Things still missing in M1MarkII firmware3.0 and M1X
Started Jun 23, 2019 | Discussions
duncanmcl Forum Member • Posts: 62
I am also using cameras like Panasonic GH4, GH5s and I am comparing them with M1 Mark II and M1X. The new firmware has lots of improvements, but there are still missing things that I want. These are some of the missing things and problems that I saw in Olympus M1 Mark II firmware3.0 and also M1X
1) Maximum Auto ISO is limited to 6400. Panasonic cameras go to 25600. I know that ISO over 6400 is extended ISO, but it eliminates the post-processing to brighten the photo afterwards.
2) When IS is disabled due to accidentally pushing the IS button on the lens, it is difficult to notice on the screen of M1 Mark II and M1X. The camera doesn't show any notification on the screen when IS is disabled. Panasonic cameras show a big red IS disabled warning so it is easy to notice and fix.
3) It is not possible to use the camera for a long time in a hot environment. The camera is closing itself. In the same hot environment a Panasonic GH4 camera continued working without any problems. Therefore I threw M1 Mark II back to my bag and did the photo session with Panasonic GH4.
4) Olympus share app is slow to access the photos in the camera. Scrolling is very slow in the app.
5) Although there is some improvement with this firmware, continuous AF under very low light is still worse than a good SLR. M1 Mark II could not acquire focus in very low light situations where an SLR acquired focus.
6) I could not find a way to enter the main menu when the shutter is in the bulb mode.
7) The live view looks soft on the screen, which makes it difficult to find out if the focus is correct or not. The screen of Panasonic cameras is sharper, so it is easier to identify sharp and blurry areas on the screen.
8) The mode dial has a slow response. It takes time to set the new mode after turning the dial.
9) In the index display mode (thumbnails) of the photo playback menu, there is no slider menu. It takes a long time move to a photo if there are thousands of photos between the requested photo and the currently displayed photo. Panasonic cameras have a touch slider menu in the playback menu, so it is easy to skip thousand of photos with a single touch to the slider.
10) Panasonic cameras show a "focus mode lever" for MF Assist on screen. However, M1 Mark II and M1X don't show a lever on the screen. When working in darkness at night with Panasonic cameras it is possible to follow the MF distance by looking at the lever on the screen while changing the MF distance. In Olympus cameras, it is necessary to look at the markings on the lens that is very difficult to see when working in a dark environment.
11) On page 46, the manual of M1 Mark II says "When you are using Sequential Low or Pro Capture Low, live view is displayed. When you are using Sequential High or Pro Capture High, the image shot immediately before is displayed". I would like to have an option to display "the image shot immediately before" when also using Sequential Low or Pro Capture Low. It is very useful for Flash photography, because the photo taken with flash is very different from what you see on live view, so it allows you to see the effect of flash in real time during a long sequential shot with flash. Panasonic GH4 has this functionality as it shows the "the image shot immediately before" in the sequential low mode.
Not firmware related but there are also some hardware related problems that I would like be fixed in the successor models:
1) The tripod hole under the camera is not at the center of the base. It is too close to the edge. Therefore, the camera is not so stable unless the tripod plate is big enough to cover the bottom of camera grip.
2) The screen quality like color display, black level is worse than Panasonic cameras. Even old Panasonic models like GH4 have better screen.
Panasonic GH5S Panasonic Lumix DMC-GH4
bofo777 Senior Member • Posts: 2,267
Re: Things still missing in M1MarkII firmware3.0 and M1X
6
Wow I didn't know my camera was SO BAD
 bofo777's gear list:bofo777's gear list
Olympus E-1 Olympus E-M1 Olympus E-M1 II Olympus E-M1 III Fujifilm GFX 100S +17 more
String
String Senior Member • Posts: 2,242
19
Kinda sounds like you should be using Panasonic rather than Olympus as it has most of the things you want.
 String's gear list:String's gear list
Olympus E-M1 Olympus E-M1 II Olympus Zuiko Digital 1.4x Teleconverter EC-14 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 75mm F1.8 +4 more
Photo Pete Veteran Member • Posts: 5,430
16
If you are shooting above 6400 on m43 you would be far better off editing in post.
If you are unable to notice that IS is not active without notifications cluttering up your screen then there is something seriously wrong,
Never experienced this, so I certainly don’t find it a problem.
No problem with this. Maybe you have a poor phone?
which SLR? The mkii is better in low light AF thsn either my D800 or D3s were... and thanks to the EVF I can actually see what I am focussing on,
I tend to just press the menu button twice. Works perfectly for me,
Checking sharpness on any screen by just looking at it is daft. That is what the focus assist aids are for.
I don’t find this at all. Less than 0.5 secs
You can scroll quickly using the touchscreen just like using a smartphone.
Not sure what you mean here? Don’t you use liveviee boost with focus peaking?
Just turn image review on
completely bemused by this.
OK. Not the most contrasty screen, but refresh rate and response time is good.
That is a very long list of features which I have no desire to be incorporated into my EM1 mkii and of issues which have never been a problem during several years of shooting with it.
I am particularly bemused by your tripod hole comment given that stability will generally depend upon which lens is mounted on the camera and that anyone who is serious about tripod work will be using a reasonably sized tripod plate anyway.
I guess that, as others have suggested, if you prefer the specific features of a Panasonic camera then you were rather misguided to purchase an Olympus.
Have Fun
Photo Pete
AlwaysLearning4 Regular Member • Posts: 256
I happen not to have some of the requests that you do and am still getting used to 3.0.
Things that I really wish Olympus would add to the 1.2 or at the very least, EM1 Mark III is:
  • Ability to tie face detection to focus point so I can select which face to focus on in a crowd.
  • Ability to use the camera while connected to my phone
  • Combine all Wi-Fi related settings to one menu location. Turning the wifi on and connecting is far apart in the menu and to save battery life I have to initiate both when I want to share something.
  • Streamline the whole sharing process. It needs some work.
That doesn't take away from how happy I am with firmware 3.0. I feel in many ways like I have a new camera. The drastically improved video AF, ability to select multiple images much faster, EC in manual mode, improved AF-C... These are practical improvements that will make my life easier on a daily basis.
 AlwaysLearning4's gear list:AlwaysLearning4's gear list
Olympus OM-D E-M10 Olympus E-M1 II Olympus M.Zuiko Digital ED 75mm F1.8 Voigtlander Nokton 42.5mm F0.95 Olympus 12-40mm F2.8 Pro +3 more
OP duncanmcl Forum Member • Posts: 62
No, I don't need to.
No, there is nothing wrong.
Galaxy S9 is fast.
I don't need those focus aids on Panasonic. Olympus can do learn from Panasonic.
Slow for me.
No. When there are thousands of photos, scrolling takes a long time by finder.
No. Turning on image review on just shows the last photo taken after sequential shooting is over. Panasonic allows reviewing all the photos while the sequential shooting continues. It makes a difference when using a flash.
I should use a special small tripod with a small and light tray carrying cameras. My Panasonic camera is stable on it but Olympus is not so stable.
Yes, refresh rate and response time is good.
If you do not need these features, it does not mean that nobody should use or ask for them. You should respect other people's requests.
No. Olympus has big advantages over Panasonic like Phase detection AF. I need them so, I am using Olympus. However there are some specific functions that Olympus can learn from Panasonic and add to their cameras for some specific shooting situations.
brianric Veteran Member • Posts: 8,980
8
Really? You did mention this is about E-M1X. I just got finished doing a six-hour shoot. taking 23,000 pictures in mid 80ies with absolutely no problems.
 brianric's gear list:brianric's gear list
Sony RX100 Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GX8 Sony a6400 Sony a9 II +6 more
Sorry, I forgot to write the model there. I saw the that problem with M1 Mark II. Therefore I said "I threw M1 Mark II back to my bag and did the photo session with Panasonic GH4". I didn't try M1X under hot weather.
gary0319
gary0319 Forum Pro • Posts: 10,540
“Looking a gift horse in the mouth” comes to mind (nt)
11
No text.
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
Jorginho Forum Pro • Posts: 15,370
Agree with nr 10: why no indication on screen of infinity.
I missed it when shooting NLCs….It is very strange but indeed my H4 shows both on screen what is sharp and what not when doing MF and it shows how close to infinity youare. Which is very nice for this kind of work. But the Oly...does not...
 Jorginho's gear list:Jorginho's gear list
Olympus PEN E-PL5 Panasonic Lumix DMC-GH4 Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH +8 more
If you saw my post two years ago  (https://www.dpreview.com/forums/post/59696906) you would have known that. The main reason why I bought theE-M1X was due to the built in heat sink.
I read the post now. Yes, I had the same experience. I hope M1 Mark III won't have this problem.
No, I don't think that it is a bad camera. It is very good for most people. However there are some things that Olympus can learn from Panasonic and add to their cameras for some specific shooting situations. Not everybody needs them.
10
I have no need for these features. I have no need for another bit of information cluttering up my evf to show me whether IS is engaged, which is perfectly visible in the viewfinder anyway. I have no need for auto iso to cover the extended ISO range because I will get better results without it. I have no need for another display of a focus scale in the evf when I am trying to concentrate on the image. I have no need for turning off live view between frames, which will ruin my ability to predict and capture the moment..
I can enter the menu in bulb mode already.
I certainly have no need to see these items adding as options to an already complex menu system.
I agree that you should respect other people’s requests... nothing wrong with that. The point I was making is that you had done exactly the opposite of that by presuming that other people want those features and that they were consequently ‘missing’.
It also seems rather ungracious to criticise what is an excellent, free, firmware update to a 3 year old camera by criticising it for not adding in a few rather dubious features that not everyone wants.
Have Fun
Photo Pete
(unknown member) Forum Pro • Posts: 19,317
i stopped reading as soon as you said the camera over heated . troll.
Don
Olympus EM5mk2 ,EM1mk2
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1 em5mk1
Kiwisnap Senior Member • Posts: 1,557
Point (3) cannot be fixed in firmware.
Fsi Senior Member • Posts: 1,276
Get a G9, it's an E-M1 alternative option.
 Fsi's gear list:Fsi's gear list
Sony a1 Olympus 25mm F1.2 Panasonic Leica 200mm F2.8 Sigma 85mm F1.4 DG GN Canon G5 X II +4 more
AussiePhil Contributing Member • Posts: 691
More like - I'd really like these things from the panasonic cameras
They are missing things I want, but honestly you say it further down that you use Oly cameras because the GH's are missing something essential for you so it's a bit rough to paint the picture you do.
Strange you talk about needing this for video later in your whine.... if you really need more than 6400 on a constant basis then you either have the wrong lenses or the wrong system, besides you can enable extended ISO up to 25600 anyway.
how hard is it to check the button before you shot...... i don't need some big red IS disabled warning... you do realise people turn IS off for genuine reasons and don't want to be bugged by a warning symbol ....
Even Brian half debunked this.... how hot? sun shining? how long? no qualifiers so the statement has no meaning. a mk2 will run for hours in ambients well over 40c but add some heating from the sun and drive the camera temp even higher then it will give you an over heat warning that still gives you a chance to cool it down, if you fail to do that then it will shutdown...
Bit different to your claimed experience
Agreed it can be slow
Seriously..... this is just trolling... if you had even tried to relate it to your GH experience it might have been less so.
Others' say it can be so, haven't tried
Well good for them but that is hardware not software ... or is that confusing
You switch modes so often and quickly that you need instant response? seriously dude this is at the picky picky stupid end of the spectrum. provide a valid use case
who, in their right mind, decides they need to go back thousands of images in camera. only the phone generation seems to want this sort of function.
i can see a use for this, but i find focus peaking does the job really well so question how it is a benefit. maybe other Pany users can eleborate.
Don't want this at all, keep it, SeqL is like it is so you can follow the action effectively. I would expect and hope that as an expert in using flash with Seq shooting that you already have the exposure correct and don't need to check it every frame......
really? i read your response about needing to use a small tripod... well that's your issue pretty damn stable on a standard QR plate.
Cheers and best wishes
Phil
Galleries at
https://www.flickr.com/photos/byphilg/
 AussiePhil's gear list:AussiePhil's gear list
Olympus E-M1 Olympus OM-D E-M1X OM-1 OM System OM-5 Olympus 40-150mm F2.8 Pro +4 more
(unknown member) Forum Member • Posts: 78
Thank you!
That's a great compilation of possible improvements to the EM1-II that I'm sure discerning prospective buyers would appreciate!
