Protecting Your Knees
Started Jul 28, 2019 | Questions
OP charley5 Senior Member • Posts: 2,703
Re: Protecting Your Knees
Interesting. I have a swingable LCD but never explored that possibility. Always used the viewfinder because of the critical focus I need to make.
lim yau tong wrote:
charley5 wrote:
Thanks Lim. What happens if you have to go very close to the ground though?
Get a camera with swingable LCD display. Use the LCD as viewer when u want low angle or closed to the ground shot.
 charley5's gear list:charley5's gear list
Sony a7 II Sony a7R III Zeiss Otus 55mm F1.4 +2 more
john54 New Member • Posts: 8
Okay here's a question.   Finding plenty of good options for padding my knees.  Is anyone using anything special that helps get back up ??  Ref. Bad knees.
Currently, when I want to get low I have to remember to consider what is close by to grab onto.
BBbuilder467 Veteran Member • Posts: 7,057
After an operation, I used an adjustable hiking pole to help pull myself up. With the grip around shoulder height kneeling, I could lift myself up off the ground. I had no strength at all in my knees for months. I could barely get out of a chair without the hiking pole.
john isaacs Veteran Member • Posts: 8,414
charley5 wrote:
Just wondering how macro photographers deal with the fact that they may be on their knees a lot, leading to sore knees? I am at the age when such considerations have become more prominent. I was thinking of getting gardener's knee pads, but I am not sure that will help since my body weight would still be on the knees, and I am not necessarily kneeling on hard surfaces (earth, grass).
Thanks.
-Charles
I carry a carpet scrap when out shooting.  I put it down and kneel on it.  It fits in one of the pockets of my camera bag.
Another thing that helps is a right angle viewer.  I slip it on the viewfinder and I don't have to get down too low.  Works great, especially when it's too light to see the LCD.
Another thing I use is a Hoodman Loop with the sleeve for attaching it to the LCD.  Works if your camera has a Flipout Articulating Screen (FAS) instead of a Tilt Screen.
Finally, if you can't get really low, I can use my phone to connect to and control the camera.  I can mount the camera on an upside down monopod, and mount the phone higher up on the monopod, and then get the camera really low while I stand or sit (on a WalkStool).  That's really comfortable.
There are lots of ways to deal with reduced mobility and flexibility as one ages, or just gets tired of lying in the flower beds.
 john isaacs's gear list:john isaacs's gear list
Panasonic GH5 Olympus E-M5 III Olympus E-M1 III Nikon Z6 II Nikon Z7 II +15 more
Michael H Contributing Member • Posts: 733
I use a rubber doormat. It protects my knees and stops my boots from distributing the surrounding soil.
But to address your question gardeners use a kneeler (which could also work for macro work): https://ultimatebackyard.com.au/garden-kneelers/
Amazon: https://www.amazon.com/s?k=gardener+kneeler&crid=2CZ4LV0IT4FC2&sprefix=gardener+kneele%2Caps%2C384&ref=nb_sb_noss_2
rolandb
rolandb Veteran Member • Posts: 3,191
gardenersassistant wrote:
Thanks.
-Charles
I used knee-pads for several years but they annoyed me by slipping down very often, and I found the elastic could get uncomfortable at the back of my knees. Eventually I discovered workman's trousers with built in (removable) knee pads and I have been using them ever since. As well as the pads not slipping out of position these trousers also have the advantage of having lots of pockets, which I find very useful. I use them for photography and for gardening.
The knee pads look as though they are too low, but I find they ride up to the right position when I kneel down.
The workman's boots have steel toecaps and good support around the ankles. This is also good for kneeling down as the toes and ankles can stay in a more comfortable position rather than the toes being bent backwards and/or the ankles getting stressed as can happen with less rigid footwear.
Brilliant idea 👍👍👍
 rolandb's gear list:rolandb's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-LF1 Casio Exilim EX-ZR800 Panasonic Lumix DMC-ZS50
