100-400 L used lens
Started Jul 11, 2019 | Discussions
Leo_B
Leo_B Regular Member • Posts: 407
100-400 L used lens
Is this a good, bad, indifferent deal and should I think on it a while or not waste any time thinking about it?
Used Canon EF 100-400mm F4.5-5.6 L IS USM Zoom Lens, Excellent Condition$852.99
 Leo_B's gear list:Leo_B's gear list
Olympus E-M1 Olympus E-M5 II Olympus PEN-F Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 12mm 1:2 +5 more
ed rader Veteran Member • Posts: 9,068
Re: 100-400 L used lens
for the version 1 that's not a great deal.
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Depends on the actual condition, I.e. how reputable is the seller? And does it include the hood, case, and tripod ring?
KEH is very reputable, they currently list one in EX (Excellent) condition for $849 with 180 day warranty.
https://www.keh.com/shop/canon-ef-100-400mm-f-4-5-5-6l-is-usm-telephoto-zoom-lens.html
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
BlueRay2 Forum Pro • Posts: 14,816
i would definitely look at the condition to make sure it is not dinged and make sure it focus' ok! and then doing all that, ask for a reasonable discount
You miss 100 percent of the shots you didn't take!!! "Wayne Gretzky"
Andy01 Veteran Member • Posts: 5,191
If Australian $, not bad, but I would have thought pretty pricey for a used lens in US$.
I sold my original 100-400L (in Australia) in mint condition with hood, case, strap etc 2 years ago for the equivalent of US$840, so now 2 years on, I would have expected that price to drop a bit.
In addition to the points mentioned above, you should check for zoom creep - on the original lenses the rings that tighten up the zoom movement (to stop creep) wear out, and the lens will slip/creep no matter how tight you turn the tension ring. AFAIK, this can only be fixed by replacing the (felt?) rings inside, which a few years ago people (in the US) were reporting to cost around the $200-300 mark.
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
