What tripod do you use and aren't many identical?
Started Jun 17, 2019 | Discussions
Jack Dale Junior Member • Posts: 33
Re: Bitteschön!
The seller didn't even mention a ballhead at all, but that second pic looked like there is one, with the legs folded over the head. Baibian's website also mentioned a ballhead coming with this BD-284 tripod, an MD-28, so I bought it.
Here it is:
The Baibian website: http://www.baibian.tw/
The Baibian BD-284 tripod, pictured here the carbon version: http://www.baibian.tw/BD-Series.html
The BD-28 ballhead: http://www.baibian.tw/Ballhead-md28.html
Baibian's nicest looking ballhead, the 45A: http://www.baibian.tw/Ballhead-45A.html
I wish I knew who imports/sells Baibian products here in Europe, and under what brand name!
Liewenberger
With the button release and the lack of safety screw grooves, that looks like a Sirui style ballhead.  They are not fully compatible with Arca Swiss plates.   I could not fit a Sirui tilt head clamp to the vertical plate on my L bracket.
 Jack Dale's gear list:Jack Dale's gear list
Nikon D70s Nikon D200 Nikon D7100 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF +4 more
HRC2016 Veteran Member • Posts: 6,874
Sirui - fabulous travel tripod
I can never spell the name right but they have a very compact, affordable model. I mentioned it on my gear list. It's been great. I think it was $150 for CF.
Why pay more?
My Slik is about 30 years old and doing great. The model is long since removed from the market.
I do not recommend:
I have a Vanguard that's a real dog. I also had a Dolica. It broke after a few weeks.
I believe in science, evolution and light. All opinions are my own. I'm not compensated for any of my posts. Can you honestly say that?
 HRC2016's gear list:HRC2016's gear list
Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Sigma 150-600mm F5-6.3 | C Olympus 12-100mm F4.0 +2 more
gary0319
gary0319 Forum Pro • Posts: 10,540
Benro Slim
On recommendation of my local Olympus dealer I purchased this one. I bought the Aluminum one but they also make a carbon one. The only drawback was the bullhead. It was sturdy enough for my E-M1 II with 40-150 pro or Panny 100-400, but did not accommodate panning for landscapes, so I replaced it with another inexpensive one that works just fine.
I use this about 3 times a year and for $99 it’s great, and lightweight.
https://www.amazon.com/Benro-Aluminum-Lightweight-Travel-TSL08AN00/dp/B072K62KMH
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
R Liewenberger Senior Member • Posts: 1,824
Re: Bitteschön!
Here it is:
Liewenberger
Yes, the Sirui heads indeed look very much like this one. The only difference seem to be these stupid black rubber rings on the knobs of most of the Sirui heads; I could imagine it feels nice, but I don't think these rings will live forever.
Not fully compatible with Arca Swiss, you're probably correct, but I've never done any tests. So far  I have used this head exactly once, with the plate that came with it, on last New Year's Eve. Thought about shooting some fireworks from the veranda, looking down to a little village in the valley. Had nicely set up the Rollei tripod with this Baibian head and my old E-5 with the RM-CB1 cable release, but then around 10 p.m. the valley filled up with fog and that was it.
The lack of safety screw grooves - yes; though I think this has changed now with newer models. I bought this one in late 2017 or early 2018. The seller said it came from some photoshop gone bancrupt, so around the time I've bought it, it was probably not the latest model of this head.
Liewenberger
setiwan47 New Member • Posts: 15
Re: What tripod do you use and aren't many identical?
One of the extra benefits of M43 is the lightness of everything. Most "quality" tripods aren't actually "quality". Instead they are built  robust enough to support, say, a Nikon with a 600mm telephoto, or in other words about four M43 cameras with equivalent lenses.
With smaller, lighter M43s much less expensive tripods are completely adequate at a fraction of the premium-brand price tags. At my photo store, which featured tripods up to AUD$600, I found a AUD$59 one that works perfectly for bird photography.
I also found the 1KG Joby Gorillapod completely adequate: my Olympus PenF and 150-300 zoom come to just over 820gm. This model costs way less than the "suggested" 3kg model.
OP Jorginho Forum Pro • Posts: 15,370
I received the first shipment
They split it in two with both on the way and now one arrived. The ful tripd without the central part nor the feet.
First impression is that it is very sturdy, the legs extend just after twisting the twist locks. Gravity makes them extend completely (which is something I like and no other tripod I use ever did). The angle of the feet seems to be the proclaimed 24 degrees which is close to the ideal 25 degrees (which it could also be, I did not measurre it).
The legs seem very stiff.
One downside: the rubber on the twistlocks moves upward pretty easily. And it is in all cases just the second leg from the top. I could use some glue but this is after extending and retracting 20-30 times which I normally would not do.
The finish seems to be really good as well.
So it depends on the next shipment and then how it performs in reallife to give a more substantial update which I will do.
Also it seems to be much more robust from the look of it than the Sirui you pointed me to. Not that I want to brag or put it down at all, that one just looks a lot more like my Rollei C5i. which is pretty nice and lightweight, has 25 mm legs but just isn't as robust as the Innorel 80.
 Jorginho's gear list:Jorginho's gear list
Olympus PEN E-PL5 Panasonic Lumix DMC-GH4 Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH +8 more
Art_P
Art_P Forum Pro • Posts: 10,114
I had
A Velbon Victory
Bought primarily because it was not expensive and the shaft could rotate to horizontal.
Not always the sturdiest tripod(depending on configuration), but after 30 years it was only just starting to show its age.
Picked up an inexpensive one on eBay last year, but have yet to use it.
Art P
"I am a creature of contrast,
of light and shadow.
I live where the two play together,
I thrive on the conflict"
 Art_P's gear list:Art_P's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 14mm F2.5 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +6 more
afoton
afoton Senior Member • Posts: 1,870
When using telephoto lenses, torsional rigidity is the factor to look for in the tripod. The weight of the camera is not the problem for the tripod, it is the narrow angle of view that makes small movements so prominent in the picture. I would put the same demands for a tripod for a M43 with 300mm as to a Nikon FX with 600mm. I have never seen a tripod that has enough torsional rigidity for the narrow angle of view, but is not robust enough for the weight of a Nikon FX with 600mm.
The head is another matter. A more lightweigth camera does not make the same demand on the head. But still, narrow angles of view set demands on the operation of the head. Small ball heads are not up to the task, because small balls makes it very hard to do small adjustments. Bigger balls makes it a lot easier, and bigger balls also handle the heavier cameras. If using video heads or gimbal heads, the real benefit of more light weight cameras will occur.
Kiwisnap Senior Member • Posts: 1,557
I try very hard to avoid using one at all, ever.
If I have to, it's a Gitzo Ocean Traveller (the orginal first series version) with a Series 1 ballhead replacing the original (useless) one.
I am thinking of replacing it with a Series 2 traveller though.
