Protecting Your Knees
Started Jul 28, 2019 | Questions
charley5 Senior Member • Posts: 2,703
Just wondering how macro photographers deal with the fact that they may be on their knees a lot, leading to sore knees? I am at the age when such considerations have become more prominent. I was thinking of getting gardener's knee pads, but I am not sure that will help since my body weight would still be on the knees, and I am not necessarily kneeling on hard surfaces (earth, grass).
Thanks.
-Charles
 charley5's gear list:charley5's gear list
Sony a7 II Sony a7R III Zeiss Otus 55mm F1.4 +2 more
RavRad
RavRad Regular Member • Posts: 133
Re: Protecting Your Knees
Thanks.
-Charles
I use these when I'm out shooting Macro. https://www.amazon.com/gp/product/B07BPWV83H/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
People will give me the crazy eye, but it doesn't matter...they'll give you the crazy eye for bing on your knees with a camera shoved into a bush or flower or grass anyways.
I know plenty of people in their 70's that get along just fine with their knees in all sorts of activities that require being on them because of my other primary hobby of metal detecting.  The main difference between those that are good and those that suffer is those that are good usually tend to exercise regularly.  The old guys that rode their bodies hard and put them away wet usually have issues, but still get by and do great with a good set of knee pads.
 RavRad's gear list:RavRad's gear list
Fujifilm X-T20 Fujifilm X-H1 Fujifilm 16-55mm F2.8R LM WR Fujifilm 16-50mm F3.5-5.6 II Fujifilm 50-230mm II +3 more
OP charley5 Senior Member • Posts: 2,703
Fantastic. Thank you for the suggestion! I take pictures in my backyard where no one can see me, so no problem about attracting attention!
-Charles
Leswick II Senior Member • Posts: 2,192
I've had several pieces left over from remodeling the shack (2" type) and I use it when I deal with bugs close to earth.
https://www.homedepot.com/p/Owens-Corning-FOAMULAR-150-1-in-x-4-ft-x-8-ft-R-5-Scored-Square-Edge-Rigid-Foam-Board-Insulation-Sheathing-20WE/207179253
Good suggestion. Thank you!
-Charles
richj20 Forum Pro • Posts: 10,181
Re: Protecting Your Knees - Yes!
Hello Charles,
I photograph in my back yard also -- several times a day, depending...
I keep an old bath towel handy which I fold into a nice padded knee rest!
- Richard
gardenersassistant Veteran Member • Posts: 9,656
Thanks.
-Charles
I used knee-pads for several years but they annoyed me by slipping down very often, and I found the elastic could get uncomfortable at the back of my knees. Eventually I discovered workman's trousers with built in (removable) knee pads and I have been using them ever since. As well as the pads not slipping out of position these trousers also have the advantage of having lots of pockets, which I find very useful. I use them for photography and for gardening.
The knee pads look as though they are too low, but I find they ride up to the right position when I kneel down.
The workman's boots have steel toecaps and good support around the ankles. This is also good for kneeling down as the toes and ankles can stay in a more comfortable position rather than the toes being bent backwards and/or the ankles getting stressed as can happen with less rigid footwear.
Makes sense. Thanks Richard!
-Charles
This is very useful. I will check out whether I can find workman's trousers with knee pads. Thanks!
-Charles
gardenersassistant wrote:
Thanks.
-Charles
NancyP Veteran Member • Posts: 6,608
1. Gardeners' or tilers' (hardware store) kneepads or a thick closed cell foam pad. Plus side of foam pad is that you can sit on it as well
2. Set of hiking poles, to help you get up from the kneeling position (particularly useful if you are wearing a backpack). Poles should be for balance, your arms alone aren't going to get you up.
3. Do practice getting up from a kneeling position at home - consider it an exercise for balance and for leg strength.
4. Get yourself up, then bend down and fetch your gear.
NancyP
 NancyP's gear list:NancyP's gear list
Sigma DP3 Merrill
Those look like great knee pads, I may have to upgrade from my "standard" hardware store tilers' kneepads. The old ones might get a second life as elbow pads in low blinds.
NancyP
Sigma DP3 Merrill
Thanks Nancy. I appreciate your suggestions!
-Charles
RavRad
After 12 years in the Army and probably a couple dozen different knee pads, these are the first ones that stayed put no matter what. I probably went through a dozen pairs on Amazon alone just to get to these.  I was so worried for some reason they might disappear I ordered 8 pairs so I have reserves until I’m in the dirt 😂
stevendillonphoto Senior Member • Posts: 1,259
I went to Lowes and got some knee pads that roofers wear.  I don't go anywhere without them being on my utility belt when I'm looking for compositions.
Steven Dillon - Capturing Nature's Art - http://www.stevendillonphoto.com
Thanks Steven. I appreciate the tip.
-Charles
lost alaskan
lost alaskan Veteran Member • Posts: 3,031
I don't do much macro but I do work with concrete. Cheap HF knee pads are worthless, but they do sell better quality pads. They always want to slip down that's just the nature of it. Our legs are long thin,tapering poles. I kind of like the idea of built in pads in the trousers. The tough boots are a good idea too.
 lost alaskan's gear list:lost alaskan's gear list
Sigma 30mm F2.8 EX DN Sony FE 70-200 F4 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +1 more
RavRad
Did you see the ones I linked above? After a decade plus of using kneepads and dozens upon dozens of types, I finally found knee pads that don't drop, no matter how hard I work them. https://www.amazon.com/gp/product/B07BPWV83H/ref=ppx_yo_dt_b_search_asin_title?creativeASIN=B07BPWV83H&linkCode=w61&imprToken=.5e21ODQeVU6UvAUXqToFA&slotNum=0&ie=UTF8&psc=1
lim yau tong
lim yau tong Veteran Member • Posts: 4,066
I normally carry a portable chair so that I can sit and take low down shots.
www.flickr.com/photos/limyautongphotography
yau tong
 lim yau tong's gear list:lim yau tong's gear list
Sony Alpha DSLR-A350 Sony Alpha DSLR-A700 Sony Alpha DSLR-A550 Sony SLT-A55 Sony SLT-A77 +33 more
Thanks Lim. What happens if you have to go very close to the ground though?
lim yau tong
Get a camera with swingable LCD display. Use the LCD as viewer when u want low angle or closed to the ground shot.
yau tong
