Panasonic Lumix G Vario 100-300mm f/4-5.6 OIS II REVIEW
Started Aug 17, 2019 | User reviews
mtnroads Regular Member • Posts: 292
Re: Panasonic Lumix G Vario 100-300mm f/4-5.6 OIS II REVIEW
FANTASTIC! I loved the last video, the road trip - the editing and music is perfect!
Really great man. I know it's an old thread but I never saw it (recent member) and I'm so appreciative that Miranda replied and brought the thread back to life so I could see it.
Inspiring work, Toxic Tabasco, thanks!
 mtnroads's gear list:mtnroads's gear list
Fujifilm X-T2 Olympus E-M1 II Olympus E-M5 III Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +10 more
miljomupp New Member • Posts: 3
Toxic tabasco!
Great pictures and videos!
Your original post was from August 2019, a one year review of the Panasonic 100-300 ii. Now almost 18 months later and more experience...what more do you have to add. I am considering the 100-300 mostly from the angle that sometimes the Panasonic 45-150 does not have enough reach but I think I would not use the Panasonic 100-400 beyond 300 often to justify the price.
In other places I have read those who are a bit down on the 100-300 because it gets a bit soft after 270 or so. Then still others say no, never experienced that. If there are other users of the Panasonic Lumix 100-300 out there reading this: what are your experiences?
Thanks.
Jeeter001
Jeeter001 Contributing Member • Posts: 768
Great review for a great lens!  I like it due to the compact size, lightness, and ease/speed of the zoom.  It's great for events like daytime sports.
 Jeeter001's gear list:Jeeter001's gear list
Panasonic LX10 Panasonic FZ80/FZ82 Panasonic Lumix DC-ZS80 Olympus PEN E-PM2 Panasonic Lumix DMC-GM1 +50 more
Kingate Cavies New Member • Posts: 11
Just wanted to check, as thinking of getting this lens for my G80M, can you use the manual focus ring okay for peaking, as I use this quite a bit, and a few people have mentioned that the manual focus ring is a bit stiff?   Sue
 Kingate Cavies's gear list:Kingate Cavies's gear list
Panasonic Lumix DMC-LZ2
olrett Contributing Member • Posts: 683
I have no comparison with other copies of this lens, so I can only speak for mine.
I did have the impression that it was a bit stiff (nothing drastic at all, for instance there is no stop-and-go behaviour whatsoever) if compared with the soft focus rings on my other (smaller) lenses. Perhaps the plasticFantastic 40-150mm by Olympus is comparable.
However, I realized that if I repositioned the lens collar*, it was less stiff, actually quite nice. WIth the lens collar tightened I see no lens creep while it's hanging downward. WIth the lens collar loosened, if I shake it pointing downwards, it does give a bit. So no, I don't think it has a stiff focus ring.
* http://roesch-feinmechanik.de/29701.html
Edit: My apologies, I went on about the ZOOM ring. The FOCUS ring is indeed a bit on the stiffer side, but, again, it is consistently opposing the same resistance along the entire range, which I do not mind at all for close-ups.
 olrett's gear list:olrett's gear list
Panasonic Lumix DMC-LX3 Olympus TG-6 Panasonic Lumix DMC-GH1 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GM5 +24 more
Bobby J Veteran Member • Posts: 5,191
Very well done.  Thank you for sharing.
BJM
 Bobby J's gear list:Bobby J's gear list
Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G 25mm F1.7 ASPH Olympus 12-100mm F4.0 Olympus E-M1 Olympus E-M1 II +9 more
rico7578 Regular Member • Posts: 124
"4) Image quality is on par with high end super telephotos for most of its range."
-> I disagree with that point.
The Panasonic 100-300mm II lens is the only m43 lens that I sold due to a lack of sharpness... Mine was pretty poor quality from 250mm...
I since acquired a Panasonic 200mm F2.8 (for 900 euros only, brand new, with Pana promotions), which is much better of course.
Have you looked at the date of this thread? It's pretty old.
dabhand
dabhand Regular Member • Posts: 132
I appreciate it's an old thread AND therre are Covid travel restrictions, but there is another Advantage that is worth mentioning - size and weight when travelling on aircraft - my 100-400 is always with me when I'm driving within the UK, foreign travel, it's always the 100-300.
You have cameras, lenses and a desire to take pictures. A pro shoots with his kit and worries about clients, prosumers worry about their lenses - everyone else worries about everything.
 dabhand's gear list:dabhand's gear list
Panasonic Lumix DMC-GX8 Pentax K-1 Pentax K-70 Panasonic G85 Pentax KP +10 more
I understand. I thought I'd sell the 100-300 after getting the 100-400. But no. Although it's not that much lighter than the 100-400 with the Roesch custom collar and a heavy fast-release metal plate attached to that.
IkosPix New Member • Posts: 2
Thanks much for your detailed review. Looks like the right lens for me.
vjephoto New Member • Posts: 5
spike29 wrote:
Astrotripper wrote:
spike29 wrote:
I am very happy with this lens. Point 3 15% tighter at 100mm as the other at 100mm?
Strange. I would think that 100mm is 100mm on any lens. gues iam naive 😀
The focal lengths on the barrel almost never match the actual focal length of the optics. And then there is focus breathing which OP mentioned. Different lenses breath differently, but unless it's a specialist cine lens, there will be some of it. That means that focal length of the lens changes as the focus changes.
I had to interweb it but it's sounds logic, turning lensring shifting elements for focus the focalpoint shifts abit and therefor the viewangle.
What i thought was a 12-100mm at hunderd locked would be have the same field of view as a 100-300mm at hunderd locked.
The digital "number" of "150mm" writed in the exif of the 100-300mm is i think a measurement and not a fysical fixed gearset, calibrated but with some tolerance.
I was recently comparing my 100-300 II with a film era Pentacon 4/300 (with and without a speedbooster). At "infinity", field of view from both was the same. but as soon as I tested by photographing a subject just 3 meters from the camera, the difference in field of view was immediately visible. Basically, with subject and camera in the same place, I had to set the 100-300 II to around 260mm to match the 210mm of the Pentacon with a SpeedBooster. With simple adapter and comparing both at 300mm, I had to move the Panasonic almost 1 meter closer to the subject to get the same framing.
I played around measuring this stuff a while back. For example, Olympus 30mm Macro is around 20mm at its closest focus distance.
Ok so a prime has 10mm angle diiference 1/3 of it's "sold prime focallenght"
Wow. 🙂
Wouldnt any 1:1 macro lens, at its closest focus (where it is expected to produce true 1:1 results), have the same angle of view as every other 1:1 macro lens?
Let me rephrase. Wouldn't a 100mm 1:1 macro and a 50mm 1:1 macro have the exact same angle of view at their respective closest focusing distances, when using same sensor between both? And wouldn’t that angle of view directly correspond to a focal length equal to the diagonal measurement of said sensor?
I may be mistaken. Please help me understand.
JosephScha Veteran Member • Posts: 7,249
If you take macro pictures of a perfectly flat surface, then I guess you could claim that you couldn't see the difference between a 50mm macro lens and a 100mm macro lens.
But most people shoot macros of insects, or flowers, or other three dimensional objects.  Since the distance between the front of the lens and the object will vary with focal length, the difference (especially in the background) should be discernable.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
plantdoc Veteran Member • Posts: 4,339
Unfortunately my copy has some focus problem and I have tried everything. Much worse from 250mm.  Can be sharp but not often enough. Off for a service check as something is off. My Olympus 75-300 is more reliable.
greg
You are right. I was thinking of a flat 2D surface. With insects, and even macro food images, focal length would definitely matter.
lecycliste
lecycliste Junior Member • Posts: 36
BIF?
Banded iron formation?
Best in frame?
Barfy internal focus?
Obscure acronyms don’t tell me anything.
Mark Bohrer
www.markbohrerphoto.com
 lecycliste's gear list:lecycliste's gear list
Panasonic Lumix DC-G9 Leica SL2 Canon EOS R5 Leica M10-R OM-1 +32 more
SterlingBjorndahl Senior Member • Posts: 2,642
lecycliste wrote:
BIF?
Best in frame?
You've been a member of DPReview since 2009 and you're only asking that question now? And you're asking someone who posted this way back in 2019? I suspect your account has been hacked.
Lens Grit
 SterlingBjorndahl's gear list:SterlingBjorndahl's gear list
Olympus Air Panasonic Lumix DMC-GX85 Panasonic Leica D Vario-Elmar 14-150mm F3.5-5.6 Asph Mega OIS Panasonic Lumix G X Vario PZ 14-42mm F3.5-5.6 ASPH OIS Panasonic Lumix DMC-FZ50 +18 more
kalisti
kalisti Senior Member • Posts: 1,181
lecycliste wrote:
BIF?
Best in frame?
XD obscure lololol
funny place to say that, interact on the forum, or maybe read it and you'll understand these strange terms we use, otherwise these strange terms arent for you anyway.
Or assume it mean bananas in front.
 kalisti's gear list:kalisti's gear list
Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G 14mm F2.5 II ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH +3 more
BIF: usually means "birds in flight"
but maybe banded iron formation or bananas in front could be good photo subjects!
js
Michael Houston Forum Member • Posts: 93
You mean BIF doesn't mean Bold Italic Font?
