Mitakon 35mm f/0.95 wide open in daylight... Electronic Shutter or ND filter?
akin_t Veteran Member • Posts: 3,320
I honestly keep forgetting about the electronic shutter on Fuji cameras.
Is there any reason to use an ND filter over the electronic shutter to nail exposure with this wide open on sunny days?
 akin_t's gear list:akin_t's gear list
Fujifilm X-E1 Fujifilm X-T2 Fujifilm X-E3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +4 more
Sjak
Sjak Senior Member • Posts: 4,517
Re: Mitakon 35mm f/0.95 wide open in daylight... Electronic Shutter or ND filter?
If you shoot moving subjects, then the mechanical shutter is recommended, and that may require the ND-filter sometimes. Otherwise, the electronic shutter is fine.
My shutter is usually set to MS+ES. For moving stuff, full aperture on a fast lens is not the way to achieve reliable focus anyway
 Sjak's gear list:Sjak's gear list
Ricoh Caplio GX100 Sigma DP2 Sony Cyber-shot DSC-F717 Panasonic Lumix DMC-LX7 Pentax K100D +3 more
JayPhizzt Senior Member • Posts: 1,031
I don't think there are many people that shoot moving subjects with manual lenses... Maybe for slow moving subjects, but then rolling shutter probably won't be much of a problem anyway.
I have a Mitakon 35/0.95 and I just use the electronic shutter when needed.
 JayPhizzt's gear list:JayPhizzt's gear list
Fujifilm X-T3 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 80mm F2.8 Macro +1 more
Sjak
Why not? It's often easy to anticipate when and where a target will be. Recently, there was e.g. a post about someone experiencing issues with AF on kids on a swing; with MF, that is very easy. Or panning: with MF, there is no chance the system will suddenly decide to focus on something in the background instead.
CeeDave
CeeDave Senior Member • Posts: 1,390
I agree, this works for me, even with the Rokinon 135/2 for street performers (and that lens has very shallow DOF with its 67.5 mm entrance pupil, compared to 36.8 mm for the 35/0.95.
E-shutter is a good thing to have as a backstop on bright days with fast lenses, and often gives me shots with no objectionable artifacts. At least on the T1, ES cannot be used with tracking continuous AF, by the way.
Musician on Royal Street, New Orleans. EXIF is wrong (forgot to set it in menu, doh!)—this is the Rokinon 135/2 at f/2 and 1/5400 s, electronic shutter. She moved quickly, but predictably (and in a limited range).
Chris
A couple of Fuji cameras and assorted X-mount and adapted primes
alekt449 Regular Member • Posts: 114
Electronic shutter changes the bokeh which the lens produces. If bokeh is your primary objective try testing side by side if it is relevant for you. Here explained
Truman Prevatt
Truman Prevatt Veteran Member • Posts: 9,167
Interesting.  The electronic shutter implementation we have today is really a scanning shutter - instead of a true electronic implementation of a shutter.  I steer away from purely electronic shutters unless absolutely necessary.  I would much prefer slap a ND filter on than use an electronic shutter.
The EFC is pretty much the sweet spot for below 1/2000s  with the H1 and T3.
When the chip makers can prefect the readout technology for for a global shutter (and keep the read noise in check) then the mechanical and current implementation of the electronic shutter will be obsolete. But until then - I will keep the shutter speed less than 1/8000s and use the mechanical shutter and on my H1 use EFC at 1/2000s and use the mechanical shutter from 1/2000 to 1/8000.
Truman
www.pbase.com/tprevatt
 Truman Prevatt's gear list:Truman Prevatt's gear list
Fujifilm X-Pro2 Fujifilm X-H1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +9 more
OP akin_t Veteran Member • Posts: 3,320
Thanks for pointing that out, yes that definitely was my use case.
I do wonder why this is the case though, maybe it's because we don't have a true global shutter. Either way, I wonder whether it's worth the price of an ND filter, I'll conduct some tests and see what I notice.
CeeDave
Interesting. I haven’t noticed this on my X-T1 with manual lenses, and can’t reproduce it, either.
Maybe it is related to how a camera manipulates the aperture at the time of exposure, which it can only do for lenses that communicate with the camera? I can’t see how shutter speed or type *per se* could have any effect on blur. Anyone have an explanation?
(Also, it shouldn’t affect exposure...this really looks like either a hardware problem in automated aperture control, or a firmware/software problem in the e-shutter control. I’m not persuaded that it is inevitable with ES, but I’m open to a persuasive explanation.)
Chris
It's a mystery isn't it? I know how an electronic shutter works, so to me I can understand the difference in exposure but definitely not the difference in out of focus areas (which is purely a function of lens opening).
In any case, I will run some tests with both the Zeiss 32mm and the MItakon 35mm and see what happens.
SigmaChrome Forum Pro • Posts: 11,185
It really depends of whether you want to capture movement or freeze it. If you want a slow shutter speed then, yes, you need an ND filter.
Vitée
Capture all the light and colour!
http://www.pbase.com/vitee/galleries
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sony RX100 Sigma DP3 Merrill Sigma dp0 Quattro +31 more
yukosteel
yukosteel Regular Member • Posts: 101
Mitakon 35mm F0.95 version II is one of my most used lens on Fuji-X for more than 3 years. 95% of time I'm using electronic shutter. In my personal shooting cases I never needed a ND filter.
 yukosteel's gear list:yukosteel's gear list
Fujifilm XF 100-400mm F4.5-5.6 OIS WR 7artisans 35mm F1.2 7artisans 7.5mm F2.8 Fisheye Fujifilm X-E2S Fujifilm X-T30 +4 more
Sjak
Excellent shot, well done!!
