Perspective (yet again, sorry!)
J A C S
J A C S Forum Pro • Posts: 14,773
Re: books are frequenty wrong
tko wrote:
Perspective on viewing a photograph
The perspective obtained on viewing a print - sometimes termed the apparent perspective - depends, firstly, on the relative sizes of objects in the print - and hence on the perspective obtained in the negative on taking the photograph - and, secondly, on the distance at which the print is viewed.
Correct perspective is said to be obtained when a print is viewed in such a way that the apparent relation between objects as to their size, position, etc., is the same as in the original scene. This is achieved when the print is viewed at such a distance that it subtends at the eye the same angle as was subtended by the original scene at the lens. The eye will then be at the centre of perspective of the print, just as, at the moment of taking, the lens was at the centre of perspective of the scene.
Unfortunately, this is wrong. The viewing point for a photo is forever fixed at the point from where the photo was taken. In the 3D world, moving closer and farther changes the relative sizes of objects that aren't the same distance from the lens. But once captured in a photo, the relative sizes are forever fixed.
Take the classic example of a portrait taken close up. The features are exaggerated. Try as hard as you can, no amount of moving the photo back and forth will alter this exaggeration.
There is nothing in what you call wrong, saying that the features can become less exaggerated with the viewing distance.
Just Tim 4
Just Tim 4 Contributing Member • Posts: 663
tony field wrote:
tko wrote:
Tom Axford wrote:
I have an old copy of "The Manual of Photography", 1978 Edition (Focal Press) and with all the discussion recently about perspective, I thought I would look at what it had to say on the matter.
Here are two extracts from the section on perspective (in Chapter 4 "The Geometry of Image Formation"):
Perspective on taking a photograph
As we have already seen, the perspective obtained on taking a photograph - sometimes termed the true perspective - is governed solely by the viewpoint. If the viewpoint is fixed, there can be no change in perspective, even if we change to a lens of different focal length - although, as we have seen earlier, the image size will alter. If, however, the viewpoint is altered, so will be the perspective, and no change of lens will recreate the perspective obtained at the first viewpoint.
This is correct, thanks
and
The book is correct. You are misinterpreting what it said. That is a superb and technically accurate book particularly so for the older editions. I wish I had a copy.
I would agree. The book is a technical manual and describes accurately how an image is mapped by a lens onto a 2D surface. What it doesn't describe in detail is how the human eye interprets that information and re-builds a 3D understanding. But it doesn't seek to to that and you must read it with that understanding. It is a common mistake to think that because something is *fixed* in an image that you see and understand it as *fixed*. In order to understand perspective fully you must understand the nature of the assumptions you make when you view images.
Of course! That is the nature of projecting a 3D scene onto a 2d surface of the sensor
I agree, but add that just because the *relative* sizes are fixed it does not mean that your assumptions of scale and distance are.
Take the classic example of a portrait taken close up. The features are exaggerated. Try as hard as you can, no amount of moving the photo back and forth will alter this exaggeration. Printing the photo freezes the perspective, since there no "center of perspective" for a flat, perpendicular object
Well that has to be said with care.
This has to be taken with EXTREME care. Nothing is as familiar to the human eye as a human face, nothing is imprinted on our memories more clearly. Such is our pre-disposition to form a correct understanding of a human face that it's actually quite difficult to spot what should be glaringly obvious. And if you can't see the obvious clearly then do you really think that we see subtle changes in perspective clearly?
Just as a proof see if you can spot what's wrong with the image below:
Explain that this shot which is virtually full frame from about 1.5 and certainly less than 2 meter distance witha 28 mm lens. I do not see the that distortion you are describing
The perspective impression that you see on the 2D projection is a perceptual process and your perception might be surprisingly wrong in many cases because you misinterpret the visual clues.
Absolutely. In fact we ALWAYS misinterpret visual clues in images, we never see them correctly. But there is another process at work, *consistency scaling*. Basically we find it far easier to navigate in a world where perspective is *consistent* and so the brain works to maintain this consistency. It doesn't mean that we see a distorted view of the world or that our assumptions are inaccurate, just that they maintain consistent as we move through it. And they remain consistent from our position as observer. You can see this when you first get a pair of glasses. At first they make you a little dizzy, but you get used to them. Not many understand the full importance of this, that you brain recognises the change in focal length, (and the slight change in angle FOV), and how vanishing points appear to move at a different speed in your peripheral vision to your central vision and cancels the effect out. It learns how to adapt what you see so you have a consistent understanding where perspective stays constant.
This happens in images as well. We form a consistent understanding because our brains try to cancel out changes in perspective with distance. The illusion with the odd shaped room is a good example of this process. It only works, (and is designed to work), from one point, the centre of perspective. If we stand in every other place we form a remarkably consistent view of the shape of the room, it is only when we stand in the centre of perspective that another more likely interpretation is presented. The illusion of the room is designed to show that in cases where the most likely is obviously incorrect we still interpret perspective in terms of the most likely as dictated by our experience. And so we see the tow people as being of different sizes rather than the room being an odd shape, even when we know the reverse is true.
Images are the same, we form a consistent understanding of perspective until we reach the centre of perspective when another interpretation that is more consistent with our experience presents itself. It is not a linear process, and with all things we see you can't make the assumption that the maths is correct and that we always see this in absolute terms.
You can't view images without understanding the nature of the assumptions we make when we view them.
Take a photo. Now take a photo of the photo from far away and close up using a zoom the fill the frame. The two resulting photos will look identical.
Since you have move far away from your original shooting point of course the actual perspective changes in the final 2d image projection. The images are not looking identical.
Agree, they don't. But it is hard to detect this with the subject of a human face, especially one where there is no other perspective other than our assumptions of the shape of the human face.
Many classic works have serious flaws. In this case, the flaw is somewhat laughable. Suppose you take a photo of a mountain from a mile away. Do you have to view the image from a mile away to have correct perspective?
Of course not you would not have the correct ocular point of view if you tried to do that.
I agree, it's a case of *absolutes gone mad* - the relationship is to focal length x magnification not subject distance.
What about a macro? Do you have to glue the photo to your face?
Macro is a special case as we ar viewing the world in a way which we have not other experience of other than the photos we see. Besides it's related to the focal length x magnification (the focal length at the point of focus and not the number stamped on the barrel), somehow this has been twisted to mean the actual distance to the subject...
Okay, technically, the edges of a photo might be smaller as you move the image closer, since they are now farther away. But most lenses and the human eye correct for this effect, which can't be categorized as "perspective" effect.
Wrong again. Sorry.the correct ocular distance will always always give you a correct perspective effect.
I agree. And if people are still in doubt that they do not see or recognise the nature of the assumptions we make, and that those assumptions are relative to our position as observer, that because we see consistency relative to our position we make the assumption that it is the object that is consistent:
An image of simple perspective, a vanishing point that is in the centre of the image:
Now if the perspective is *fixed* in the image and is an absolute of the image then if we hung two identical copies on either side of a corner in a wall then wouldn't the *fixed* perspectives (or vanishing points) converge?
But they don't they remain resolutely fixed only to your position as observer, in fact they actually splay out in relation to your position:
BTW, turn the portrait the correct way up.
tko Forum Pro • Posts: 12,913
it would seem like nobody read it correctly
1.) Take a photo, say a close up portrait.
2.) Print it as photo A
3.) Use a telephoto to take a photo of that photo.
4.) Zoom in full screen from different distances, creating another another set of photos B, C, d.
Can anyone tell the difference between the set of photos taken of the original photo A?
Nope, which shows that the viewing distance of a photo is irrelevant to perspective. The book is either 1.) wrong 2.) meaningless 3.) poorly explained.
If you're going to challenge something, challenge my statement: "viewing a flat photo from different distances has no impact on perspective." Show me a thought experiment that violates this with a clear counter example.
As a bonus question, tell me what "correct perspective" means and how a print viewed with "incorrect perspective" would be distorted.
no, I won't return to read your witty reply!
professional cynic and contrarian: don't take it personally
http://500px.com/omearak
Tom Axford wrote:
Although I did not copy the whole chapter, a little later on he says:
"For correct perspective, therefore, a contact print should be viewed at a distance equal to the focal length of the lens.
1.) You can't change perspective by viewing distance, therefore there is no such thing as a "correct viewing distance" for perspective.
An enlargement should be viewed at a distance equal to the focal length multiplied by the degree of enlargement."
2.) This contradicts what he's already said. With a 100 MM lens, you could take a photo of a flower close up or a mountain far away. At the same enlargement, this statement says the "correct" viewing distance for both is the same.
No need to go a mile away!!!
By the way, a contact print is a print made at the same size as the image on film (or on the sensor if you translate it to the digital age). Of course, nobody makes prints that small these days.
Going back to the basics, his statement "Correct perspective is said to be obtained when a print is viewed in such a way that the apparent relation between objects as to their size, position, etc., is the same as in the original scene."
Here is how I read this statement. If you have a man who appears to be half the height of the tree behind him, there is a two to one size relationship. This relationship is the same no matter where you view the photo from.
The relative size and position of objects in a photo do not change with viewing distance. Not in the brain, not with a ruler, not with anything. No one has given me an example of how this could happen.
OP Tom Axford Veteran Member • Posts: 6,289
Re: it would seem like nobody read it correctly
That is a convincing argument, yet it is mistaken.  The reasons are quite subtle and to explain clearly would involve drawing some diagrams which are very tedious for me to do.
Instead, I am going to suggest a real experiment that anyone can do if you can display your images on a large screen (the larger the better).  Take an ultra-wide-angle image and display it as large as you can.  Suppose it was taken with an 18mm equivalent focal length lens and is uncropped.  Then position you eye at a distance from the centre of the screen that is equal to about half the width of the image.
How does the image look?  The perspective that you see should be about the same as if you viewed the original scene with your own eyes (from the position of the camera).
Try it!  If you haven't done it before it is quite remarkable. Any wide-angle distortion in the picture magically disappears.  This is what correct perspective means.  It means that your eye sees everything in the image at the same angular positions as you would have seen if you viewed the original scene from the camera position.
Until you try this experiment, you will probably not appreciate what I am getting at.
I know many people here have tried it, and understand exactly what I mean.
tex Veteran Member • Posts: 7,887
Well, here's my perspective.
Photographers, and for the most part amateurs (in both the good and bad senses) and enthusiasts, get very fixated on things like....this...and all the other things here at DPR that generate multiple threads that max out.
I have run into very few professional commercial photographers who are as obsessed about this sort of thing, excepting maybe some architectural  and niche (as in my own field of museum photography) photographers, and zero artist photographers who do.  And even then, it's not like it ever generates a bunch of discussion.
tex_andrews, co-founder and webmaster of The LightZone Project, an all-volunteer group providing the free and open source LightZone photo editing software.
"Photography is the product of complete alienation" Marcel Proust
"I would like to see photography make people despise painting until something else will make photography unbearable." Marcel Duchamp
 tex's gear list:tex's gear list
Pentax 645Z Pentax K-1 Pentax K-1 II Ricoh Theta V Pentax smc FA 77mm 1.8 Limited +29 more
Just Tim 4
It's all here, with examples and a thought experiment that you can repeat at home:
https://www.dpreview.com/forums/post/62791542
Besides your statement reads:
3.) Use a telephoto to take a photo of that photo. = copy photo. Did you think that it would apply *telephoto compression* to the photo? Somehow change the perspective...
Hmmm...
So go back to my thought experiment then, see if you can come up with an *explanation as to why the vanishing points appear to move relative to you as the observer* if the position you view from makes no difference. And then tell me how this doesn't affect the perspective...
