Odd behaviour with 85mm lens and nx1
Started Aug 3, 2019 | Discussions
markyboy81 Veteran Member • Posts: 4,778
I rarely use my nx85mm, but when I do I'm blown away by the results. However, today I ran into a few issues.
Firstly the autofocus switched off randomly and I had to reboot to get it working again.
Then the screen just sort of froze but then eventually came back to life.
When I turned the camera off and put it away it was only later that I realised that it hadn't actually turned off and had rinsed through the battery by keeping the screen on the whole time.
Could this be an issue with the lens? I know it's one of the older models but I don't know if it's renowned for this type of problem. I'll add that I haven't had any issues with any other lens, apart from the 60mm, but that only misbehaved on my old galaxy nx.
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
Samsung Galaxy NX Samsung NX1
Re: Odd behaviour with 85mm lens and nx1
Might be an issue with contact. Try to clean the contacts on the lens and mount?
OP markyboy81 Veteran Member • Posts: 4,778
Will give that a go, thank you!
AndrewIsUsingTheNX1000 Forum Member • Posts: 60
maybe i can explain the lens frozing problem..it usually happens on my nx1000 when i detach the lens and reattach it in manual mode,i dont know why,but you should consider about this....
p/s: you are currently holding my favourite portrait setup lol.
 AndrewIsUsingTheNX1000's gear list:AndrewIsUsingTheNX1000's gear list
Samsung NX1000 Canon EOS 700D Sigma 70-300mm F4-5.6 DG Macro +2 more
I'm pretty sure I was either in A or S modes as I very very rarely go full manual.
I absolutely love the 85mm, even if my copy is very squeaky and slow to focus (though I think they all are slow).
Now I'm wishing I held on to the 50-150mm as it's autofocus was superb and it had the added benefit of ois, particularly useful for video. Ah well..
mnewxcv Forum Member • Posts: 90
I have had quite a few nx cameras and they can all be a little quirky. If I am having problems, I usually take the battery out for a minute and restart the camera. That usually does the trick to reset things since "OFF" is more of a standby mode than truly being off.
 mnewxcv's gear list:mnewxcv's gear list
Samsung NX1 Samsung NX 18-200mm F3.5-6.3 ED OIS Samyang 10mm F2.8 Samyang 35mm F1.4 Samsung 16-50mm F2.0-2.8 +1 more
ttbek Veteran Member • Posts: 4,869
O.o  I just assumed only mine squeaked.  No real trouble with focus speed on mine though.
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
LiveM Veteran Member • Posts: 3,836
I have always had exactly the same issues with this lens on my NX500. I believe it is a firmware issue, though it seems to have persisted through firmware upgrades on both kens and body.
For this reason, along with the autofocus, I avoid using this lens for weddings or any other live action.
 LiveM's gear list:LiveM's gear list
Samsung NX1
