(unknown member)
Re: You get same DOF....
C Sean wrote:
However, if I wanted to say photograph a group of people, not only would I say use the 15mm 1.7 (depending on the size of the group) but I would also close the lens down to F5.6 or F4.0.
Yes, that depends from the size of the magnification that how much you need to stop down.
If you double or half the focal length, you need to double or half the distance to the subject to get the same framing as with the previous focal length, examples:
- if you take a shot with 25mm from a 3 meters and you move to 6 meters, you now need a 50mm to get the same framing.
- If you take the shot from 5 meters with 100mm and you move to 2.5 meters, now you can use 50mm to get the same framing.
Now, lets say that you use 25mm from 3 meters, that gives you framing of about 220 x 160 cm. At that range f/1.8 gives you about 78 cm.
If you are now photographing the same group of people and you have four people positioned together that you can fill in that 78 cm of DOF, but you find that the background is distracting, what you can do is to change the perspective. So either turn camera around the group and turn the group facing the camera until camera points toward background that has the nicer background.
Or if you can't do that, you can control the background better by using longer focal length, so instead 25mm you can go straight to example 100mm. Now you have four times narrower field of view, so what you need to do is to move four times further. So you move camera from 3 meters to 12 meters.
What you now have is same framing for the group, the background size is only 1/4 of the previous, and with f/1.8 (now a theoretical 100mm f/1.8 lens) your DOF will be the same, about 78 cm, but your background will be much different and far more blurrier.
When it comes to long telephoto lenses, if we ignore 70-200mm and the use for landscape or portrait. The long telephoto lenses often use for either wildlife or sport and in those situation, very often you can't get close to the subjects and use a wide angle lense.
Of course. But in such scenarios where you can not get the same framing (magnification) your DOF will be totally different.
I imagine you can zoom out a bit to increase the DOF and crop in later if you have spare megapixels but in general use of long telephoto lenses is because you can get close to the subject by foot.
Cropping changes the DOF.
The DOF is defined by you, the viewer, that what you find acceptable as sharp (instead blurry). And DOF changes as well by the final image size, viewing distance and your eyesight. It as well changes by the sensor Mpix count (image resolution) as well is the lens sharp or soft and many other factors, that are not related to the F-stop or camera distance.
The image below was taken in South Africa last year and I can't remember if I stopped down or not. If I remember correctly the shot was taken at 400mm at either 6.3 or 8.0 or even higher. Problem is the 100-400 at 400mm generate a thin depth of field.
The 400mm will generate same DOF as example 12mm if you would frame (magnify) the bird in same size on the frame from 4/3" sensor.
The 400mm itself doesn't make the DOF thinner, the magnification does.
The options is either to use the 100-400, drive closer and scare the birds away. The other option is to jump out of the vehicle, walk up to them and scare the birds or at the sometime get killed by the bleeding and peed off cape buffalo close by.
The point I am raising, is that the focal length doesn't change the DOF, but your magnification does. So if you are there photographing that bird with a 40-150mm, 300mm and 150-400mm with all set for longest focal length and all you are using at f/5.6.
You will get the same DOF regardless the focal length change when you frame the bird same size. Meaning you would have possibility to get closer or further to get that same framing.
So your f/5.6 is not thinner with 400mm than it is with 150mm.
So let me put it in other way:
You do not need to stop 100-400mm @ 400mm down more than you would need to stop down 35-100mm @ 100mm, if you would manage to get the same framing on the bird, as the DOF will be same.
