Which is the sharpest? Battle of six lenses @50mm f/5.6
Started Aug 13, 2019 | Discussions
Massao Senior Member • Posts: 2,580
Mirror mirror on the wall, which is the sharpest of them all?
Comparison of following six zoom lenses @50mm f/5.6:
  • Tamron 28-200mm f/3.8-5.6 AF Aspherical LD (IF) 271D
  • SMC Pentax DA 50-200mm f/4-5.6
  • Sigma 50-500mm F4-6.3 APO DG (older version without OS and HSM)
  • Sigma 17-70mm f/2.8-4.5 DC Macro
  • Tamron AF 17-50mm f/2.8 LD Aspherical XR Di II SP A16
  • SMC Pentax DA 17-70mm SDM f/4 AL (IF)
Same camera on tripod; no filter on any lenses; hood on all lenses; out-of-camera jpegs.
Note1: focus is on pink flowers!
Note 2: I tried to block the light coming from top left side with my hand (in addition to lens hood).
Comparison of most of these lenses @35mm can be seen here .
Kind regards,
Massao
First camera: Canon FTB; First autofocus SLR camera: Pentax; First Nikon: F601 (N6006); First digital camera: Sony DSC-W5; First DSLR: Nikon D70; First mirrorless ICL camera: Samsung nx11
Roland Karlsson Forum Pro • Posts: 30,035
Re: Which is the sharpest? Battle of six lenses @50mm f/5.6
This is my first take at it
  1. Tamron 28-200 - oops, faulty?
  2. Sigma 50-500 - OK
  3. Pentax 17-70 - OK
  4. Pentax 50-200 - soft, but nearly OK
  5. Tamron 17-50 - very good
  6. Sigma 17-70 - very good (maybe with an edge)
I cannot decide between 5 and 6. Number 6 has higher contrast which makes it look sharper. So ... I give it a better point.
BTW - are you sure that the focus not is on the wall for the pictures?
/Roland
Kalpanika X3F tools:
https://github.com/kalpanika/x3f
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony RX100 III Pentax K-3 Pentax K-1 +14 more
And this is my take at corner sharpness (lower left corner).
  1. Very soft
  2. OK
  3. Slightly soft
  4. Slightly more soft
  5. OK
  6. OK
Much harder to tell
But 5 and 6 are clear overall winners and 2 seems to come after that.
NOTE - in this test, of course. There might be sample variations and the images might not be optimally focused etc.
/Roland
OP Massao Senior Member • Posts: 2,580
As sure as I can be I selected the af point my self, and my tripod is professional line from manfrotto. Its possible the camera is playing tricks with AF
  1. Very soft
  2. OK
  3. Slightly soft
  5. OK
  6. OK
Much harder to tell
Thanks 😊
I give the number 1 position to Sigma 17-70mm lens for four reasons:
  1. Slightly sharper
  2. Higher contrast and clarity.
  3. Best corner/edge sharpness.
  4. Tamron should had performed better at f/5.6 since its a f/2.8 lens—two full stops is all a good lens should ever need.
No.2 position is of course Tamron 17-50mm.
Whats interesting is that Sigma 50-500mm performs quite well despite a 10x zoom; its probably at number three place in this test. However, it is a disappointing lens at longer focal lengths—where its needed the most ☹
Indeed, but the results generally correspond to other test reports of these lenses.
Kind regards,
Massao
 Massao's gear list:Massao's gear list
Sony Alpha NEX-3 Pentax K-r Samsung NX300 Samsung NX1100 A3000 +40 more
This is an annoying thing with Bayer CFA cameras. In order to improve sharpness, the software uses tricks, like edge detection. But, soft flowers do not really have any nice edges.
This means that the wall, that has edges in the patterns, can actually be sharper, even if it is more out of focus.
I would really like a non Bayer CFA camera for that reason. Therefore I have been interested in the Sigma/Foveon cameras. And they can deliver a uniform sharpness. They have other problems though.
/Roland
I have thought about Sigma's system several times over the years, but its the lens and flash availability/selection that has killed that idea every time..lol
Kind regards,
Massao
