Sharpness at f/1.4
marco1974 Senior Member • Posts: 1,831
Sharpness at f/1.4
Here: cut yourselves open!
100% straight out-of-camera JPEG, captured with the amazing XF 23/1.4R.
Marco
 marco1974's gear list:marco1974's gear list
Fujifilm X-H1 Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R Samyang 135mm F2.0
57LowRider Veteran Member • Posts: 4,155
Re: Sharpness at f/1.4
After I first got that lens shortly after it hit the shelves, I called it "The Resolver" -  it seemed to give the sensor extra pixels. It really is very good. Might yet get a square lens hood for mine.
 57LowRider's gear list:57LowRider's gear list
Fujifilm X-E1 Fujifilm X-T1 Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +11 more
stefanik Regular Member • Posts: 160
Hi Marco,
could you share your jpg settings?
mike lix Contributing Member • Posts: 500
Marco
I really wanted this lens for shooting (mainly) wide dog portraits - the FL, the f/1.4, all great. But sadly this photo just confirms how strong the sharpening has to be set to resolve some detail wide open and for dogs´ fur this is not enough. I have the 16/1.4 instead, which is a bit better wide open, but it is sometimes a bit wider than I want. Still waiting for version II of this lens, with improved ghosting on high contrast edges, sharpness and focusing speed - to such an offer I could not resist!
mike
www.instagram.com/michal.placek.fotograf
www.facebook.com/michal.placek.fotograf
500px.com/mikepl500px
 mike lix's gear list:mike lix's gear list
Fujifilm X-T2 Carl Zeiss Touit 1.8/32 Carl Zeiss Touit 2.8/12 Fujifilm XF 16mm F1.4 R WR XF 90mm +1 more
dual12 Contributing Member • Posts: 824
It doesn’t look very sharp to me. The buildings and clouds are way out of focus...hahahaha!
DarnGoodPhotos Veteran Member • Posts: 8,592
I see the artifacts you're talking about, but I found that I didn't need to jack up the sharpness to get nice dog photos with good fur detail..
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X-Pro1 Fujifilm X-Pro2 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +3 more
DarnGoodPhotos wrote:
I see the artifacts you're talking about, but I found that I didn't need to jack up the sharpness to get nice dog photos.
These are nice photos, but the f/1.4 shots are not doable for me Web/FB/IG is fine, but large prints not so much.
mike
OP marco1974 Senior Member • Posts: 1,831
Not sure what you're talking about. The sharpening was set to the default "0" in camera. No post-capture sharpening was applied (nor any other post processing whatsoever).
I cannot see any artefacts. That's just what a cheap polyester fabric flag looks like in real life
M.
stefanik wrote:
Hi Marco,
Film Simulation = S ("Astia"), DR Priority = AUTO, WB = Sunny.
All other settings at default = 0.
M.
M.
There's no problem with the flag, it's just the very fine detail that I need for my shots and I can't see them in 23/1.4 (nor in 35/1.4) pictures shot wide open. I need only small radius sharpening to refine tiny details, larger radius is not OK as it induce artificial look. In-camera sharpening obviously uses larger radius for this lens wide open. For most uses OK, for the very fine details (that I need) not so much.
tradesmith45 Senior Member • Posts: 1,667
For Astro Landscapes ALL XF f1.2 & f/1.4 Lenses Are Poor Wide Open
Glad your liking the XF23 Marco for the subjects you shoot.  It is terrific stopped down.  At f5.6, its stunning.
Wanted to respond w/ a differing opinion re f11.4 for anyone doing astro.  I own the XF16, XF23 & XF56.  Fuji has compromised edge IQ of all 3 to keep lens size down.  (The XF35 may be even worse from looking at Lenstip review.)  The large amount of vignetting in these demonstrates the size problem.  All 3 must be stopped down to f1.8-f2.2 to get sharp edges.
Unfortunately the XF23 also suffers from high astigmatism even in the center @ f1.4 so star fields turn to mush.
Astro is a harsh test of lenses and the demands of general photography are less.  The XF23 @ f1.4 can produce acceptable results for may applications.
Marco
 tradesmith45's gear list:tradesmith45's gear list
Fujifilm X-T2 Olympus E-M1 II Fujifilm X-T20 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Samyang 12mm F2.0 NCS CS +5 more
