Photo-manipulations vs. photography
Started 5 months ago | Polls
Laybourne
Laybourne Forum Member • Posts: 57
On DPR's homepage, there's a story about how 500px has drawn a distinction between what it sees as photography and what it considers a photo manipulation.
But is the line between the two really as cut and dry as they make it out to be?
What do you think?
POLL
Yes, it is
26.0% 20  votes
No, there is some gray area.
74.0% 57  votes
  Show results
J A C S
J A C S Forum Pro • Posts: 15,072
Re: Photo-manipulations vs. photography
There is no clear line but this does not mean that there is no distinction at all.
mamallama
mamallama Forum Pro • Posts: 56,305
5
Photo manipulations imply distorting reality which is not photography. Things like blue screening and cutting objects out of a scene are distortions of reality and thus not photography.
 mamallama's gear list:mamallama's gear list
Panasonic Lumix DMC-GX85 +1 more
yardcoyote Forum Pro • Posts: 12,096
I know exactly where I put the line in my own work.
Otherwise (and generally speaking), if I can see the manipulation, then i call it "digital art based on a photograph or several photographs", not photography. And yes, that includes HDR if the effect is dramatic enough that I can see it.
Digital art is not a bad thing by any means, but it is its own thing.
 yardcoyote's gear list:yardcoyote's gear list
Fujifilm X10 Fujifilm X100T Fujifilm X-Pro1 Pentax K-5 IIs Fujifilm X-M1 +18 more
teejaywhy
teejaywhy Regular Member • Posts: 271
I can't define it, but I know it when I see it.
 teejaywhy's gear list:teejaywhy's gear list
Nikon D750 Olympus PEN-F Panasonic G85
Sara Valentine Contributing Member • Posts: 893
Perhaps in this specific instance.
What do you think?
The problem is 500px hasn't clarified to what extent a photograph can be manipulated (seems like copyright is the actual issue). Would the artist in question have been reprimanded had they held the copyrights to all the base image content to produce the final images?
Images also don't have to be as abstract to be manipulated either, a problem prevalent in journalism: https://www.niemanlab.org/2019/06/can-you-spot-a-fake-photo-online-your-level-of-experience-online-matters-a-lot-more-than-contextual-clues/.
Jake2046
Jake2046 Regular Member • Posts: 241
my question is does Karcz even own a camera?
Seemed like all his works are borrowed images from someone else.
Don Lacy
Don Lacy Senior Member • Posts: 2,064
8
So if I do say a Humming bird set up were I use a flower that I placed sugar water in then place a artificial back ground behind it and use six flashes to light everything it’s not a photograph according to your definition. So I guess my sons school pictures are not photographs either. I am confused when did the definition change and who changed it.
 Don Lacy's gear list:Don Lacy's gear list
Canon EOS-1D Mark III Canon EOS 6D Canon EOS 5D Mark IV Canon EOS M100 Canon EF 50mm F1.8 II +11 more
robgendreau Veteran Member • Posts: 6,151
What do you think?
Yes, that does seem to be the problem. The note from 500px said it was going to be "a purely photography website." Rather vague, and somewhat ungrammatical. No stacking? no composites, of say milky way with foreground taken at the same time and spot?
But I suspect they just wanted his images off there, maybe because someone complained he sampled their shot.
“Art is not what you see, but what you make others see.”
— Edgar Degas
 robgendreau's gear list:robgendreau's gear list
Pentax K-1 II Pentax FA* 50mm F1.4 SDM AW
sybersitizen Forum Pro • Posts: 14,118
5
Manipulation is a part of the photographic process. On a basic level it can begin as soon as a photographer chooses what to include in a composition or exclude, and it can continue in many directions from there.
mamallama
I think photo-manipulation of the OP is different from the manipulation you are talking about that includes choosing a composition.
misterodd
misterodd Senior Member • Posts: 1,284
It's grey.  It always is.  The problem is one of language.  A problem of signification.
There are others problems here, as well.  But fundamentally, this is a linguistic problem and it's inescapable.
Box Man
 misterodd's gear list:misterodd's gear list
Nikon 1 V1 Nikon 1 J2 Nikon 1 V2 Nikon 1 J3 Nikon 1 V3 +14 more
Yes, it's different. There can be a progression from minimal manipulation to obvious, rampant manipulation, and people have been known to raise personal objections to manipulation almost anywhere along that progression.
Hello123
Hello123 Senior Member • Posts: 1,320
What do you think?
Can this be narrowed down to something as simple as documentation versus artistic expression?
misterodd
I completely understanding your line of thought and it's a fair definition relatively consistent with the opinions of many individuals and groups, photographers and non-photographers, alike.
In a broader sense, perhaps a socio-philosophical sense, however, even "photography" is inherently "manipulative" as it provides no context, especially historical context.  In the case where images are used for purposes outside the aesthetic realm, an image, whether it be a overtly engineered or left alone, possesses the potential to serve ideological purposes, particularly, if this is the very intention of either the photographer or the editor or the medium, etc.
Without context, there is little meaning; coherent understanding can only be derived contextually.  Since an image is frozen in space and time, we have to be careful judges.
An image is one signifier among an inexhaustible many and can fall prey to the machinations of those who do not use photography to enlighten or edify or inspire others.
Box Man
mamallama
Only on a dpr forum are there arguments about the definitions of very simple fundamental things:
Dictionary definition:
Photograph: representing nature and human beings with exactness.
Both of your examples fit the above definition of a photograph.
J A C S
This is the MW definition of photographic, not photography; it is incomplete (it should end with "of a photograph"); and it is one of the three. The definition of photograph is different.
Don Lacy
6
Both of my examples distorted reality or more important show a false reality so my question is why in the process of of making an image does it matter when I distort reality.  If I do it before I press the shutter it’s a photograph after I press the shutter in a editing program it no longer is a photograph one of the problems I have with that is when it was done in a dark room it was still considered a photograph.  So why have the rules changed if I did a double exposure using film it’s a photograph if I combine two I’mages in PS it’s no longer a photograph.
MisterBG Veteran Member • Posts: 6,755
So do you believe the camera never lies?
In fact the camera rarely tells the truth.
 MisterBG's gear list:MisterBG's gear list
Sony RX100 Sony a6000 Olympus PEN-F Canon EOS 80D Canon EOS 5D Mark IV +14 more
