DXO Prime vs. Topaz Denoise AI
Started Jun 28, 2019 | Discussions
Sagittarius Veteran Member • Posts: 8,140
ISO 51200. Same image has been processed in DXO PL prime and Topaz Denoise AI. Which one do you think is better #1 or #2?
Best regards
 Sagittarius's gear list:Sagittarius's gear list
Nikon Z6 II Nikon Z7 II Nikon Z 14-30mm F4 Nikon Z 24-200mm F4-6.3 VR Nikon Z 100-400mm +1 more
stormyboy Contributing Member • Posts: 967
Question about your skills with the programs:
19
Can we assume that you have fiddled with all the possible adjustments enough to truly understand them, and have arrived at each version being the absolutely best version you can possibly make it? If not this is pretty meaningless and we would be better served if you uploaded your raw file so everyone could experiment. I'm sorry to be negative, but these sort of comparisons are so open to variable changes that I don't have much faith in them.
NAwlins Contrarian Veteran Member • Posts: 7,057
Different raw conversions, settings issues, and taste / trade-offs
10
I realize these sorts of comparisons are difficult to do well, but there's an overarching issue that the two images are just different in ways that can and probably will affect the appearance of noise:
* Image 2 is noticeably brighter than image 1.
* Image 2 is noticeably more saturated and/or shifted toward red compared to image 1.
* The sharpening differs between the two. Overall image 2 appears maybe more sharpened. To some extent this is a matter of taste, and upon brief review I'm not prepared to say either is clearly better-sharpened than the other, but in USM terms the radius / amount / threshold settings appear different.
Also, the results you get depend heavily on how you set the noise reduction controls. I presume (but don't know) that Topaz Denoise AI is similar, but with DxO PhotoLab Elite's Prime noise reduction, there are five different controls (Luminance, Chrominance, Low frequency, Dead pixels, and Maze). Personally I find I can usually produce results much more subjectively pleasing to me by changing the settings from the defaults--often changing them a good bit.
With those caveats and FWIW, my opinions of your tests:
* Image 1 has more coarse / low-frequency noise.
* Image 2 has more fine / high-frequency noise.
* Overall, subjectively, I think I prefer image 2, but that's mostly due to the distracting noise in the air / shadows in image 1, and image 1 is arguably more pleasing in the detailed image areas. Also, I think I might well change preferences based on magnification / print size.
But I might well reach different conclusions if given the opportunity to change the controls and settings. I know with DxO they make a huge difference, and I suspect with Topaz they do too.
 NAwlins Contrarian's gear list:NAwlins Contrarian's gear list
Nikon Coolpix S30 Canon PowerShot S120 Sony Alpha DSLR-A580 Tamron SP AF 90mm F/2.8 Di Macro Tamron SP 70-300mm F/4-5.6 Di USD +5 more
tokumeino Veteran Member • Posts: 3,086
Re: DXO Prime vs. Topaz Denoise AI
#2 without question. I didn't even look a the full size image : the thumbnails is enough to judge.
Note that I'm not sure whether it can help to qualify a SW among the other, since many thing rely on parameters.
jan pawlak Contributing Member • Posts: 702
No 1.
No. 1 has lower (normal) saturation, more details and is sharper
 jan pawlak's gear list:jan pawlak's gear list
Sony FE 24mm F1.4 GM Sony a7R III Sony FE 55mm F1.8 Sony FE 70-200mm F2.8 GM OSS Sony FE 16-35mm F2.8 +1 more
Digital Nigel Forum Pro • Posts: 15,818
7
I've done similar tests, and shown the results here. Denoise alone produced strange results, and using Denoise AI directly on a RAW image is a bad idea.
I came to the conclusion that PRIME was much better for day to day use, but the occasional high ISO image benefited from being processed from RAW with PRIME, and then having Denoise AI applied. That's a tedious process, so only worth doing for the few images that really need it.
Here's an example:
https://www.flickr.com/photos/recliner/albums/72157708128725115
Someone else commented that Denoise AI was a useful way of 'polishing' very noisy images that had first been processed with PRIME. I think that's a good way of describing it, and that's what I now do.
 Digital Nigel's gear list:Digital Nigel's gear list
Panasonic FZ1000 Canon PowerShot G7 X Nikon Coolpix P900 Panasonic ZS100 Sony RX10 III +19 more
Ernie Misner
Ernie Misner Veteran Member • Posts: 8,618
Here's an example:
I agree with your results and thanks for the flickr link!
Ernie Misner
http://www.flickr.com/photos/erniemisner/
"I bet we'll find hints of extraterrestrial life before 2030" - Jamie Shreeve, Popular Science
 Ernie Misner's gear list:Ernie Misner's gear list
Nikon Z6 Nikon Z7 II Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm F1.4G Nikon AF-S Nikkor 70-200mm F4G ED VR +5 more
David5833 Senior Member • Posts: 2,252
Photo 2 looks much better to me, no blobs or smearing of details.
 David5833's gear list:David5833's gear list
Canon G9 X II Olympus OM-D E-M10 II Olympus E-M5 III Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +5 more
Re: Different raw conversions, settings issues, and taste / trade-offs
NAwlins Contrarian wrote:
I<snip>
No, the controls are completely different in the Topaz AI products. Fundamentally, you are letting the AI system choose the method to apply, based on its training on many other noisy and noise-reduced images. In effect, it tries to produce the same effect as the best 'fixed' images it was trained on. For that reason, the results are very unpredictable, both from image to image, and even in different parts of the image.
These are the controls:
Topaz DeNoise AI controls
OP Sagittarius Veteran Member • Posts: 8,140
The same image has been sent from LR to both SW. #1 is by Topaz, #2 is by DXO PL1.
Best regards
sobrien
sobrien Senior Member • Posts: 1,729
#2 looks clearly better to me. Very good detail/noise ratio.
#1 has that smudgy look you get when NR is cranked up too high, IMO.
"The simple things are also the most extraordinary things and only the wise can see them."
https://www.flickr.com/photos/135843555@N03/
 sobrien's gear list:sobrien's gear list
Canon EOS R Canon EOS R5 Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM Canon Extender EF 2x III +16 more
What value was the "remove noise" slider set to in Topaz AI?
Okay, but it looks like even with Topaz Denoise AI, the user still can (and probably should) adjust / balance / make subjective judgments about the best relationship among control settings for noise, sharpness, and details--right?
So not the current DxO Prime?
If I understand correctly, you used DxO PhotoLab 1, which was replaced by PhotoLab 2 eight months ago. DxO claims to have improved Prime noise reduction between PL1 and PL2; how much and how, I don't know. But it seems like that's another methodological issue.
jan pawlak wrote:
No 1.
Why even looking at details ? Isn't it obvious that all the background suffers a very heavy cotton pattern ?
Yes, very much so. Maybe the AI will get good enough one day to pick its own optimum settings?
I just use trial and error, which can be rather a tedious process, given the very slow processing speeds even on my very fast workstation. It's hard to become expert in the software, given my infrequent use of it, and the big changes in each new release.  It feels almost like you're participating in an experiment.
Lan Veteran Member • Posts: 3,557
I have a strong preference for #2, the most obvious difference is some really nasty wide chroma blotching in #1 which is visible even at thumbnail size, but there's also more detail in #2 when viewed at 100%.
Did you look at the picture before zooming 2:1 ? The background is full of huge 'cotton' artifacts. How can people miss that ? Are you using a camera or a microscope ?
You mean the first thing I mentioned about the images
Sorry, I've indeed not read past "I have a strong preference for #2". The thing is : blotching appears in #2, not #1. Didn't you mix the numbers ?
