Back focusing SL1
Started Jul 29, 2019 | Discussions
Mike - Senior Member • Posts: 1,068
Back focusing SL1
Has anyone found front or back focusing problems with their SLX cameras (or even checked) ?
Wondering what...if anything Canon might do to help with an older, bottom of the line body.
I've never been overly happy with my SL1.  The detail/sharpness has not been very good.  I chalked it up to a cheaper body and left it at that.  I was checking the micro focus on a new lens on a Sony body, and the SL1 was sitting close by...I thought what the hell, I'll give it a go..!  It has a zoom lens on it, so I tried f5.6 - f8 - f11.  While f8 was by far the best, I also noticed that it back focuses by a large amount.  I tried a second lens (also a zoom), almost as bad.
Unfortunately there is no adjustment in the SL1 like the higher end bodies..!
Experience anyone ?
Mike
 Mike -'s gear list:Mike -'s gear list
Sony a6300
Canon EOS Rebel SL1 (EOS 100D)
tbsteph
tbsteph Regular Member • Posts: 150
Re: Back focusing SL1
Experience anyone ?
Mike
Only fix for a back/forward focusing SL1 that I know would require a service repair by Canon or ?. I previously owned a SL! and never noticed this issue. But, never had it checked either. I think you already know what Canon might do to help with an older, bottom line body.
tbsteph
 tbsteph's gear list:tbsteph's gear list
Fujifilm X-T20 Canon EOS R6 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Canon RF 24-105mm F4L IS USM +1 more
Wave forest Regular Member • Posts: 356
What is your lenses, Canon or Third Party? My this post may help.
Experience anyone ?
Mike
 Wave forest's gear list:Wave forest's gear list
Sony RX100 Canon EOS 550D Sigma 17-70mm F2.8-4 DC Macro OS HSM | C Sigma 35mm F1.4 DG HSM Art Canon EF-S 55-250mm f/4-5.6 IS STM +2 more
OP Mike - Senior Member • Posts: 1,068
Both, and as noted, both have similar problems, the "off brand" is slightly worse...but.
I guess it'll just have to do mostly what it's been doing, siting on a shelf...looking pretty..!  I have a hand full of quality bodies and lenses, I was just curious.
Mike
Experience anyone ?
Mike
Sony a6300
Helen
Helen Veteran Member • Posts: 7,606
Experience anyone ?
Mike
I've had very poor focus accuracy, especially at wider apertures, with the 50mm f1.8 STM (two examples) on my 100D (SL1), and 750D (which I no longer have) and indeed my 200D (SL2).  The first two seem OK with kit-level zooms (i.e. smallish maximum apertures), whilst the 200D actually seems a bit questionable overall - I have some milder concerns with its performance with such zooms.  In all three cases, they were fine even with the 50mm lenses in live view mode, which does indeed point to the type of PDAF adjustment issues that would be helped/cured by micro-adjustment, if only they had that feature.  I have also observed a very similar problem with a 50mm f1.8 on a Nikon D5500 - again, it's fine in live view (which also suggests it's nothing to do with user error at the narrower depth of field of wider apertures), so it's by no means an issue confined to Canon DSLRs.  The Nikon also has no micro-adjustment feature (it also has some pretty strong shutter vibration interactions at certain speeds with certain lenses, which is something the Canons are inherently free of, since they use electronic front curtain shutter operation).  Once at a narrow enough aperture in SLR (i.e. PDAF) mode, the 50mm lenses on both brands of camera behave better as the increased depth of field helps to disguise it.
What's never clear with this focus accuracy issue with PDAF is how much is contributed by an issue in the body and how much by an issue in the lens, as it can be variable (presumably sometimes a lens could have its own issue that either compounds the problem, or in some cases lessens it, if the lens problem is in the "opposite direction", so to speak, of the one in the body; or of course there could be no issue at all with the lens itself.  Similarly there must be examples of bodies that have no issue at all as well - though sadly that doesn't seem to apply to any I've owned!).
Do you find that your lenses behave better on the Canon in live view mode too?
I'm old enough to have used film-based SLRs a lot too, and oddly, even when they had PDAF systems configured and designed similarly to current DSLRs, they didn't seem to have this issue.  Doubly strange given that they were full frame, with inherently narrower depth of field (though of course their 50mm lenses were 50mm, rather than equivalent to 80mm [on Canon APS-C bodies] or 75mm [on Nikon APS-C], so maybe that offset the narrower depth of field largely).  Maybe they simply checked them and adjusted them on the production line more stringently then, though some were very cheaply made, so I don't know...
Re: Back focusing SL1, Helen ?
PADF ?
I've never used Live View in any of my cameras.  Well...I guess my point and shoot/pocket cameras are really Live View based, so in reality, I guess I have used...Live View.
I should try my two current APS-C lenses on my old 40D and see what happens.  I guess I should see if I have a usable battery for it first..?!  My 40D was my favorite (of many Canon bodies) until I went with full frame bodies (6D and 5D IV).  Neither of these required any focus adjustment with the lenses that I use with them.  Same exact test as done with my SL1.  Distance, time of day, body and lens settings, everything.
Mike
Sony a6300
Helen
Mike - wrote:
PADF ?
PDAF - phase detection auto focus. Strictly speaking this describes the measurement method used to determine correct focus, and initially in DSLRs (and AF film-based SLRs) the only system they used was a separate PDAF array, whereby a bank of dedicated phase detection sensors in the base of the mirror box receive light, via the lens, which passes first through a semi-silvered portion of the reflex mirror and then is reflected down to them via a sub-mirror assembly mounted on the back of the main mirror. Obviously that somewhat convoluted optical path does have some inherent possibility of deviating from being exactly matched to the light path directly to the image sensor when the mirrors are up for an exposure, either via an adjustment issue during manufacture (any almost-microscopic deviation could have a visible effect on the results) or perhaps in the course of use, for example if some kind of impact befalls the camera. And that's where front- or back-focusing could occur.  This system is always used, including on the latest DSLRs, when the DSLR is being used in its native eye-level optical reflex mode.
Yes, they are, effectively.  The image preview being fed through the lens and displayed on the rear monitor prior to the shot is live view.  These days it's an (optional, activated by a button or switch) feature on any current DSLR, and the inherent, normal operational mode of mirrorless interchangeable lens cameras.  DSLRs are a lot better at it than they used to be, but its use still causes the eye-level optical reflex finder to be blocked and forces you to use the LCD monitor as your only viewfinder, whereas mirrorless cameras also have the option of retaining eye level use if they possess an electronic viewfinder.
Your comment about the 6D and 5D IV reinforces a facet of "Murphy's Law" that often strikes me - I haven't double-checked, but I bet both models have micro-adjust facilities.  It often seems to be the case that the cameras which don't need it doing are the ones that have the ability, whilst those where it needs doing (like, perhaps your erstwhile SL1) are the ones that don't have it and would require a trip back to the manufacturer!  Such is life... (it is perhaps because the more expensive models are built in smaller numbers and perhaps checked and calibrated more carefully than cheaper, large-production models which are additionally probably anticipated to be mainly used with smaller maximum aperture kit zoom lenses, which maybe won't show AF errors so readily as large-aperture prime lenses anyway).
I just familiarised myself with the EOS 40D by reading the DPR review of it.  If I read it correctly, the 40D does have an early iteration of live view, but unfortunately it wouldn't fully answer the question for you (obviously if it doesn't show a problem with any of the problematic lenses anyway, then it has no issue itself, and neither do the lenses, most likely).  The thing is, however, that the 40D achieved autofocus in live view by momentarily switching back to the DSLR separate PDAF array anyway - a brief mirror-drop occurs (cutting off live view for its duration and reinstating the view through the optical reflex viewfinder as a side effect, before returning to live view once AF lock is achieved).  Therefore results would be the same, regarding the AF system, whether in live view or not, as the same system is used for both modes of use.  Later DSLRs started to give the choice between this form of mirror-drop AF operation in live view or providing an uninterrupted live view AF operation by using the image sensor itself to achieve AF (in the way that all mirrorless interchangeable lens cameras always do).  Initially this was using the slow but precise contrast detection AF method (CDAF) but as sensors have evolved, a way of providing PDAF on the sensor itself has been developed - many brands use both on-sensor methods, switching between them as required or combining them.  Whichever method (PDAF or CDAF) is used, as long as it's on-sensor (the image sensor, that is) there should be no front- or back-focus in most circumstances.  Canon now uses the confusingly-named DPAF system on its latest models, which is a form of on-sensor PDAF named for its dual-pixel AF arrays.  The quick mirror-flip type of live view AF that reverts to the separate SLR-style PDAF array (as in the EOS 40D) is largely a thing of the past these days.
So, it's only the newer uninterrupted-AF in live view style (via AF measurements done by the imaging sensor itself) that show up for sure if there is an adjustment issue with the separate SLR-style PDAF system used when the DSLR is not in live view mode - soft results in normal eye-level operation, but perfect results in live view with all other settings the same are the telltale sign of this - but unfortunately it's a difference the EOS 40D's live view AF setup is not able to demonstrate since it uses the same measurement array as when it's not in live view.  Sorry that's rather long-winded but I hope it helps!
Mike
jvc1 Senior Member • Posts: 2,202
I had an SL-1, now an SL-2. My 15-85 front focused noticeably on the SL-1 but is fine on the SL-2. From my experience, it seems that all my STM lenses work very well in the SL bodies. The only reason I have an SL-2 is for it's small size and portability so I usually want the smaller, lighter STM lenses on it. I haven't done serious testing of all my lenses on the SL bodies but these types of threads make me wonder if there's a real reason STM lenses would work more reliably on SL cameras. This seems unlikely but still, I wonder.
I keep some of my favorite pictures here,
https://www.flickr.com/photos/129958940@N03/
 jvc1's gear list:jvc1's gear list
Canon EOS Rebel SL2 Canon EOS 90D Canon EF 85mm F1.8 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 60mm f/2.8 Macro USM +10 more
