Fuji XF 90 f2 Dust issues
Started Jun 21, 2019 | Discussions
rsongusa New Member • Posts: 9
I have the Fuji XF 90 f2.  I also own the XF10-24, XF 23 and XF 16.  The XF 90 has a sheen of dust just under the front element.  I have not encountered that problem with any of my other lenses.  My questions are:
1. has anyone else encountered this issue?
2. how have you addressed it?
 rsongusa's gear list:rsongusa's gear list
Sony RX100 Ricoh GR II Sony RX1R II Fujifilm X100F Canon EOS 6D +15 more
Justin9999 Contributing Member • Posts: 725
Re: Fuji XF 90 f2 Dust issues
Being careful not to hurt your eye, shine a flashlight through your lenses from the rear side.
They all have a surprising amount of dust.  You might just be able to see it more easily on the 90 [without the flashlight].
Assume you know a lot more than me and teach me at will.
 Justin9999's gear list:Justin9999's gear list
Fujifilm X-E2S Fujifilm X-H1 Fujifilm XF 14mm F2.8 R Fujifilm XF 27mm F2.8 Fujifilm 16-55mm F2.8R LM WR +3 more
ikaika777
ikaika777 Senior Member • Posts: 2,632
Unless it’s affecting your pictures do absolutely nothing and enjoy your lens. πŸ‘πŸ»
After all is said and done and your photo is hanging on the wall, no one is going to know or care what camera, lens, or what post processing you used. All they care about is if the image moves them.
 ikaika777's gear list:ikaika777's gear list
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 16mm F1.4 R WR +18 more
Ed B
Ed B Forum Pro • Posts: 12,575
Not my lenses.
afwares Regular Member • Posts: 150
This is my mindset.   As long as my photos are clean, I don't care what's in there.   Too many battles to fight in life...can't bother with that one.
Along same lines, my wife once badly scratched the center of the lens on an X30 I used to have.   When she showed me, my first thought was "I'm going to have to Photoshop that out of every photo I ever take with this camera from now on".   But as big as the blemish was, it never showed in any photo so it became a non-issue.  That's how I feel about dust...if I can't see it in photos, I don't care.
 afwares's gear list:afwares's gear list
Fujifilm X30 Pentax K100D Fujifilm X-T20 Tamron AF 70-300mm F/4-5.6 Di LD Macro Fujifilm XF 18mm F2 R +3 more
Ed B
A scratch on the lens front element probably won't affect an image but dust inside the lens could affect image contrast.
Naturally, depending on the amount of dust, most people may not notice the loss of contrast but take an identical picture with a clean lens and the difference is obvious.
Where the dust is located also has a lot to do with how it affects an image.
Yes, absolutely agree. There are "who cares" levels of particulate and then there are "this isn't working properly" levels. You have to know the difference.
MFiftysomething Senior Member • Posts: 1,075
Mine has had dust since new but does not show on photos
 MFiftysomething's gear list:MFiftysomething's gear list
Sony RX100 V Fujifilm X100V Sony a7C Fujifilm X-E4 Sony a7 IV
OP rsongusa New Member • Posts: 9
You are all right, of course.  I do not notice any of the dust in any pictures I have taken.  My only concern was how to stop the dust from entering the lens.
