How to fix NX Mini Error 00 with 9mm lens?
Started Jun 27, 2019 | Questions
cellofellow New Member • Posts: 2
I've only had this NX Mini a few days. I just today encountered the Error 00 on my NX mini when using the 9mm f/3.5 lens. It still works with a lens mounted via an LTM->NX-M adapter.
I've tried cleaning the lens contacts without luck. I found new firmware on a site posted by vatazhka https://samsungnx.herokuapp.com/check?product=XM1404. Description in the firmware says that it will fix Error 00 problems; but I cannot install the firmware because I've been getting Error 00.
Is there anything else I could do?
Samsung NX mini
Kinger
Kinger Contributing Member • Posts: 549
Re: How to fix NX Mini Error 00 with 9mm lens?
What happens if you install the lens with the camera already powered on? Still get stuck lens 00 error?
did you try gently forcing the portion of the lens that extends while you power the lens on?
Maybe try upgrading in camera body firmware first, maybe that will help and allow you to then install the lens firmware update.
just some suggestions. Good luck.
 Kinger's gear list:Kinger's gear list
Canon EOS M5 Canon EOS M200 Canon EF-M 22mm f/2 STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 10-18mm F4.5–5.6 IS STM +3 more
OP cellofellow New Member • Posts: 2
I have tried attaching while already powered on, and have updated the body firmware.
I'll see if I can make the lens extend. I may need some tips on how to accomplish that though.
