a diy gimbal...
Started Jul 3, 2019 | Discussions
AndrewIsUsingTheNX1000 Forum Member • Posts: 60
a diy gimbal...
so,i've heard of the gimbal controller board and wanted to make a big badass gimbal for my own. the problem is...my intention is to load about 1 to 2.5 kg on the gimbal,like the crane plus,but i dont know what kind of motor i should buy.
with that payload,should i buy strong or weak motor? or..kinda big or small motor?
and where can i find it?im from vietnam,the source that i can buy import stuff is from lazada.
or if you folks dont have the specific links,maybe the motor's name or the voltage,motor dimensions or motor capacity may helps me find the best one.
and the material for the gimbal is maybe from plastic,or lightweight aluminium,any lightweight materials that i can find,in my country,but not carbon fiber,carbon fiber is too expensive for me.
for more details,im using a nx1000 with samsung 18-55,the combo is about 1.1 kg.
thanks.
 AndrewIsUsingTheNX1000's gear list:AndrewIsUsingTheNX1000's gear list
Samsung NX1000 Canon EOS 700D Sigma 70-300mm F4-5.6 DG Macro +2 more
Samsung NX1000
petrochemist Veteran Member • Posts: 3,619
Re: a diy gimbal...
You're clearly talking about a different kind of Gimbal than I've come across.
Gimbal heads don't use motors & generally take much heavier weights than 2.5kg.  The first one mentioned here is rated to 23kg...
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
OP AndrewIsUsingTheNX1000 Forum Member • Posts: 60
Re: a diy gimbal...
no not that one lol....i mean a video stabilizer...
i mean this
https://www.instructables.com/id/DSLR-Brushless-Gimbal/
yeah but i cant find that motor type,the one on hobbyking is already offsale,thats why i asked.
Bernard Delley Senior Member • Posts: 2,041
Re: a diy gimbal...
i mean this
take my professor's mantra: if you can buy it, buy it! it is cheaper than DIY.
here it is much more than a question of motors. The whole thing involves inertial sensors and a well designed electronic system to steer the actuators. If you know the inertia of the moving part, the frequency/amplitude spectrum of the movement to be compensated, then the actuator/motor minimum specs follow from a mechanical calculation. So the motor specs are the easy part. It is a long way from there to a working gimbal-stabilizer.
 Bernard Delley's gear list:Bernard Delley's gear list
Olympus TG-6 Nikon D7200 Nikon D500 Nikon D850 Nikon Z7 II +17 more
Re: a diy gimbal...
ah yes,thanks for your mantra...but i quit buying it anyway..it's not necessary for me anymore.....well thanks anyway!
