Pentax K1 and FA 77/1.8 Limited Lens problem
Started Aug 15, 2019 | Discussions
babujr
babujr Forum Member • Posts: 89
I can autofocus with all of my Pentax AF lenses on the K1.
But the  77 Limited makes a slight noise when the shutter button is pressed, but does not focus. When I try manual focus, there seems to a three four points of slight resistance to to the focusing ring between, 0.8 ft and 5 ft.
The K1 has nothing to do with this problem, I should think, right?.
Does the lens need some kind of lubrication? Can it be repaired? Any suggestions, please. Could not find any earlier references.
babujr
 babujr's gear list:babujr's gear list
Sony RX100 VII Canon PowerShot Zoom
Pentax K-1
PeterPentax
PeterPentax Senior Member • Posts: 1,121
Re: Pentax K1 and FA 77/1.8 Limited Lens problem
I suggest you send it in. Something, probably a small screw has worked loose inside the lens.
babujr
OP babujr Forum Member • Posts: 89
Sorry, I found a specific thread from 2016, but I don't seem to be able to paste it here. Any other suggestions are welcome.
babujr
miles green
miles green Veteran Member • Posts: 7,827
yes, that souds right, i think you should send it in.
(PS: I'm assuming at least one of your other Pentax AF lenses is screw-drive AF, depending on the camera's AF motor)
Miles Green
Pentaxian since 1997!
Corfu, Greece
N.B. All my images are protected by Copyright
 miles green's gear list:miles green's gear list
Pentax K-1 Pentax K-1 II Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +7 more
babujr
Actually ,they are all screw drive.
babujr
miles green
So yes, there must be something loose in the 77
Great lens though.
Miles Green
Corfu, Greece
