridge, as well. I rarely use Bridge so, can't say from experience.
There are several good free EXIF reading & display apps. I use ExifTool. However, it generates EXIF displays for individual photos; not statistics for a batch of photos. (It's a pretty basic app so, you could potentially edit the command line to do a batch sorting based on focal length. But that's above my pay grade.)
A Google search for a free EXIF reader that does batch sorting may be your best pathway to an answer.
Bill Ferris Photography
Flagstaff, AZ
http://www.billferris.photoshelter.com
 Bill Ferris's gear list:Bill Ferris's gear list
Nikon D610 Fujifilm X-T20 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Tamron SP 24-70mm F2.8 Di VC USD +3 more
