Cognisys Stackshot?
Started Aug 14, 2019 | Discussions
Ellis Vener
Ellis Vener Forum Pro • Posts: 13,943
Cognisys Stackshot?
I’m not sure if I need one or merely want one. I have a macro project coming up and I will be doing focus stacking. While my camera has focus shift capabilities.
the project will be in the 1:2 to 4:1 magnification range.
Ellis Vener
To see my work please visit http://www.ellisvener.com
Or on instagram @therealellisv
 Ellis Vener's gear list:Ellis Vener's gear list
Sony RX100 VII Nikon D850 Nikon Z7 Nikon Z6 +1 more
Azimuth Jones
Azimuth Jones Regular Member • Posts: 323
Re: Cognisys Stackshot?
No experience, sorry, but I thought I'd point out that LensRentals has it for a week for $83. And I recently got an email from them offering 20%-off through the 23rd, with coupon-code UGET20
Ellis Vener
OP Ellis Vener Forum Pro • Posts: 13,943
Thank you Mr. Jones
Much appreciated. I received that coupon as well. I did not know LensRentals.com stocked it.
Ellis Vener
Bill Janes Senior Member • Posts: 1,941
Ellis.
Take a look at Rik Littlefield's post on focusing by ring or rail. For magnifications of less than 1:1 an auto-focusing macro lens with "focus shift" is my preferred method, although determining the number of shots and step size with my Nikon D850 takes some experimentation.
For magnification greater than 1:1 many methods require manual focus and the StackShot is very useful and simple to use in this situation. One can set the near and far focus points, specify the number of shots, and start shooting. Alternatively, one can set the start distance, step size and number of shots. The Zerene site has good depth of field tables that help in determining the step size. Extreme Macro has some good info on high magnification photography.
Bill Janes
Ellis Vener
Ellis.
Thank you Bill!
i want to avoid the out of focus blurred edge when photographing at an oblique angle and the background is textured.
i am working with a Z7 and a D850 so I already am familiar with focus stepping. I am using Helicon Focus stacking software.
Ellis Vener
mawyatt2002
mawyatt2002 Contributing Member • Posts: 502
Ellis Vener wrote:
Ellis.
Thank you Bill!
Ellis,
With the excellent info Bill pointed to if you decide on focus stacking by camera/lens movement the Stackshot is a great focus rail, WeMacro has a lower cost rail. I have both, the Stackshot is the most versatile of the two, the Wemacro is very capable and a great value. If you use Zerene as focus stacking software, this has a built-in interface with Stackshot which is the best available IMO.
I've used the D500, D800, D800E, D850 and soon the Z7 on both rails, make sure you get the proper camera trigger cable interface.
Eventually I moved to custom rails, and now developed custom controllers which go beyond the capabilities of commercial available stacking systems. These support automated Stack and Stitch work at high magnifications (mostly do silicon chip images). You can see some of the developments here.
https://www.dpreview.com/forums/thread/4342999
BTW you won't be able to use flash or strobes with the D850 or Z7 under fully electronic shutter modes, the Hot Shoe is blocked during these modes. A work around has been developed with the custom controllers mentioned above.
Best,
Research is like a treasure hunt, you don't know where to look or what you'll find!
~Mike
Ellis Vener
Thank you for all of this.
Ellis Vener
John K Veteran Member • Posts: 8,662
What are you photographing, what's the primary light source, and what macro lens/setup do you have to get to 4:1?
Asking cause I shoot single frames up to 5x.
Also known as Dalantech
My Book: http://nocroppingzone.blogspot.com/2010/01/extreme-macro-art-of-patience.html
My Blog: http://www.extrememacro.com
My gallery: http://www.johnkimbler.com
Macro Tutorials: http://dalantech.deviantart.com/gallery/4122501/Tutorials
Always minimal post processing and no cropping -unless you count the viewfinder...
Ellis Vener
Nothing complex: just rocks.
Ellis Vener
mawyatt2002
I wouldn't characterize all rocks as "nothing complex", some rocks & minerals can be very challenging because of the complex surface reflections. There are a few folks over at the Photomacrography site Bill mentioned that have produced some stunningly beautiful images of rocks and minerals with Stackshot and WeMacro rails. I had no idea how beautiful these minerals and rocks can be, others have done some sections of small meteorites that are also quite stunning. I recall an image of a small mineral crystal with a tiny ~1mm sliver of gold meandering around in the crystal surfaces, absolutely beautiful natural subject!
Caution, stacking can become addictive because you can fill the entire field with crystal sharpness at pixel levels and not suffer defraction and soft corners with traditional techniques. Some specialized lenses, including microscope objectives, can be employed to go far beyond what conventional "macro" lens achieve at higher magnifications. Recently a surplus Minolta Film Scanner lens (5400) Robert O'Tool discovered and tested with excellent results, these quickly escalated in price once the "word" got out!! He also discovered a $18 4x microscope finite objective that is a jewel in the rough, think you can still get these for ~$20!
Along with the excellent sites Bill mentioned here is Robert O'Tools site.
https://www.closeuphotography.com
Best,
~Mike
ClosePhoto Regular Member • Posts: 137
Yes, things certainly get complicated when the subject requires significant lighting yet many surfaces are reflective.
FOV: 6mm
mawyatt2002
FOV: 6mm
Yes lighting these kind of subjects is a challenge indeed!!
I've had to deal with surface reflections with some silicon chips I've imaged that have small 40~100um solder balls all over the chip for attachment. These are like tiny spherical mirrors, and reflect from every direction. The initial lighting solution to create an absolutely uniform lighting was quadruple diffusion using dual light tents, one inside the other and double diffused strobes, used up to 11!! Now I still use the light tents, sometimes dual tents, up to 7 strobes and use a white styrofoam cup attached to the microscope objective lens for higher magnifications. This isn't ideal since the cup moves with the lens for stacking and thus changes the subject lighting, but the movement is only a couple mm. For lower magnifications the cup is attached to a fixture and the lens "pokes" thru the end of the cup. BTW these cups are some of the best diffusers I've found for studio work, they are cheap available in various sizes, but they do eat light so you need lots of optical power.
Here's a large crop (can't show entire chip image (~20mm by 18mm), it's proprietary) for a older chip oxidized solder ball, for reference the multiple small squares are ~2um I recall. The top is overexposed, note the dent on the ball top this is from wafer scale probing using test. Also note the slight jags in the middle left of the coil spiral, this is caused by slight sub-micron rail lateral movement rather than perfectly along the optical axis. The stacking software can't totally compensate for this because the slight movement across ~20mm creates a very slight perspective change since the custom lens assembly isn't perfectly telecentric (magnification doesn't vary with subject position nor distance).
Initial setup used for imaging chips with solder balls
Stackshot rail with custom lens assembly (Mitutoyo Objective)
Later setup
Best,
~Mike
Ellis Vener
FOV: 6mm
With respect, Lighting is a completely different subject from my query and I am not photographing geodes.
Ellis Vener
Ellis Vener wrote:
Ellis Vener
I was responding to mawyatt2002's comment about the challenge of rocks, not to the thread in general.
Typically at 4x magnification one isn't looking for the matrix of a rock, but to capture the interesting elements unseen to the eye, such as the dawsonite, calcite, fluorite and marcasite crystals in that little vug.
In your case, the answer is straightforward. If focus stacking with Helicon is an option with your gear it's preferable to using a rail. A manual focusing lens or microscope objective necessitates a rail. Provided your lens doesn't have severe focus breathing, the focus stepping method will produce slightly better results.
Have you decided how you're getting to 4x magnification? Doing so while maintaining autofocus (to allow for stepping), IQ, and a reasonable working distance is a mean feat given the number of possible combinations.
flyinglentris
flyinglentris Senior Member • Posts: 1,344
I compared pricing between the RRS Macro Rails and the Cognisys products some time ago and this difference can be as little as a couple hundred bucks depending upon which products you are comparing.
RRS at B&H:
https://www.bhphotovideo.com/c/search?Ntt=really%20right%20stuff%20macro%20rail&N=0&InitialSearch=yes&sts=ma&Top+Nav-Search=
Cognisys StackShot:
https://www.cognisys-inc.com/store/focus-stacking.html
As I don't yet have either product, it's an open decision where I'd go with this and I tend to prefer the StackShot option with its precise automated control.
"If you are among those who believe that it has all been done already and nothing new can be achieved, you've murdered your own artistry before ever letting it live. You abort it in its fetal state. There is much that has yet to be spoken in art and composition and it grows with the passage of time. Evolving technologies, world environments and ideologies all drive change in thoughts, passion and expression. There is no way that it can all ever be done already. And therein lies the venue for the creative artist, a venue that is as diverse as the universe is unmapped and unexplored." - Quote from FlyingLentris
flyinglentris in LLOMA
mawyatt2002
Another parameter to consider when doing higher magnifications is the lens working distance and the lens barrel diameter near the entrance, these can make a difficult lighting situation even more difficult.
Best,
~Mike
