Olympus: saving to new sub-folders within the DCIM folder?
Started Aug 12, 2019 | Discussions
Tango 55 Contributing Member • Posts: 815
Hi All,
Going on vacation with my E-M10 MkII and without a computer, I would like to create a new folder within the DCIM folder for each day of shooting. Is there a way of doing this? I don't see an option to change the default name of the 105OLYMP folder where each raw file resides.
Just in case you wonder why I need this: I got a RavPower FileHub, which is a neat device for SD-to-USB (flash drive) backup without a computer, but unfortunately it doesn't do incremental backups. It comes with a decent Android app in which I could select the individual pictures I want to back up from each day, but that's not ideal.
Searching the web and this forum I can't find almost any information on this topic.
Any thoughts?
Thanks in advance,
Ricky
 Tango 55's gear list:Tango 55's gear list
Sony a7 IV Olympus OM-D E-M10 II Canon EOS RP +1 more
Olympus OM-D E-M10
AussiePhil Contributing Member • Posts: 579
Re: Olympus: saving to new sub-folders within the DCIM folder?
Tango 55 wrote:
Hi All,
The folder naming is set and the camera will write 10k files before automagically creating a new folder incremented by 1
Most of these devices will create a new folder each time you insert the card ..... you end up with a lot of dups on the disk if you don't format the card each time... doesn't this device do that.
there was a thread here not more than a few days back.... buggered if i can find it though
Any thoughts?
Thanks in advance,
Ricky
More info here - https://www.howtogeek.com/204228/why-does-every-camera-put-photos-in-a-dcim-folder/
Cheers and best wishes
Phil
Galleries at
https://www.flickr.com/photos/byphilg/
OP Tango 55 Contributing Member • Posts: 815
That's the case with this device. Needless to say, if I format the SD card each day, I end up with no back up but a single storage location, which is what I'm trying to avoid. A good solution to the problem might be to save all files from the SD card each day, and then delete the backed-up up folder from the day before. This would work, except for taking longer each day.
I saw the one on file naming after formatting the SD card, if that's the one you remember. I use the "Auto" setting, which prevents having duplicate file names.
Any thoughts?
Thanks in advance,
Ricky
Thanks for your reply!
Ricky
alcelc
alcelc Forum Pro • Posts: 17,985
Indeed you can backup files selectively through the Android file manager (some good native one or there are a lot of free good stuff on Play Store).
I do it once a day or every 2 days during my trip. I used a <US$2 OTG USB SD card reader, a not new Android phone and a few 64Gb USB Flash Drives as back up devices for the 32Gb SD cards I am using. I am investigating the possibility (including cost efficiency) on using those 500Gb SSD external USB HDD.
Just look at the name of the last file you copied onto your phone (or on any devices they were copied), and pick all files after that would be done.
Albert
Your original idea was going to take longer each day if that is how the device works.
only delete the oldest folder set on the device once you need space.
All this assumes you were never going to fill the SD card up whilst on holidays
Nah it was a different one but that one is relevant as well
One thing is once you get a new DCIM folder as in 105xxxx to 106xxxx the file numbering resets to file00000 -> file99999 meaning you get duplicate names in different folders
now you should check how the device handles this, do files end up in a single day directory or is the dcim folder retained as well
Any thoughts?
Thanks in advance,
Ricky
Ricky
exactly how you handle this will depend on the SD card size, Disk size and the number of images you might end up with.
Phil
Galleries at
kbouk
kbouk Regular Member • Posts: 357
Tango 55 wrote:
Hi All,
Any thoughts?
Thanks in advance,
Ricky
Try menu H1 (Record /Erase), setting :
  • Assign Save Folder:
    • Allows you to create and “save to” folders so you can organize images within your card.
Cheers
Costas
 kbouk's gear list:kbouk's gear list
Leica Digilux 3 Olympus E-1 Olympus E-M1 III Olympus Zuiko Digital 25mm 1:2.8 Pancake Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD +12 more
JaKing
JaKing Veteran Member • Posts: 6,299
With the E-M1 MkII you can create and select user folders in-camera. See manual p.132.
Doubt that this facility is available on lower priced/earlier model cameras. I know my E-M1 MkI doesn't have this facility.
br, john, from you know where
My gear list and sordid past are here: https://www.dpreview.com/members/1558378718/overview
Gallery: https://www.canopuscomputing.com.au/zen2/page/gallery/
 JaKing's gear list:JaKing's gear list
Olympus E-M1 Olympus E-M1 II Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ Olympus 12-100mm F4.0 Olympus E-1 +29 more
The EM1X allows it as well but it's not an option in the EM10mk2 based on the user manual, hence why i didn't mention it in the first reply
Phil
Galleries at
Yes, I though of taking the E-M1 MkII with me, but I decided against it because of its additional weight. I'll be walking many hours a day, so I must take weight into consideration. Also important: I simply love the E-M10 MkII...
Ricky
Yes, I'll simply select the files to backup each day from the SD card. I rarely take more than 200 pictures a day, so it's not the end of the world to select the ones from the last day or two.
For your reference, I'm also using 32GB SD cards, and a 128GB USB flash drive. I looked into the 500GB and 1TB SSDs, but I don't need so much capacity, so I went for the tiny USB drive.
Ricky
kbouk wrote:
Tango 55 wrote:
Hi All,
Any thoughts?
Thanks in advance,
Ricky
I think you are not taking about the 10MkII...
