Help with broken 16-50 f2-2.8
Started Aug 18, 2019 | Discussions
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
Hello, it's been a while. I'm still using 100% my nx system.
Unfortunately today my camera dropped and the lens broke. Unfortunately it was the 16-50 premium lens.
Actually the damage is not that bad. The only broken thing is the flat cable internally connecting the camera to the lens.
Does anybody know the part number for the back part of the lens, I mean the plastic ring with the cable departing from it?
Thanks in advance.
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
markyboy81 Veteran Member • Posts: 3,976
Re: Help with broken 16-50 f2-2.8
Sorry, I can't help but you have my deepest sympathies and I hope you can get it fixed. How did it get dropped?
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +10 more
tecnoworld
OP tecnoworld Veteran Member • Posts: 7,232
From my bag, which wasn't closed 😭 my fault, 100%
TuVuVu
TuVuVu Regular Member • Posts: 342
I search all over the internet for a "Service Manual, "Parts Manual", etc.
I'm 100% sure you did the same and all that came up is, "User Manual".
The ONLY suggestion I can think of (now); shop used, condition ugly, replace your broken part using ugly's.
Very Best Regards,
Tu Vu
"The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." -Albert Einstein
 TuVuVu's gear list:TuVuVu's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samyang 85mm F1.4 Aspherical IF +18 more
tecnoworld
Yes, I searched already with no luck, but I'm almost sure that they sell parts, also.
I remember that there was a similar thread where a guy asked for a zoom ring or something.
I need to find out the part number (code) so to look for it...
otto k Senior Member • Posts: 2,194
If it's just a generic flat cable (not meant to move, etc, in lens) maybe a good electronic repair shop could help you? It's not like there's magic in it, just simple wires.
Canon EOS 600D Samsung NX1000 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 20-50mm F3.5-5.6 ED +6 more
tecnoworld
Sure, but I'm pretty dumb about diy work...
For this reason, I was looking for the rear inner ring of the lens with the cable attached to it...
thatfour Junior Member • Posts: 36
I did drop the lens with nx500 on solid dirt ground with the lens good and thankfully it is still fine
tecnoworld
You've been lucky, my lens opened and the flat cable was broken
Actually I have dropped it many times and the thread kind of not circular like usual but still manage to be usable I think
tecnoworld
My issue is that it opened up and the flat connector broke in the final part (see image)
That really hurts. Some may suggest you seek online at samsungparts and do the repair yourself. Seek official Samsung see if they willing to help.I did and they kind of respond you to send back the cam. (Nx500 crazy mode dial). But I ignored it
This and the 85mm really are my most precious lenses still hope they will last long... somehow regret for leaving the 85 home so often in dry cabinet when traveling...
Best of luck to you
It's quite possible that Samsung reused the same cable for different lenses. You might be able to salvage it from some other broken cheaper lens. You could check with lenses you already have.
TuVuVu
No need for diy if good electronic repair shop could help you and you cannot locate part number for the rear inner ring.
tecnoworld
Interesting suggestion. The tricky part is finding an electronic shop nearby, able to fix the cable.
tecnoworld
Exactly what I thought, also because the small flat cable with contacts is simply wired to the ring. Hence that specific part should be the same for all the lenses IF the flat cable has the same length. The bad thing is to select a lens to 'sacrifice'. The 20-50 is perhaps the best candidate....
tecnoworld
Can it be this?
ASSY FPCB-CONTACT
tecnoworld
It should be just the part with contacts and cable, pcb is fine...but it could do if price is not too much
It depends on the way the cable is connected to the board. If it's soldered then you have to buy it together. Samsungparts lists it for under 10 euros IIRC, this site does not anymore and it was 30, but check again.
