Olympus Zuiko 14-54 F2.8-3.5 Mark I Four Thirds Lens slow autofocus - adapter issue?
Started Jul 31, 2019 | Questions
pcunnin Regular Member • Posts: 378
I just bought a used Olympus Zuiko 14-54 F2.8-3.5 Mark I,
It's originally for four thirds...
The autofocus takes around 3-4 seconds with a fotga adapter. That's the most popular adapter I've seen.
However I had a Zuiko 50-150 lens before which hunted in low light but focused fast in good light.
But this lens takes forever even in good light...I just bought the adapter new, and sold the old one, so could this be an adapter issue? I haven't tested the adapter on different lenses.
It seems to turn over focus quickly but when narrowing the focus it moves very slowly which is why it takes 3-4 seconds. Basically it gets close to the correct focus, then moves VERY slowly to the correct focus, refocuses, then beeps into place.
Any suggestions?
I've heard the Mark II version of this Four Thirds lens focuses better, but I'm not sure I can recommend this first version if this is how it's supposed to work, unless I should try to replace the adapter.
I'm using an Olympus E-PM2
Olympus PEN E-PM2
dave rogers Contributing Member • Posts: 774
Re: Olympus Zuiko 14-54 F2.8-3.5 Mark I Four Thirds Lens slow autofocus - adapter issue?
7
The Mark I 14-54 isn't configured for contrast-detect autofocus. The MK II version includes an additional signal line in the lens contacts that helps facilitate contrast-detect autofocus. The lens is behaving normally, it's not your adapter, nor your camera.
It will auto-focus, it will just be slow.
 dave rogers's gear list:dave rogers's gear list
OM-1
Garry Schaefer Veteran Member • Posts: 3,349
I agree with Dave's assessment in general, although I believe it would be considerably faster on a body with phase-detect on sensor (the E-M1 or E-M1 Mk2.
Garry
 Garry Schaefer's gear list:Garry Schaefer's gear list
Panasonic Lumix DMC-G3 Olympus OM-D E-M10 Olympus E-M1 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 +8 more
ahaslett
ahaslett Forum Pro • Posts: 12,662
It is!
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
Mark9473 Veteran Member • Posts: 6,428
The adapter just passes electrical signals, and electricity travels at nearly the speed of light. It's the body that determines which signals are given to the lest and how fast they come.
On my G80, this lens focuses in about 2.5 seconds. That's with both the MMF-3 adapter and a cheap Chinese knock-off.
Mark
 Mark9473's gear list:Mark9473's gear list
Canon G1 X II Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX85 Panasonic G85 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +21 more
Jouko Senior Member • Posts: 1,985
On Olympus line-up the Em1-versions are most suitable for using old FT-lenses. Phase detection AF (PDAF) needed for fast AF.
Anyway, all the other bodies will do the focusing - slowly, hunting, but usually getting there. With wide angles the Af speed usually is not a big  issue, because of the "nature of the usual shots" - landscapes etc. With longer focal lenghts - af speed is usually just too slow.
The EPM2 camera is not the newest nor fastest in any way, not even with the mFt-lenses. So, the combination may be slow for AF... Does not depend on the adapter.
The lens itself is a nice peace of glass - sharp, fast, quite compact.
Cheers!
Jouko
'The best camera in the world is the one you have with you when you need it'
https://www.instagram.com/jouko.k.lehto/
http://lehtokukka.smugmug.com/
http://jouko-lehto.artistwebsites.com/
https://joukolehto.blogspot.fi/ - Lenses for mFT-cameras
https://joukolehto.blogspot.fi/2015/12/what-to-dowith-camera-during-winter.html
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
Good used E-M1 mk1 bodies are now fairly inexpensive.
My E-M1 mk1 focuses very fast with the 43 lenses. On other bodies, the AF woth 43 lenses is versy slow.
Cheers
Eric
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
OP pcunnin Regular Member • Posts: 378
E-M1 bodies are like $200 on ebay looks like on average...I don't really feel like buying a new body.
I'm having trouble getting the lens to focus when zoomed out fully (At 14mm) I'm guessing the lens isn't having enough data to focus. The autofocus doesn't "click" it just stops at a certain point like infinity focus.
Any tips on getting this to work? Or just chuck the lens lol?
Michael Meissner
Michael Meissner Forum Pro • Posts: 28,013
In good light, I might agree with you.  However, I've found in low contrast situations, my E-m1 mark I hunts badly while my E-5 snaps into focus immediately using the mark I 50-200mm f/2.8-3.5 lens.
In particular, I do at least one whale watch each year, and when you are trying to focus on a whale in the ocean if you don't have the E-m1 mark I oriented correctly, it will hunt badly and not achieve a focus lock.  The year after I discovered this, I brought my E-5 out of mostly retirement, and it had a much larger keeper rate.
The reason is the E-5 had cross shaped sensors for each of its main phase detect focus points.  I.e. the camera could find straight lines in either horizontal or vertical orientations.  The E-m1 mark I on the other hand only has sensors aligned in one direction.  So if you have the camera aligned so it is looking for horizontal lines, and the subject you are focusing on has vertical lines, it will hunt.  The work around is to switch the camera's orientation, and it should find focus much faster (obviously you will need to crop if you wanted a landscape orientation photo and you have to shoot in portrait orientation.
The E-m1 mark II fixes this as it has cross shaped sensors.
The first generation lenses that I own (14-54mm mark I, 50-200mm mark I, 11-22mm, 50mm) were made long before Olympus decided to do micro 4/3rds.  The last generation of consumer lenses (40-150mm mark II, 14-42mm, 70-300mm) as well as the 14-54mm mark II had some support for contrast detect auto focus (used in micro 4/3rds cameras, and also the last generation of classic 4/3rds cameras in live view mode).
This means the 14-54mm mark II now focuses somewhat faster on other bodies than the E-m1 mark I, but it is by no means a speed demon.  The difference between the two on a non-Em1 body is between dreadfully slow and merely slow.  I bought the 14-54mm mark II specifically to use with my E-m5 mark I and it is still somewhat slow to achieve focus.  Fortunately the use case is when my E-m5 mark I is inside my steampunk camera case, and generally people are posing for photos, and having a 1-2 second delay isn't bad.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-5 Olympus E-M5 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
Eric Nepean
Useful comments; you have more 43 gear than I have, and older as well.
I based my comments on the mark II 50-200 SWD which works well on the E-M1 mark I, and has quite useless AF on other bodies.
Cheers
Eric
Miron09 Senior Member • Posts: 1,068
correct, the OMD cameras manage a bit better. Still not very fast
 Miron09's gear list:Miron09's gear list
Olympus PEN E-P1 Olympus PEN E-PL1 Panasonic Lumix DMC-GF3 Olympus PEN E-P3 Olympus PEN E-PL5 +18 more
