Why do you buy fast lenses/cameras?
Started 3 months ago | Polls
kiwi2
kiwi2 Veteran Member • Posts: 4,628
Re: Why do you buy fast lenses/cameras?
trungtran wrote:
Honestly i rarely shoot below F2.8.
I photography people singles and groups. I don't like the one person in focus and the other person not. If i don't have a speedlight or can't use it then sure i use the faster aperture, but i rather just use my zoom and have most people in focus.
But that's just you.
For all the scenes in this clip I didn't shoot f/2.8 or above. Everything was f/2 to f/2.5.
Sometimes nothing beats being able to gather as much light as possible in a certain time frame.
 kiwi2's gear list:kiwi2's gear list
Fujifilm X-T2 Fujifilm X-T100 Samyang 8mm F2.8 UMC Fisheye Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 56mm F1.2 R +4 more
Crash N Burn
Crash N Burn Regular Member • Posts: 119
Reilly Diefenbach wrote:
Abstaining. The absolute last thing I want on my camera is one of these two pound f1.4 monstrosities. The world really doesn't need another one eyelash in focus blurry nose and ears masterpiece :^)
An understandable position.
DSLRs have that clumsy AF fine tune confound, whose value varies as a function of focal length and subject distance--a problem rendered all the more apparent with fast glass. Then, there's that amusingly antiquated focus and recompose. Lastly, let's not forget to give credit where it's due: the Nikon Z's are very good at eyelash focus, from what I've heard.
You'd be surprised at how useable fast lenses are on, say, a Sony FF mirrorless body.
tony field Forum Pro • Posts: 10,295
Michael Fryd wrote:
tony field wrote:
Michael Fryd wrote:
Don't forget:
  • Brighter Viewfinder
  • More accurate auto focus
If you are using a camera with a padf system, why would an F 1.4 lens provide more accuracy then an F 4 lens or F 2.8 ??
Take the Canon 5D 4 for instance. There are 61 Autofocus points, but not all are created equal. Each point has from one to four PDAF sensors in various orientations; horizontal, vertical, right diagonal, and left diagonal.
Some of the sensors work with lenses that's f/8 or faster, some work with lenses that are f/5.6 or faster.
A few of them are slightly higher precision, but only work with lenses that are f/4 or faster.
Five AF points near the center offer the highest precision, but only work with lenses f/2.8 or faster.
Take the center AF point. With an f/8 lens the horizontal and vertical PDAF sensor will do a good job with most lenses. However, the right and left diagonal sensors can provide higher precision results with lenses faster than f/2.8.
As the camera focuses with the lens wide open, you get the benefits of the high precision focus points with an f/2.8 lens, even if you are shooting at f/8.
Thus the f/2.8 version of the 70-200 lens may yield more accurate focus than the f/4 version, even if you are shooting at f/4 or slower.
with the Canon systems you do not gain more focus precision with a 1.4 lens than you do with the 2.8 lens. As Marianne Oelund pointed out years ago the Canon F 2.8 focusing system does not seem to provide more precision than the Nikon F 5.6 focus system.
Charles Darwin: "ignorance more frequently begets confidence than does knowledge."
tony
http://www.tphoto.ca
Michael Fryd
Michael Fryd Forum Pro • Posts: 11,628
Correct.  An f/2.8 lens can provide more accurate focus than an f/4 lens.  However, there are no further improvements from moving to a lens faster than f/2.8.
 Michael Fryd's gear list:Michael Fryd's gear list
Nikon Coolpix AW130 Canon EOS D60 Canon EOS 7D Mark II Canon EOS 5DS Canon EOS 5D Mark IV +16 more
Bob A L Senior Member • Posts: 2,150
Personally, for me and not a recommendation. Absolutely no reason to buy fast lenses with the high iso, low light capabilities of modern digital cameras. Plus other reasons for me not to buy them - huge and too heavy, cost way too much money, no reason to want super  thin dof.
Mackiesback
Mackiesback Senior Member • Posts: 6,857
Michael Fryd wrote:
Don't forget:
  • They tend to be sharper (a high quality f/2.8 lens is likely sharper at f/3.5 or f/5.6 then a lens with a maximum aperture of f/3.5).
  • The wider apertures tend to be bundled with other features (i.e better build quality, weatherproofing, better optical quality).
That would be option number 4.
 Mackiesback's gear list:Mackiesback's gear list
Nikon Coolpix A Nikon D50 Nikon D100 Nikon Df Nikon Z6 +17 more
tko Forum Pro • Posts: 12,929
well
Michael Fryd wrote:
tko wrote:
trungtran wrote:
If i want better IQ in the low light, i use a bigger sensor
Bigger sensor don't gather more light, but bigger lenses do.
In terms of the lens, the angle of view and aperture diameter are the two main factors in how much light you gather. Generally, for a given angle of view, it's easier to find a lens with a large aperture for larger sensor cameras.
The OP implied he used a bigger sensor instead of of a bigger lens. They tend to go tougher, but you still need that faster lens.
no, I won't return to read your witty reply!
professional cynic and contrarian: don't take it personally
http://500px.com/omearak
OP Lee Jay Forum Pro • Posts: 54,794
Re: well
At the same f-stop, a bigger sensor is faster but the reason it's faster is that at the same angle of view the longer focal length lens has a larger entrance pupil.
Lee Jay
 Lee Jay's gear list:Lee Jay's gear list
Canon IXUS 310 HS Canon PowerShot SX50 HS Canon EOS 7D Mark II Canon EF 70-200mm F2.8L IS II USM Canon EF 8-15mm f/4L Fisheye USM +23 more
Michael Fryd
Mackiesback wrote:
Michael Fryd wrote:
Don't forget:
Yes.
But if the goal is to understand why people buy fast lenses, you probably don't want a survey where lot's of people select "other."
The survey provides far more insight when you can tell the people who wanted a brighter viewfinder from the people who wanted better weather sealing or more accurate auto focus.
On the other hand, if you are trying to promote a particular viewpoint with respect to shutter speed and depth of field, then it may sense to strategically omit common reasons.
Michael Fryd
Re: well
At the same aperture diameter and same angle of view, the light captured is independent of sensor size.
When we compare a crop body to a full frame, we seldom compare at the same focal length, as the result of the focal length depends on sensor size.
Why would you want to compare at the same f/stop?   The advantage of same f/stop is that we can maintain the same light per unit area on the sensor.   But different sensor sizes give us different noise levels at the same light per unit area.  That's no more a fair comparison that comparing at the same focal length.
If you want to compare at the same camera settings, use the same settings; same focal length, same f/stop, same ISO.
If you want to compare when you want similar results, then adjust the focal length to yield the same angle of view, use the same aperture diameter, and adjust the ISO to match.  (i.e. if your full frame is at 50mm, f/4 and ISO 800, your 2X crop body should either be at the same, or at 25mm, f/2, ISO 200.
Re: well
Yes.
I do that comparison, frequently, because I'm focal-length-limited or using a prime.
Because I can mount my crop and full-frame bodies to the same lenses.
Correct.
Lenses are a real-world limitation.  I have a 70-200/2.8, but I don't have a 320/2.8 to put on my full-frame camera to compare to.  It would win easily if I did, but I don't.
I don't have a reason to do that.
But real-world lenses can prevent that.
My telescope doesn't have an aperture actuator.  The entrance pupil diameter is fixed, regardless of angle-of-view.
Lee Jay
Mackiesback
Michael Fryd wrote:
Mackiesback wrote:
Michael Fryd wrote:
Don't forget:
Yes.
At the risk of overthinking it yes. Ideally, it could be a list of all the benefits where you can select multiple choices.
Michael Fryd
Mackiesback wrote:
Michael Fryd wrote:
Mackiesback wrote:
Michael Fryd wrote:
Don't forget:
Yes.
To be most useful, it should list the most common reasons.
Michael Fryd wrote:
Mackiesback wrote:
Michael Fryd wrote:
Don't forget:
Yes.
Right now we're at 2.4% other, so I think we're good.
Lee Jay
Rexgig0
Rexgig0 Veteran Member • Posts: 6,263
Most of my “fast” lenses were chosen primarily due to factors such as a “pro” build and the optical engineering. The wide maximum aperture, which enables a faster shutter speed, was/is a bonus.
In some cases, a faster shutter speed, in low light, was the primary goal, and the better build quality and optical engineering were bonuses.
Shallow depth of field was never a primary consideration. If I open an aperture wider than f/5.6, it is usually due to the need to let more light reach the sensor
By accident of availability, I learned to use Canon and Nikon DSLRs at the same time. I love specific lenses made by both Canon and Nikon, too much to quit either system. Dabbling with Leica-M is fun, too. I am, certainly, not an expert.
 Rexgig0's gear list:Rexgig0's gear list
Canon EOS 7D Mark II Canon EF 135mm F2L USM Canon EF 400mm f/5.6L USM Canon EF 100mm F2.8L Macro IS USM Nikon AF-S Micro-Nikkor 60mm F2.8G ED +43 more
Michael Fryd
Lee Jay wrote:
Michael Fryd wrote:
Mackiesback wrote:
Michael Fryd wrote:
Don't forget:
Yes.
The problem is that you don't know how many people chose not to respond because they didn't see their reason listed.
Suppose you get an even response with no more than 20 people selecting any one answer.  If there were 200 people who didn't answer, you don't have answers from over 70% of your audience, and that 70% is self selected to probably be those who would have selected "other".
The questions on the survey guide the responses.   One has to be very careful with designing the questions.   If you want to find out why people make decisions, you don't want to influence the results.  If you want to make a point, then you want to influence the results to support your position.
Here's a simple example of how words influence people, which is a better sale:
  • Up to 20% off on all items!
  • No more than 20% off on any item.
To most people, the former sounds like a better deal, but both say exactly the same thing.
Most Americans favor one of two political parties.  Let's call them "A" and "B".  Suppose there was a third party "C" favored by about 5%.
There's a big difference between the survey:
What party do you favor:
  • A
  • B
  • other
and
  • A
  • C
  • other
People are more likely to answer if they see their preference listed.  People who favor party "A" are likely to answer either survey.
People who favor "B" are more likely to answer the first survey, and not bother with the second.
Therefore the first survey should be used if you want a more accurate result.  The second should be used if your goal is to inflate the number of people who favor party "A".
Mark_A
Mark_A Forum Pro • Posts: 14,971
For low light and narrow dof
I have two f1.8 lenses, two f2.8 lenses, and one f4.5-5.4 lens.
I buy fast lenses for better low light abilities and to be able to get a narrower dof when I want it.
Mark_A
perrrob
perrrob Junior Member • Posts: 48
Re: For low light and narrow dof
Mark_A
Same here ... I also prefer a light photography kit (especially when on vacation).
As I'm just a hobbyist, all my "fast glass" are light primes (f/1.8G) and my zooms are lighter variable aperture lenses which I use in good light (ie. outside).
Whenever I go out, I always have at least my 2 essential lenses (16-85 zoom and 35 f/1.8 prime). I then add additional lenses according to what I might need that day.
 perrrob's gear list:perrrob's gear list
Nikon D7100 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S Nikkor 50mm f/1.8G +1 more
Reilly Diefenbach
Reilly Diefenbach Forum Pro • Posts: 13,482
5
Did buybuybuy just break wind in the forum and try to blame it on CnB?  PU!
 Reilly Diefenbach's gear list:Reilly Diefenbach's gear list
Nikon D500 Nikon D850
sportyaccordy Forum Pro • Posts: 15,148
Half and half. I use my standard zoom as a walk around so I like its IQ and ability to isolate subjects at the long end. Makes for an impromptu portrait lens. My 35 1.4 is my indoor lens so while the subject isolation is nice I mainly have it for light gathering.
Sometimes I take pictures with my gear- https://www.flickr.com/photos/41601371@N00/
 sportyaccordy's gear list:sportyaccordy's gear list
NEX-5T Sony a7R II Canon EOS 5D Mark IV Canon EF 24-85mm f/3.5-4.5 USM Sigma 70-200mm F2.8 EX DG Macro HSM II +6 more
