bp1030 and.....bp1130?
Started Jun 16, 2019 | Discussions
AndrewIsUsingTheNX1000 Forum Member • Posts: 60
so my nx1000 is using bp1030. i have seen bp1130 somewhere,when i picked it up,pretty much things the same,like the case. but the thing is,can i use bp1130 on my nx1000?whats the difference between bbp1030 and bp1130?
 AndrewIsUsingTheNX1000's gear list:AndrewIsUsingTheNX1000's gear list
Samsung NX1000 Canon EOS 700D Sigma 70-300mm F4-5.6 DG Macro +2 more
Samsung NX1000
Re: bp1030 and.....bp1130?
1130 is a newer model used in NX500 (for example). As I have both nx1000 and NX500 I use them both and don't look at the battery. They have the same form factor and voltage.
OP AndrewIsUsingTheNX1000 Forum Member • Posts: 60
so,you charge both on the same charger?
Yes
Danielsic New Member • Posts: 1
Hi Otto I recently bought a new genuine bp1130 and it won't charge in the nx1000 charger, no indicator light on charger or anything but works in camera as it had 2 bars of charge out of the pack any ideas? Thanks
Sorry, I just checked with the original NX1000 charger and it doesn't charge the original 1130. It does charge 1030 and third-party batteries (they say they are 1200mAh, but they last less than the original ones). They are wasabi and came with their charger (which I always use as it works in car as well, it was a charger and two batteries for ~15$) and it charges 1130 too. NX1000 charger charges no-name batteries with blue stripe on the side of the label, I have them a few, they vary by their stated capacity from 800 to 1200mAh but they all work (I keep them as spares, just in case).
I also have (somewhere) completely no-name (nothing on it, was less than 5$ on that auction site) charger that IIRC charges everything. Can't find it though.
FWIW, I've had only good experience with wasabi (Sony and Canon batteries as well) and if I cannot get the originals, I go for them. Maybe someone with more experience can chime in?
