Lightroom: Built-in Lens Profile Applied
Salah Regular Member • Posts: 345
Greetings,
I use Adobe Lightroom Classic CC and sometimes I notice that Lightroom shows "Built-in Lens Profile applied."
Sony A7R II + Zaiss Batis 18mm f/2.8 Lens
Should I check the Enable Profile Corrections and Remove Chromatic Aberration checkboxes?
 Salah's gear list:Salah's gear list
Sony a7R III Sony FE 35mm F1.4 Sony FE 70-200mm F2.8 GM OSS Zeiss Batis 18mm F2.8
Sony a7R II Zeiss Batis 18mm F2.8
Tom Axford Veteran Member • Posts: 6,427
Re: Lightroom: Built-in Lens Profile Applied
Salah wrote:
Greetings,
The built-in lens profile is applied by LR whatever you do.  The lens corrections panel only allows you to carry out further corrections if you wish.
Sailor Blue
Sailor Blue Forum Pro • Posts: 14,920
The panel is showing you that your camera has already applied a lens Profile Correction so LR is not doing it. You shouldn't check the Enable Profile Correction box.
It is also asking if you want to Remove Chromatic Aberration. It is easy enough to check for chromatic aberrations and apply if you find any. Look at edges for green/purple fringing, which is chromatic aberration. Here is some information about chromatic aberration and how to fix it.
Chromatic Aberration - What is Chromatic Aberration? (And How to Fix It in Photoshop or Lightroom)
Chromatic Aberration - Quick Tip: how to precisely detect and remove chromatic aberration in Lightroom - DIY Photography
Living and loving it in Pattaya, Thailand. Canon 5DS R & 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Canon EOS 5DS R Tamron SP AF 90mm F/2.8 Di Macro Tokina AT-X 16-28mm f/2.8 Pro FX +9 more
If you are using a raw image, then, strictly speaking, some cameras embed the lens profile in the raw file (along with the image data) and LR applies the lens profile itself in the first stage of processing the raw data.  That lens profile generally contains distortion and vignetting correction.  It sometimes also contains lateral chromatic aberration correction (to see if this is so, just click on the "i" in front of the text "Built-in lens profile applied").
OP Salah Regular Member • Posts: 345
When I clicked on the "I", I got the following message:
"This raw file contains a built-in lens profile for chromatic aberration. The profile has already been applied automatically to this image."
So should I assume the built-in profile doesn't fix the distortion and vignetting?
I do not know the answer to that.
Of course, if your image shows obvious distortion and vignetting, then it hasn't been fixed.
However, my guess is that most built-in lens profiles do fix distortion and vignetting and the software just doesn't bother to say so.
