Aperture changing constantly
Started Aug 12, 2019 | Discussions
AndreM365
AndreM365 Forum Member • Posts: 78
I've searched the web for an answer to this, but no definitive answer. Pre-AF OFF, AF-S, not touching any buttons, the aperture changes constantly as the light entering the lens changes: https://youtu.be/OqaF87utnlM
My questions:
Why is this required?
How will this affect the life of the aperture mechanism?
Can I turn it off.
Cheers, André
 AndreM365's gear list:AndreM365's gear list
Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS Fujifilm XF 16mm F1.4 R WR XF 90mm +6 more
imagei Forum Member • Posts: 64
Re: Aperture changing constantly
I'm guessing here but try turning off exposure/effect preview (whatever it's called), perhaps set natural view to on as well if your cam has it. I also think it wouldn't do that if you select EVF-only+eye-detect view mode, not until you put the camera to your eye at least.
 imagei's gear list:imagei's gear list
Fujifilm X-T100 Fujifilm X-T5 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR +4 more
nex55 Regular Member • Posts: 232
I think if the lens diafragm (apertutre ring) is in position" a " (automatic) so the aperture changes with the change of light entering the lens
this is a normal working mode of the camera - no harm
 nex55's gear list:nex55's gear list
Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS
AndreM365
OP AndreM365 Forum Member • Posts: 78
Lens was set to F2.
Cheers, André
AndreM365
Thanks. I toggled Viewmode and Natural View and that makes no difference. Is "Exposure/effect preview" referring to the "Preview exposure in manual mode" setting? I think that only applies to manual mode, but I tried that too.
Cheers, André
Doug Pardee
Doug Pardee Veteran Member • Posts: 9,920
6
The camera is maintaining a usable exposure setting in order to get proper images to display on the EVF or LCD.
It's part and parcel of the mirrorless experience. Exposure control is no longer a "when the shutter is released" kind of thing -- it's continuous whenever the viewfinder is active. There's nothing you can do about it.
When you half-press, the camera will adjust to your shooting parameters, which means it'll stop down to your designated aperture and will stay there until the picture is taken or you release the shutter button.
Co-founder of the open-source LightZone Project: http://lightzoneproject.org/
 Doug Pardee's gear list:Doug Pardee's gear list
Fujifilm X-T10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Olympus Stylus 1030 SW Canon EOS 350D +13 more
vhimste Junior Member • Posts: 26
Hi Doug, your explanation is correct, but still it remains a bit strange on why they do that: the fact that the lcd/evf can show a properly metered/exposed image when you half press the shutter (and hence close the aperture to your setting in Aperture Prio mode) means that they can somehow adapt the evf/lcd readout to show a well exposed image with any aperture.
So why they constantly change it when you do not half press the shutter and point the camera to brighter/darker areas is still a mystery to me. It is actually quite annoying as it makes a rattling sound in e.g. the kitlens.
So if you have any thoughts on that, please share as i also like to know how this stuff works inside.
Doug Pardee
It appears the camera doesn't like running the electronic shutter at a very fast setting during the "no-press" image framing time. It's still forced to go a bit high in full daylight -- my X-T10 won't stop down beyond f/5.6 during framing, and at a framing ISO of 200 (its minimum) the camera would need 1/1600 in Sunny 16 conditions.
You could ask Fujifilm why it matters, but I doubt they'd tell you. Modern "smart" cameras are based on a lot of secret-sauce logic that the manufacturers keep to themselves.
BurpeesAreHard Contributing Member • Posts: 880
It would be impossible for carefully conceived and executed experiments to have produced these results. I suggest that you undertake to meticulously document a series of experiments crafted to convince skeptics like me that your observations are correct. Along the way, you will likely discover where your thinking is wrong.
User1107598218 Junior Member • Posts: 28
My questions:
Can I turn it off.
It's a known issue. Fujifilm website has explanations, but in Japanese only. To avoid it, just manually set shutter speed. Meanwhile, please make sure "PREVIEW EXP./WB IN MANUAL MODE” in the camera menu is set to "ON".
AndreM365
User1107598218 wrote:
My questions:
Can I turn it off.
Very interesting. I have not been able to find that "known issue" mentioned anywhere. I did notice that switching to manual shutter stops the aperture stuttering.
Cheers, André
My questions:
Can I turn it off.
Try this if you can read Japanese: http://digitalcamera.support.fujifilm.jp/app/answers/detail/a_id/17361/~/%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%A8%E7%B5%9E%E3%82%8A%E7%BE%BD%E3%81%8B%E3%82%89%E9%9F%B3%E3%81%8C%E3%81%99%E3%82%8B%E3%80%82
Doug Pardee
Google Translate renders that as follows:
With the FUJIFILM X-Pro1, the diaphragm blades are automatically switched according to the brightness of the subject when the power is turned on to display the LCD with the appropriate brightness.
Therefore, if the amount of light transmitted through the lens changes, for example, by tilting the camera, you may hear the sound of the diaphragm blades moving.
If you press the shutter button halfway, the aperture value will change.
Which doesn't really say anything we didn't already discuss.
Tom Schum
Tom Schum Forum Pro • Posts: 13,282
I've gotten around this by using non-electronic manual lenses such as Rokinon 21mm F1.4.  The camera can't change the aperture or focus so it figures out how to make the EVF and LCD deliver usable imagery so you can take a picture.  This works well on my X-E1, X-T100, and X-T3.
Fuji could easily fix it with a menu item that says "set aperture full-time in aperture priority mode" but years have gone by and they won't do it.  This is my pet beef regarding the use of Fuji electronic lenses.  At present I own only one Fuji lens!
But Fuji is not the only one doing this.  I believe the Nikon D800 series allows you to set Nikon electronic lenses to fixed aperture full-time, but I have only heard this and I don't know of any others.
Tom Schum
Copper: Mankind's favorite electrical conductor
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
No, they didn't say anything new. It's just an official confirmation in 2015. And there isn't any change till now. But since I have already described the work around, we don't expect anything new, either.
AndreM365
Thanks for the replies. The workaround doesn't work for me as I mostly shoot Aperture priority. In manual mode the aperture stays wide open and display adjusts if you change SS, so I don't understand why they can't do the same in Av. They could easily fix it with firmware
Cheers, André
Vytas999 New Member • Posts: 2
I've the same issue on my X-H2, and can't find any setting how to disable this. Also it seems for me that this behavior started randomly without any real change to the settings...
 Vytas999's gear list:Vytas999's gear list
Fujifilm X-H2 Fujifilm XF 33mm F1.4 R LM WR
