45 f1.8 vs 56 f1.4 vs 75 f1.8 for a twin lens do it all
Started Aug 12, 2019 | Polls
Po Sen Tsui Regular Member • Posts: 289
Let's say you are going on a trip with 1 camera body and just 2 prime lens, you don't know what you will encounter, you may be shooting portrait, or landscape, or street, or something else, etc. One of your lens is a wide angle 17mm f1.8, which one of the three (45mm f1.8, 56mm f1.4, 75mm f1.8) will you choose as a second lens to make this combo work the best? In terms of both quality and usability. Thanks!
 Po Sen Tsui's gear list:Po Sen Tsui's gear list
Olympus E-M1 II Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-100mm F4.0 Venus Laowa 7.5mm F2 MFT Olympus 100-400mm F5.0-6.3 IS
POLL
Olympus 45mm f1.8
50% 50  votes
Sigma 56mm f1.4
35% 35  votes
Olympus 75mm f1.8
15% 15  votes
  Show results
Bassaidai Contributing Member • Posts: 801
Re: 45 f1.8 vs 56 f1.4 vs 75 f1.8 for a twin lens do it all
-> 56mm/f1.4
Compared to the Oly 45mm its just a notch narrower and a little faster - > more separation, enough tele for many situations.
I find the 75mm for a two-lens setup too narrow, too much a step from 17mm.
Of course this comes down to your very personal style and preferences. 😊
Bass
If things appear to good to be true - they're usually neither of both.
 Bassaidai's gear list:Bassaidai's gear list
Panasonic GH5 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +8 more
Soulfulized
Soulfulized Regular Member • Posts: 103
Not quite the scenario outlined, but I recently attended a music festival where I needed to get my EM5ii to pass as a non-interchangeable lens camera. Did that via the 9mm bodycap lens, but that would have been useless for shooting the acts on stage, so smuggled one more lens in. That was the Sigma 56mm.
Definitely the best choice - better quality and slightly (handily) faster than the 45mm (which I own) and not so long as to overly compromise shooting close to the stages when I could (as the 75mm would have been, great lens though it is - I rented it for the same festival last year).
 Soulfulized's gear list:Soulfulized's gear list
Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus OM-D E-M10 II Olympus PEN-F Olympus E-M1 II +38 more
OP Po Sen Tsui Regular Member • Posts: 289
One more reason to use MFT cameras   It is certainly much harder for FF to be that sneaky
Not an expert, not a pro, I just shoot for fun
epozar
epozar Senior Member • Posts: 1,969
56mm has minimal CA (especially against a 75mm lens)
Both are super sharp though
 epozar's gear list:epozar's gear list
Olympus E-M1 Olympus E-M1 II Panasonic Lumix DC-G9 OM-1 Olympus Zuiko Digital 2.0x Teleconverter EC-20 +10 more
photofan1986
photofan1986 Veteran Member • Posts: 3,841
I voted Sigma 56 1.4, but then again, I'm biased as I'm absolutely IN LOVE with that lens
I owned the 75 1.8, and it's a great lens, but way too long for me so I sold it. And the O45 1.8 is very nice, I'll never part with it, as it represents the essence of m43, but it can't touch the Sigma for optical qualities (sharpness, contrast, lack of CA...).
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Panasonic Lumix DMC-GM5 Sony a7R III Olympus E-M5 III Panasonic Lumix G 20mm F1.7 ASPH +15 more
daleeight Veteran Member • Posts: 3,199
I have done it with the Olympus 17mm f/1.8 and Olympus 45mm f/1.8...
I have done it with the Olympus 17mm f/1.8 and Olympus 75mm f/1.8...
And the 45mm f/1.8 is a better pairing because it isn't "too long" in some cases... But with the versions that I have, the 75mm f/1.8 was way sharper than my 45mm f/1.8 (of course, way sharper is relative and is in reality the difference between 50 and 50.5, so it is there, but it isn't in your face)
For a landscape like trip, or where you will see something far away, I'd be taking the 75mm... for other types, the 45mm.
Dale
 daleeight's gear list:daleeight's gear list
Olympus E-M1 III Nikon Z7 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +6 more
Soulfulized
Indeed so:-D
Harold66
Harold66 Forum Pro • Posts: 12,002
There are good arguments to be made for both the 45mm and the 56mm
But definitely not the 75mm
Harold
FOLLOW me on IG @ledaylightstudio.
thedemandingtraveler.org
www.haroldglit.com
IG :thedemandingtraveler
 Harold66's gear list:Harold66's gear list
Sigma DP2 Merrill Ricoh GR II Panasonic Lumix DC-G9 Fujifilm GFX 50S II Panasonic 20mm F1.7 II +5 more
addlightness Veteran Member • Posts: 3,641
45/1.8
I have the 45/1.8 and 75/1.8.  No 56/1.4 (yet) but do a Sigma 60/2.8
For general use, 17/1.8 and 45/1.8 is not 'a bridge too far' to each other
I usually pair my 15/1.7 (no 17/1.8) with my 45/1.8 or 25/1.8 when traveling.
I reserve 75/1.8 (and 60/2.8) for street parades or indoor concerts/basketball where my wallet allows only cheaper seats or I have to be at the back of the crowd.  I only take these on car trips where I can leave them in the car when not in use.
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
John Glover
John Glover Veteran Member • Posts: 3,511
Re: 45/1.8
Same with me, these two make are very good and lightweight kit.
John Glover
Naperville, IL, USA
 John Glover's gear list:John Glover's gear list
Ricoh GR III Sony RX100 VII Fujifilm X-E3 Fujifilm X-H2S Fujifilm X-T5 +14 more
Day Hiker Forum Pro • Posts: 10,829
A wide separation
Two lenses. Don’t spread the focal lengths too much. 17mm (35mm) and 45mm (90mm) are a somewhat classic match if you don’t want/need 25mm (50mm) as #3 in a trio.
My two-lens choices are:
  • M.Zuiko 12-40mm f/1.8 Pro
  • M.Zuiko 8mm f/1.8 Pro fisheye
or
  • M.Zuiko 12-40mm f/2.8 Pro
  • M.Zuiko 75mm f/1.8
It depends upon whether I want reach or potential wide-angle flexibility. Generally I go with the 8mm Pro.
Jim Pilcher
Summit County, Colorado, USA
Living above life in the Rocky Mountains
56 is not that huge in terms of size compare to the 45?
eques Veteran Member • Posts: 4,115
Do even more: O 60 macro
What I used for do most purposes was wider than 17mm (Ricoh GR: 13-14mm equiv.) and 2.8/60 macro.
2 bodies to avoid changing lenses - crucial when in company.
The 60 for triple use: short tele, macro and portrait.
What I missed sometimes was a UWA and more often a longer tele (birds and beasts), never ever a FL between 14 and 60mm. When I used the 12-40, I always found 40mm too short.
Peter
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Olympus 12-100mm F4.0
Searching Veteran Member • Posts: 3,964
 Searching's gear list:Searching's gear list
Olympus E-M1 II Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +4 more
Felice62 Veteran Member • Posts: 5,079
As the variables are too many i would go for the 45/1.8 as both longer FLs might limit too much the FOV.
In addition, 45 is just as good as 56 and 75.
YMMV if course
I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
 Felice62's gear list:Felice62's gear list
Olympus Stylus 1 Olympus Stylus Tough TG-850 iHS Olympus Tough TG-3 Panasonic ZS100 Olympus OM-D E-M5 +36 more
tedolf
tedolf Forum Pro • Posts: 29,547
Leicaesque
This is very Leicaesque.  When Leica cam out with the CL (Compact Leica) film camera they introduced it with two compact lenses, a 40mm f/2 and a 90mm f/4.  Your choice compares favorably. With the 2x crop factor the 17mm and 45mm are like 34mm and 90mm on full frame.  That was a good pair for travel then, and is a good pair now.
I have traveled with a 17mm f/2.8 and the manual 40mm Leica (Minolta) f/2 in Italy.  Worked out really well.
TEdolph
 tedolf's gear list:tedolf's gear list
Olympus PEN E-P5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Samyang 7.5mm F3.5 Fisheye +9 more
John Glover
Re: Leicaesque
TEdolph
Those were exactly my thoughts when I paired up those two lenses some years ago. I learned how to use an SLR on a Pentax Spotmatic with 28mm, 50mm and 135mm SMC primes. For a full prime kit with the EM5.2, I add the 14/2.5 and the 25/1.8. That makes me very Leicaeque (or Pentaxish) , with 28, 35, 50 and 90mm equivalents. And it is *still* a light kit compared to my old Pentax gear!
Granted the 12-40/2.8 can cover those same focal lengths and give me a little more on the wide end, but sometimes I just enjoy using a more traditional 1950's rangefinder approach. It makes me slow down and enjoy the process of photography.
John Glover
Naperville, IL, USA
Harold66
Re: A dissenting voice
I  know that a majority of people think that a 35mm focal length is virtually the same as a 40mm for but in 30 years of photography I have never had that experience
when I am travelling (not shooting in the studio)I probably could  do 80% of my images with a 40mm
I never could say the same thing about the 35mm or the 50mm FOV
Harold
www.haroldglit.com
007peter
007peter Forum Pro • Posts: 12,933
My recent Trip using 15/1.7 + 45/1.8 combo..... realize 60/2.8 would be better
Great minds thinks alike. I like to travel light, so I only carry my
  • 90% Panasonic Leica 15mm f/1.7 and
  • 10% Olympus 45mm f/1.8
for my last trip to Asia. Due to the scenery nature of traveling, I found myself using WIDE 15mm nearly 90% of the entire trip. There are very few moment when I think its worth-switching-lens to 45mm f/1.8 for a tighter head-shots, but when I do switch to 45mm f/1.8, I often found it Not Tight Enough, and backdrop not blurry enough for my liking. When I came back from the trip, I immediately sold the 45mm f/1.8, and is now evaluating between buying
  • Sigma 60/2.8 vs
  • Olympus 75/1.8
What I learned from my recent trip is that:
  • what makes sense on paper (Olympus 45/1.8) may not make sense in real life
  • Real Life has a way of forcing you to re-consider your own preference in swapping-lens, in telephoto-compression,  or in the "LOOK" that you prefer.
YMMV, but for me, I think a longer reach 60mm or 75mm would pair better to my PL 15mm f/1.7.
 007peter's gear list:007peter's gear list
Panasonic Lumix DMC-GF6 Panasonic 20mm F1.7 II
