An old pic, but new technique; please grade for 3D effect
Started Jul 24, 2019 | Discussions
uuglypher
uuglypher Regular Member • Posts: 250
This image, converted with one of my older techniques, has been previously posted.
This time it was converted with a new algorithm and I would appreciate it if you would grade it by the usual scale:
a. no 3D effect
b. slight 3D effect
c. Moderate 3D effect
d. strong 3D effect
Many thanks,
Dave
uuglypher
"100% of the shots you don't take don't go in!"
Wayne Gretzky
Brian F Flint
Brian F Flint Regular Member • Posts: 184
Re: An old pic, but new technique; please grade for 3D effect
The top pair - parallel view
b. - slight 3d effect
The bottom pair - cross view
b. slight 3d effect
 Brian F Flint's gear list:Brian F Flint's gear list
Panasonic Lumix DMC-ZS60 Sony RX10 III Canon MP-E 65mm f/2.5 1-5x Macro
uuglypher
OP uuglypher Regular Member • Posts: 250
Thanks, Brian, for looking and responding.
I appr3ciate your input.
Dave
uuglypher
Wayne Gretzky
threed123
threed123 Senior Member • Posts: 1,490
b. slight 3d effect
Same here.
Steve Pruetz Senior Member • Posts: 1,076
b. slight 3d effect
Same here.
Me too.
Steve
 Steve Pruetz's gear list:Steve Pruetz's gear list
Pentax K-3
BenThomas1 New Member • Posts: 11
The 3D effect works because of a stereopsis principle. Each eye is in a different location and that’s why you see a slight difference in the image. The difference between both the images is what lets us look depth. This effect can be replicated with photography by capturing two pictures of the subject that are offset by the same distance. The two images are then viewed so that each eye views only the corresponding picture. Your brain puts the two images together as it does for normal vision and you see a single three-dimensional image.
