Olympus in body lens correction, manual lenses
Started Aug 8, 2019 | Questions
cvhmanchester New Member • Posts: 17
I am using an Olympus E-P5 for macro photography with a Canon FD bellows and its 35 mm macro lens or a Lomo microscope lens, magnification x 3-7. I am getting the same sort of chromatic distortion on these as on Olympus lenses, like the 12-40 mm, used for normal photography.
The first question is: does the in body correction continue operating when using manual lenses, and perhaps over-correct?
Second: Is there any way to add chromatic correction to processing of images from the manual setup?
 cvhmanchester's gear list:cvhmanchester's gear list
Olympus PEN E-P5 Olympus E-M5 II Olympus E-M1 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro +3 more
Olympus PEN E-P5
Skeeterbytes Forum Pro • Posts: 23,186
Re: Olympus in body lens correction, manual lenses
There will be none. m4/3 lens corrections are hosted in the lens itself. IDK which TruePic the E-P5 has but if it's VII it should "play nice" with all the system lenses, Oly or Panny.
Yes, in Lightroom for example you can create an adjustments preset to apply when you import your photos. Use the Develop module lens corrections to make the needed changes then save them as a preset to apply the next time you import.
Good luck!
Rick
OP cvhmanchester New Member • Posts: 17
Thank you for the straightforward, useful, advice.
I am currently trying out a Canon fitting Vivitar 135mm 2.8, with a Canon FD24mm 2.8 reverse stacked. Lots of CA to deal with!
