NX1 and 16-50S works with Ronin-SC
Started Aug 5, 2019 | Discussions
Mike Mu
Mike Mu Regular Member • Posts: 224
I know there's a few of us that take advantage of the NX1 for video.
I got the new Ronin SC and was able to balance it with a little hack of sliding the mount one screw back.  Works except for the part where if you tilt too high, it hits the viewfinder.  Other than that, the SC is a decent match for the NX1 and probably better for the NX500 (which I do not have).
 Mike Mu's gear list:Mike Mu's gear list
Sony RX100 II Sigma dp2 Quattro Lytro Illum Sigma dp0 Quattro Ricoh Theta S +35 more
Samsung NX1 Samsung NX500
markyboy81 Veteran Member • Posts: 4,778
Re: NX1 and 16-50S works with Ronin-SC
The zhiyan crane also works with the NX1 plus 16-50mm but it's quite a heavy combination to use for any length of time. I find the best combination is the nx500 plus kit zoom as you also have the option of controlling the zoom with a smartphone if you need to.
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
Hienc Junior Member • Posts: 32
That is impressive. I remember a few years ago i jumped through a few gimbals but non of them can balance the nx1 with S lens.
Kisaha Senior Member • Posts: 2,300
I have the Ronin S. No problem at all with NX1+S. I still recommend the S vs the SC for that setup.
Mike Mu
OP Mike Mu Regular Member • Posts: 224
I'm going to agree with you there.  But with that much extra weight and size, I think I'd be less likely to take it out and use it.  That's just me knowing myself.
Still its nice to know that I can use the NX1 + 16-50S on the SC.
Overall I'm on the fence on whether I'd keep the SC since I do consistently use other gear that does not fit well so I may end up with the Ronin S down the line or its successor.
Another reason is that I would feel more confident using a Pocket 4K/6K camera with the S than the SC. People have fit even Canon C200 there, the motors seem to be pretty powerful.
It is heavy though, and the axis do not lock, which is quite the bummer! If only they had a smaller and lighter battery at least..
Blasst Regular Member • Posts: 124
Mike, do you have some footage you could share with that combo?
 Blasst's gear list:Blasst's gear list
Samsung NX1
Yuriy45 New Member • Posts: 1
Hello. I also bought a DJI SC and eat it in combination with the Samsung NX1 16-50. Please tell, whether you managed to connect NX1 to a suspension bracket that beat availability provided by DJI function. Well, for example, turn on the video with the button on the suspension or use the panorama mode ... I just want to know, then I just can not connect or a problem with incompatibility.
ken69 Junior Member • Posts: 25
anybody tried with new rs2?
Ok Tay New Member • Posts: 1
I bought a RS2 about 3 weeks ago. Balaning was verz easy and gimbal rotating works really perfect with NX1 and 16-50S.
The only thing which does not work is the usb shutter function. NX1 swithches to USB file transfer mode as soon I connect it with the RS2. Independent whether storage function or remote function is pre-selected in NX1 menu.  Any ideas?
