Loving Rokinon AF 45/1.8
thiefofpresence
thiefofpresence Contributing Member • Posts: 697
10
Just picked up this lens at B&H and deployed to my system in the role of AF normal. Liking it very much, of course because of its fantastically light and small size, optics that look like an homage to the Sony Sonnar 55/1.8.
The AF seems like its was tuned for the version 3.X firmware on my A7iii, and having previously owned Sony Zeiss 55 and 35, I am finding performance to be fast and accurate within a margin of error of Sony Native performance.
Paid the full $399 for it, and am sure that it will be available at times for $299 and be a fantastic steal at that price.
https://www.instagram.com/thiefofpresence
Sony A7iii | Voigtlander Color-Skopar 21/4 Pancake; Zeiss Batis 2/25; Rokinon AF 45/1.8; Sony FE 1.8/85 | Sony FE 4/24-105 G OSS; Sony FE 4/70-200 G; Sigma 150-600 C
 thiefofpresence's gear list:thiefofpresence's gear list
Sony a7 III Leica Elmarit-M 28mm f/2.8 ASPH Voigtlander 21mm F4 Color Skopar Pancake II Sigma 35mm F1.4 DG HSM Art Sony FE 70-200 F4 +4 more
DenImage Senior Member • Posts: 2,496
Re: Loving Rokinon AF 45/1.8
Yeah I mostly agree, but there's a few things I don't like about it. The AF motor is still audible (will be heard by internal mic when recording video), the manual focus ring is too loose (like my Sony 100mm STF), and chromatic aberration is very prevalent.
I paid $385 for mine, so the above compromises are acceptable for the price and compact size and light weight. I purchased it as an less expensive alternative to the Sony FE 55mm which is larger (longer) and heavier, and also has very prevalent chromatic aberration.
I am impressed with the sharpness of the Samyang, both central and edges/corners are excellent from wide open (though less contrast at f1.8). See my brick wall test shots here:
https://www.dpreview.com/forums/thread/4401572
Den
 DenImage's gear list:DenImage's gear list
Sony a7R II Sony a7 III Sigma 8mm F3.5 EX DG Circular Fisheye Sony FE 55mm F1.8 Sony FE 100mm F2.8 GM +3 more
travelinbri_74
travelinbri_74 Veteran Member • Posts: 3,427
I will keep track of this thread and would love to see pics from you all.
I would like to love this lens - although I would have more preferred it at 40 - but so far the few pics I have seen haven't convinced me. Hope to see lots more as it becomes widely available. Great that Samyang is focused on small lenses for the Sony.
 travelinbri_74's gear list:travelinbri_74's gear list
Ricoh GR III Sony a7R III Sony FE 90mm F2.8 macro Sigma 100-400mm F5-6.3 Sony FE 16-35mm F2.8 +2 more
Bad weather here, so it will be a while before I can post some samples.
The images look great in this thread though:
https://www.fredmiranda.com/forum/topic/1595630/9#lastmessage
Den
matrix44 Forum Member • Posts: 84
Mine should be here on Monday. Looking forward to playing with it. Paid $340+tax for it with a 15% off discount at Rakuten, so I'll be happy with it as long as it's better than the Sony 50 1.8 that I sold recently.
This will be the only small and light lens in my A7iii kit, so it will see a lot of use if it's half decent. I also bought the incredible 50 ZA 1.4 recently, so I will have the highest quality 50mm out there when I am okay with the size and weight, and now this diminutive 45mm when I need the best portability.
Kris2403 Junior Member • Posts: 33
How does it compare to FE 50mm f/1.8 in sharpness, AF, etc.? Thanks
I've previously tested the Sony FE 50mm f1.8 so I can post a comparison.
The Samyang has a faster and quieter AF motor but is still slightly audible. It's also noticeably sharper in the edges and corners at wider apertures, but equally centrally sharp. Chromatic aberration and vignetting is equally average in both lenses. The Samyang's slightly swirly bokeh is more pleasing thanks to its 9 aperture blades vs 7 in the Sony, and as yet I haven't noticed any of the reported onion rings. IMO the Samyang's build quality is slightly better than the Sony's, and I prefer its internal focusing vs the Sony's extended barrel focussing.
The Samyang lens offers reasonable and acceptable performance (especially as a compact/light travel solution) and is worth its current asking price. The Sony never made the cut for me, because it had too many compromises.
Den
vlado29 Junior Member • Posts: 26
Would it be completely crazy to replace Zeiss 55/1.8 (that I already own) with this lens? I currently also have 28/2 and 85/1.8. Plan to replace 28/2 with Tamron 17-28/2.8 (had GM 16-35/2.8, but sold it, it was too big for me), then I could cut it with 17-28 on the wide end, 45/1.8 as light walkaround prime (or Batis 40/2 when it gets cheaper) and 85/1.8 portraits/landscape tele...
travelinbri_74
I found the Samyang 35/2.8 an excellent performer. If this can match or exceed that lens, it is a winner in my book.
CyeJoeBob Forum Member • Posts: 71
Did anyone experience AF issues. My Samyang 45mm 1.8 can't properly focus at infinity. It always has a slight front focus when focusing at infinity, no matter which AF mode or aperture I choose.
I'm not sure wheter it is just my sample or a general AF issue.
100% center crop - MF (left), AF-S (middle), AF-C (right)
 CyeJoeBob's gear list:CyeJoeBob's gear list
Sony a6300 Sony E 16-50mm F3.5-5.6 PZ OSS Sigma 60mm F2.8 DN Art Sigma 30mm F1.4 for Sony E Sigma 16mm F1.4 DC DN (Sony)
Mentt New Member • Posts: 19
For a prime lens around 50mm  it has noticeable barrel distortion ... for example cheap Sony 50mm 1.8 is basically distortion free
Peter Foiles
Peter Foiles Senior Member • Posts: 1,788
I did have one situation where it would not focus properly on a building 50 yards out but in other cases focus on distant objects seemed OK.
 Peter Foiles's gear list:Peter Foiles's gear list
Sony RX100 VA Sony a6500 Sony a7R III Sony a7 III Canon EF 70-200mm F4L USM +14 more
Yes it would be crazy.
IMO, performance wise the Samyang sits in between the Sony 50mm f1.8 and the Zony 55mm. It's better than the Sony 50mm, but not as good as the Zony 55mm.
Den
Noticeable if you're looking for it, but it's very minor.
Den
Yes, I have noticed the same issue, but only in AF-C mode at infinity.
I will do further testing tomorrow to see if it does the same in AF-S mode, if it does, it's going back 😕
Den
Den
To me It is easily noticeable
Jerry R Forum Pro • Posts: 10,731
Do you love the pictures?, Please post some.
Sony R1, NEX C3 & 5R ,Sony A7.
Lenses: 24mm, f/1.8, FE 24-70, f/4, & FE 70-200, f/4.
Nikon V1 + 10-30 & 30-110 lenses.
Mentt wrote:
Den
There's no EXIF data in that photo.
Please post comparison images from both the Samyang and Sony lenses to support your claim that the Samyang has more noticeable distortion than the Sony?
Den
thiefofpresence
OP thiefofpresence Contributing Member • Posts: 697
OP: Extended experience raises AF issues
I just spent a day shooting with this lens, and I have to say, using C-AF and back button focus, I would mash on AF-on set to Wide mode, and there was frequently (if not always) a long lag until I was showing evidence of AF locking. Sometimes, more disturbingly AF would simply fail and I had to release AF-on and "try again".
I realize they can fix this with firmware updates, but in the area of AF prowess, I was let down a little.
I've owned AF 35/1.4 and thought, even with narrower depth of field, that it had an easier time getting a lock than this lens.
I can edit and post some shots, and I am quite happy with the IQ results. All I could personally hope for. But, the AF experience was disappointing today (I'm the first to admit my expectations are nearly unreasonable for a third party manufacturer.
These are two post processed RAW to JPEG images from my brick wall test of the Samyang FE 45mm f1.8 @ f5.6 taken on my a7rii
The first is with distortion uncorrected, the second is with distortion corrected:
f5.6 image with no corrections
f5.6 image with distortion correction
The bottom image was manually processed +4 Barrel Distortion in DXO PhotoLab.
Lightroom fixes it with +3 Barrel Distortion Correction.
Den
