OP
Kevner
Contributing Member
Conclusion - 20mm Lens Rumble
I finally had a chance to bring this test to a conclusion (of sorts). Firstly, let me say that I have no illusions that these lenses would perform as well as a modern 20mm designed for use on the Sony filter stack. While these are all lenses that were designed over thirty years ago, I was pleasantly surprised by the results. Here is how the test comparisons were performed:
Close Focus/Resolution: This test is fairly self explanatory. I set up a typical close focus target (US $5 Bill) and established what the closest focus for each lens. Three shots for each lens, wide open, F8 and F11. These are typical aperture settings for the way I shoot. The set up probably affected the outcomes and I will use a standard distance setting for resolution rather than the close focus distance for each lens. The performance for the Mamiya SX 20mm also lends me to believe that the close focus distance for that lens was incorrect.
Vignetting: Vignetting was measured in the sky from the shots taken for the mid-range target for all three aperture settings. The wide open shots are hard compare as the four lenses do not share the same maximum aperture. As would be expected, the Mamiya SX performed best wide open. The performance at F8 and F11 is a truer comparison between the lenses.
Mid-Range Target: For the mid-range target I use a fence in my back yard. The camera is set up so that the center frame target is 10' from the camera and the fence oblique to the camera. Within the image frame, the fence in the left corner of the image is approximately 40' from the camera and the fence in the right corner of the image is approximately 6' from the camera. The image is compared in the center, mid-frame left, left and right corners. As the aperture is changed, each test point is compared using the target (fence) and similar points throughout the focal range.
Infinity Target: For the infinity target I used the horizon line on the opposite side of the valley I live in seen from my back yard. The camera is set up so that the center frame target is 5 miles from the camera and focused on the conical peak seen in the center frame. The image is compared in the center, mid-frame left, left and right corners. As the aperture is changed, each test point is compared using the target (conical peak) and set target points throughout the focal range.
Attached below are the excel charts indicating how these lenses performed in comparison to each other.
Close Focus
Mid-Range
Infinity Target
