Samyang FE 45mm f1.8 Brick Wall test
DenImage Senior Member • Posts: 2,585
All SOOC JPEG's from my a7rii:
f1.8
f2.8
f5.6
f8
Den
 DenImage's gear list:DenImage's gear list
Sony a7R II Sony a7 III Sigma 8mm F3.5 EX DG Circular Fisheye Sony FE 55mm F1.8 Sony FE 100mm F2.8 GM +3 more
Foto4x4 Senior Member • Posts: 2,726
Re: Samyang FE 45mm f1.8 Brick Wall test
Not too shabby Den. Did you have vignetting compensation turned on in the body?
Cheers, John
Quote: “If your pictures aren’t good enough, you’re not close enough.”, Robert Capa
 Foto4x4's gear list:Foto4x4's gear list
Sony a6300 Sony RX100 VI Sony a7R II Olympus E-M1 II Panasonic Lumix DC-GX9 +14 more
OP DenImage Senior Member • Posts: 2,585
Yeah, all three were set to auto.
Though the shading (vignetting) correction seems to only partially correct the vignetting (same as my Tamron 28-75 lens).
Den
JohnNEX Senior Member • Posts: 1,797
Thanks for putting these up - very decent performance. The corners wide open are certainly better than I expected, and very good at f/8.  Looks a good buy to me!
Sharpness scores and other stats for many FE lenses here: https://www.dpreview.com/forums/thread/4398385
Fairly amateur photography here:
https://www.facebook.com/John-Clark-Photography-1035965476487072/
 JohnNEX's gear list:JohnNEX's gear list
Panasonic Lumix DMC-ZS20 Sony Alpha NEX-6 Sony a6500 Canon EF 70-300mm f/4-5.6 IS USM Sony E 50mm F1.8 OSS +9 more
Yeah I agree.
I must admit I was pleasantly surprised how sharp it is wide open, especially the edges and corners. I'm very happy about that.
Den
