Panasonic GH1 manual focus with legacy lenses
Started 2 months ago | Questions
xpatUSA
xpatUSA Forum Pro • Posts: 15,575
Have just ordered an M42 to m4/3 adapter (non-electronic). Obviously, there will be no manual focus-by-wire, duh! Less obviously, it seems that live view can not be magnified unless a "proper" focus-by-wire lens is used - i.e. legacy lens means no magnified view.
Is that correct or is there some procedure that I haven't discovered in the manual?
Ted
Sigma DP2 Sigma DP2 Merrill Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-G1 Sigma SD15 +17 more
Panasonic Lumix DMC-GH1
DidierDCH Contributing Member • Posts: 507
Re: Panasonic GH1 manual focus with legacy lenses
On my DMC-G1, when in MF, you can press the left arrow on the four-way controller then press the center button to activate live view magnification.
With an adapted lens, though, you may first need to activate « shoot without lens » (found in the Custom menu on the G1).
HTH - Didier
 DidierDCH's gear list:DidierDCH's gear list
Panasonic Lumix DMC-FZ200 Panasonic Lumix DC-ZS70 Panasonic Lumix DMC-G1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +1 more
xpatUSA
OP xpatUSA Forum Pro • Posts: 15,575
HTH - Didier
Thank you Didier!
When my adapter arrives, I'll give it a try ...
... I also have a G1 so I'll try that first, then the GH1.
Once again, thank you.
Ted
Caledonia Regular Member • Posts: 159
If those cameras have a "digital teleconverter" feature, it might be possible to assign that to a button, and toggle it on and off as needed -- that's a technique used by some of the wildlife shooters here.  If shooting raw, it might be best to test the feature to see if raw images are affected when it is on. Best guess, they aren't, but it's always worth a check.
xpatUSA
HTH - Didier
Got the adapter today and tried your method with a Pentax Takumar 24mm lens.
It worked very well, thanks again for the advice.
Ted
Glad to hear it worked. Have fun shooting!
Didier
