Issue with T5i view finder when shooting stars.
Started Aug 1, 2019 | Questions
patsies62 New Member • Posts: 2
Hi everyone,
This is my first time posting here so I apologize if this is in the wrong sub forum or in the wrong format.
I have a canon t5i and it has been pretty solid for roughly 4 years. I want to get into Astrophotography and with that I started to take pictures of the stars a week ago to get practice on focusing on them. Everything was going fine I could see Vega clear as day and could focus it. I took one really noisy picture shooting at ISO 3200 for at 45 seconds and after that my view finder stopped working. I couldn't see Vega or anything in the view finder and when I went to take a photo it was pitch black. I took down my camera equipment and brought the camera inside and in bright light the camera seemed to be fine and I could take a normal photo. On the photos I took after the noisy photo and on the all black photo I took outside I noticed a lot of hot pixels or dead pixels on them that were not there before my very noisy photo. I ran the sensor cleaner in the cameras settings to hopefully fix the issue with the view finder after discovering these pixel issues. Friday night I went to take more photos. I turned the camera on and to my surprise I could see Vega again. I had to shut my camera off and wait about 30 minutes before I could take photos and when I went to turn the camera on again I couldn't see Vega anymore. It's like my lens cap is over the camera. Flash forward to last night and once again I couldn't see in the view finder but this time I could take photos unlike the prior night a week or so.
If anyone has any information as to what might be going on with my camera I would really appreciate any advice.
Thank you very much, Pat
PS: Here is a link to some of the photos I took last night: https://drive.google.com/drive/folders/1VJ1T-SBkFtOfURAwI5g3cEzRJiuYjfgu?usp=sharing
The first photo you can really notice all the hot/dead pixels.
Canon EOS 700D (EOS Rebel T5i / EOS Kiss X7i)
Ralph McKenzie Senior Member • Posts: 2,121
Re: Issue with T5i view finder when shooting stars.
I've used both my 1000d and 650d (t4i) to do astrophotgraphy and not had this issue.
I looked at your linked images and all are out of focus, but what we really need is the lens you used, what focal length you used and then all the relevant camera settings.
BTW 45 seconds is far to long an exposure unless your were trying to do star trails.
The behaviour you detail sounds a little like the auto LCD switch is active but not switching back to the LCD after the shot is taken.
The image below is taken with my Canon t4i and the standard 18-55 kitlens and is a stack of 10 images taken at 20 seconds per image at ISO 1600, so if all goes well you should be able to get this sort of result from your camera.
By any chance is your image review time set to off?
Please post those camera settings if you can, but what you describe does sound as though there could be another issue unrelated to settings.
http://akiwiretrospective.com/
Fuji HS20EXR,S5700
Canon 1000D, EF-S18 - 55 mm & EF 70 -300 mm
 Ralph McKenzie's gear list:Ralph McKenzie's gear list
Fujifilm FinePix HS20 EXR Canon EOS 600D Canon EF-S 18-55mm f/3.5-5.6 IS II Canon EF-S 55-250mm f/4-5.6 IS II
Helen
Helen Veteran Member • Posts: 7,606
patsies62 wrote:
Hi everyone,
Presumably you're referring to the eye-level viewfinder - you weren't using live view (in which case you'd be looking at the image, before taking it, via the LCD monitor), I assume?
I wonder if what you are running up against is long exposure noise reduction? Take a look in your menu system, in the third tab with a camera icon - note there is an entry called long exposure noise reduction. If you go into this, does it say either Auto or Enable? If so, that could be what you're seeing. There is also a Disable option, which could bypass this problem if this is what's causing it, but at the expense of even noisier results.
Most digitals have this option (sometimes under different names). It's a process called dark-frame subtraction. On long exposures (over 1 second long in the case of your model), this function can be used to help cut down the hot and stuck pixels that are more likely to build up during a long exposure as the sensor heats up. A second exposure (but with the shutter closed, so that it's blank) follows the actual exposure. Because the mirror is up, the viewfinder is blocked by it. The purpose is that in that second exposure, the only bright points will be the hot pixels, so the camera notes where they are and blanks them out on the real image it just took. On "Enable" this will always happen for long exposures - on "Auto", it will only happen if the camera thinks there are hot pixels in the real image - but it could mistake stars for these and trigger it. In any case, if it runs this process, that second exposure IS ALWAYS THE SAME LENGTH as the first, real one - so 45 seconds again in your example. Do you think this is maybe what you were experiencing when the viewfinder image disappeared? It would feel like forever if you weren't prepared for it to happen.
guinness2
guinness2 Veteran Member • Posts: 4,617
Without an EXIF info of pics youposted , there is no advice for you ,I am affraid
 guinness2's gear list:guinness2's gear list
Canon EOS Rebel SL3
OP patsies62 New Member • Posts: 2
I breifly read some of the comments but I need to clarify one major mistake I made in this post.
1) I am talking about live view not the view finder... Sorry for the stupid silly confusion...
2) As far as the lens settings and what I was shooting at this is the information
Lens: 70-200MM f/4 L
Focal Length : 200MM
ISO: 1600
Shutter speed varied from 30-45 seconds.
I was using a skyguider pro and trying to verify it was tracking well and that I was indeed aligned with Polaris so I tried a few shots at 45 seconds and I increased the ISO to 3200 a shot a few shots at a shutter of 5-10 seconds. I finally shot a shot of 45 seconds at ISO 3200 and I got my the live view to stop working. The screen went totally dark.
This is a link to the first batch of photos I took of the stars when the live view was working.  I am very new to astrophotograhpy and I was really just trying to work on getting my stars sharp.  The stars are still out of focus but with the live view working and me being able to see the stars I had a much easier time focusing and they look a lot better rather than me just guessing the focus point and taking shots..  My only concern is I might have over heated the sensor when I took the image of ISO 3200 at 45 seconds.
https://drive.google.com/drive/folders/1aoob9MJCvGwzW-HJ-nWBaLCCvc7-QpvH?usp=sharing
Thank for all the replies so far.
it would seem unlikely that the sensor would overheat, not to say it cant, just seems unlikely.
I feel you are using the wrong lens to start with. You really should be using a shorter focal length with wider field of view. To get sharp stars at 70 mm your exposure time is only going to be 5 or 6 seconds before star trailing is observable and you wont be able to tell if your focus is right. Of course with a tracking mount this will be better.
What method are you using for checking the stars focus? I mean by this whats your step by step process for setting up the lens focus. Might I also suggest you spend some time on Lonelyspecks website to get a better understanding of the task at hand.
https://www.lonelyspeck.com/lenses-for-milky-way-photography/
https://www.lonelyspeck.com/milky-way-exposure-calculator/
https://akiwiretrospective.com/about-astrophotography/
Fuji HS20EXR,S5700
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Long Exposure Noise Reduction?
patsies62 wrote:
I briefly read some of the comments but I need to clarify one major mistake I made in this post.
ISO: 1600
I was using a skyguider pro and trying to verify it was tracking well and that I was indeed aligned with Polaris so I tried a few shots at 45 seconds and I increased the ISO to 3200 a shot a few shots at a shutter of 5-10 seconds. I finally shot a shot of 45 seconds at ISO 3200 and I got my the live view to stop working. The screen went totally dark. ...
+ 1 to Helen's response. It sounds to me that you have Long Exposure Noise Reduction enabled. pp. 127-128 of the 700D/T5i instruction manual. Whether using the viewfinder or live view it takes a 2nd exposure with the shutter curtains closed for the same length of time as your initial exposure. Shooting with the viewfinder, it remains dark because the mirror is up. Shooting with live view the monitor is completely black because the 2nd noise reduction exposure is with the shutter curtains closed.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Helen
Re: Long Exposure Noise Reduction?
ISO: 1600
Thanks - that saved me a long, waffly sequel (my style, unfortunately!!) adding that it could still be Long Exposure NR in live view too.  The OP's fear of overheating probably needn't be too much of a concern to them - long exposures do generate more heat (and hot pixels), but the camera would probably cut out to protect itself from damage (which is I suppose another potential reason for the live view cutting off, actually).
While long exposure NR could be a potential problem, its highly unlikely that overheating due to the length of exposure is occurring. My T41 and my friends t5i & t61 all do several minutes per exposure without heating issues. In his case he has the cameras attached directly to an imaging telescope and typically does 180 to 300 second subs and will often do a run of 20 of these exposures one after the other.
Some people cool their cameras to control the amount of hot pixels and to improve long exposure astrophotography imaging. For the short duration that the OP describes it seems more likely that there is something else at play with the camera, which is why we need to see how the camera is setup and a step by step process to help the OP eliminate any potential problems.
Fuji HS20EXR,S5700
