D810 key symbol continuously flashing on info screen
john49brown Regular Member • Posts: 214
For some reason the key symbol seems to be permanently displayed on the camera info screen. I cannot find any indication in the 810 manual on how to disable flashing symbol.
Anyone encounter this problem before, it does not appear to be interfering with any function but I would rather not see it f possible
JohnB
 john49brown's gear list:john49brown's gear list
Nikon D300 Samsung NX300 Fujifilm X-T1 Nikon D810 Fujifilm X-T3 +16 more
Nikon D810
xrdbear Veteran Member • Posts: 3,939
Re: D810 key symbol continuously flashing on info screen
I have no idea if this is right but is the lock engaged on the side of the SD card?
Brian
Sagittarius Veteran Member • Posts: 6,165
Which camera screen do you mean. Top LCD or back LCD when you press i button?
Best regards
 Sagittarius's gear list:Sagittarius's gear list
Nikon D810 Nikon D500 Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR +4 more
Schrodingers_cat Senior Member • Posts: 2,593
Try a Two Button Reset
That and reformatting the card are the only things that come to mind.
I just checked. If you have CF card and locked SD card inserted, the key symbol will flash on the rear LCD when info (i) button is pressed. If you have only locked SD card inserted, the word "Card", key symbol and (---) will be flashing on rear LCD when i button is pressed.
So yes, locked SD card is causing this problem.
Best regards
OP john49brown Regular Member • Posts: 214
Gentlemen one and all
You all nailed it, the culprit was the locking mechanism for the SD card which had moved when inserting card.
Thanks again everyone
JohnB
