Nikon D750 with Nikon 24-70 2.8 VR
Sharianne
Sharianne Regular Member • Posts: 228
i have been told this lens is too heavy with D750. Anyone have this combo? Thx
iMac 27" core i7
Nikon D750, 50 1.4, 85 1.8, sigma 150-600
 Sharianne's gear list:Sharianne's gear list
Nikon D750 Nikon AF-S Nikkor 50mm f/1.4G Nikon 85mm F1.8G Sigma 150-600mm F5-6.3 | C Tamron SP 24-70mm F2.8 G2
Nikon D750
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 15,532
Re: Nikon D750 with Nikon 24-70 2.8 VR
Too heavy why?   Someone thinks all lenses should be the weight of 50f1.8?   Someone thinks the lens mount will warp from a 'heavy lens'?
DSLR's are about the heaviest cameras used these days.   You should expect the lenses to mostly match.   I don't find the 24-70 heavy at all, but then I shot an 80-200F2.8 with SD-24 flash mounted at the same time for years.
Phoenix Arizona Craig
www.cjcphoto.net
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +37 more
Sharianne
OP Sharianne Regular Member • Posts: 228
I read in a review of lens. The person was using 810.  I have been told the Tamron would be better for me but just checking as can get a good price on Nikon
iMac 27" core i7
Flashlight Veteran Member • Posts: 7,952
I find the combo quite heavy, I changed my 70-200 f/2.8 VRII for an f/4 copy and can now walk around all day with two D750's, 24-70E VR, 70-200 f/4, 20mm f/1.8, 50mm f/1.4 and an SB800 flashgun for low light event work.
Whether it's too heavy for you is of course very personal. I have a very light DX set for work in good light.
Philip
PHXAZCRAIG
What is the weight difference between the two lenses?
I find that the only time my camera really feels heavy is if I have it on a strap around my neck.   I quit doing that years ago and changed to hanging a camera off my shoulder.   Two cameras, preferably.   I did have to change the Nikon strap to a decent padded one that doesn't slide off a shoulder.
www.cjcphoto.net
Sharianne
Thank you. I got the Peak Design strap and it does make a difference. This is basically a hobby so I would only carry one camera😄
iMac 27" core i7
Peter v.d Werf Contributing Member • Posts: 738
I'd say rent a copy for a few days if you're in doubt. The experience of weight is very personal. I was fully used of this kind of lenses (900/1000gr) on my D750 and I was just fine with it. Others might find it heavy and someone used to a 70-200VRII might find it refreshingly light;-)
Nikon33 Senior Member • Posts: 1,447
I have a similar combo, D850 + that lens. I always use 2 bodies during events. I can easily shoot for hours with the D850 and Z6 + 24-70mm VR and 70-200mm 2.8 VR. Of course, I do own a light DX setup like others have mentioned for when I get lazy. But no, by too heavy, there are no balance issues or anything. The 24-70mm f/2.8 VR is a great lens! When I had a D750, my 24-70mm remained fixed on it 95% of the time. 24-70mm is a excellent focal length for many functions.
 Nikon33's gear list:Nikon33's gear list
Panasonic Lumix DMC-LZ3 Nikon D60 Nikon D700 Nikon D800E Nikon D500 +15 more
Toby43 Regular Member • Posts: 499
I did try it and it’s a little front heavy but not noticeably more so than the older 2.8. It’s a big heavy lens on any camera, only buy it if you need it, is my view. Peak design strap is the answer to carrying the thing.
 Toby43's gear list:Toby43's gear list
Ricoh GR II Nikon D750 Fujifilm X-Pro2 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G +8 more
Sharianne
Thank you.  I have the Peak Design strap but I think I have decided on the smaller, lighter Tamron that gets excellent reviews.
iMac 27" core i7
StillLearning
StillLearning Veteran Member • Posts: 4,379
Which Tamron?
 StillLearning's gear list:StillLearning's gear list
Nikon D810 Nikon D750 Nikon D7200 Nikon D850 Nikon Z6 +11 more
Sharianne
24-70 f2.8 G2. Must be the second generation
iMac 27" core i7
StillLearning
Yes. It can take the Tap in for lens updates. Same combo I have.
PHXAZCRAIG
I'm only a hobbiest too, but I got in the habit of two bodies back in the 1990's, using ISO 400 film in one and ISO 64 in the other.  Sometimes different ISO's, sometimes slide versus print, sometimes color versus black and white.
At other times I just use the same film (or ISO settings on digital), but like the flexibility of two bodies with complementary lenses, especially primes.
After carrying a gripped N90s with 80-200F2.8 and often an SB-24/26 speedlite, the weight of an ungripped camera with a simple 24-70 zoom doesn't seem heavy in any way to me, except perhaps hanging from my neck.
I am used to big cameras, and slogging weight around as needed until my camera is in the right place with the right lens.
Underwater gear is even worse, since it all encases the camera.  At least underwater it is neutral.  My rig with two strobes, focus light, camera, lens and wide angle dome weighs more than 30 pounds above water.
www.cjcphoto.net
So you haven’t actually used the camera and lens the OP is asking about. Your point, apart from showing off a nauticam housing, is?
Sharianne
That is what I thought. No help to me🙄
iMac 27" core i7
