Sandisk Extreme Pro or Extreme or ultra for t6
Started Jun 12, 2019 | Discussions
Laksh Junior Member • Posts: 47
Hi,
Which would be the more reliable card for the camera and would be  the best fit given the write speed of the camera..
laksh
Canon EOS Rebel T6 (EOS 1300D)
Photonographer
Photonographer New Member • Posts: 7
Re: Sandisk Extreme Pro or Extreme or ultra for t6
Sandisk Extreme Pro looks like it has the best Write speed, which is the more relevant detail. UHS II isn't necessary at all.
https://www.cameramemoryspeed.com/canon-t6s-t6i/sd-card-comparison/#RecommendedCards
Hope this helps.
 Photonographer's gear list:Photonographer's gear list
Canon EOS Rebel T7i Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 24mm F2.8 STM Canon EF 50mm F1.8 STM
R2D2 Forum Pro • Posts: 26,551
Hope this helps.
+1 I've been using Sandisk Extreme Pros for many years.  Love their ruggedness, speed, and reliability.
R2
OP Laksh Junior Member • Posts: 47
are the ultra line reliable and good value for money.. it could save a few dollars when i buy 5 or more cards...
laksh
laksh
There are various versions of the Ultra (with differing read/write speeds).  Your camera body probably maxxes out at about 45 MB/s?
Your call, but I prefer the maximum performance and reliability of the Extreme Pro.
R2
Doug Pardee
Doug Pardee Veteran Member • Posts: 9,920
I suppose it depends on what you're going to do with the card. If you check on various dash-cam forums, you'll find that Sandisk Ultra has a terrible reputation for dash-cam usage, which involves heavy writing and overwriting (hundreds or even thousands of times) of huge volumes of video data. Whether that's at all relevant to usage in still photography, I don't know.
Reliability in the consumer-grade SD world isn't something that's easily determined. In the high-priced world of commercial- and industrial-grade SD cards, the manufacturers describe what technologies are used, which at least gives you a clue.
Anyway... for my personal usage, I'd be okay with an Ultra because if a card goes bad and I lose the photos on it, it's no big deal. My pictures aren't important. Even so, I still go for at least an Extreme because I just don't want the hassle.
Co-founder of the open-source LightZone Project: http://lightzoneproject.org/
 Doug Pardee's gear list:Doug Pardee's gear list
Fujifilm X-T10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Olympus Stylus 1030 SW Canon EOS 350D +13 more
I've indeed killed less expensive cards with various dashcams.
Until I discovered the SanDisk High Endurance Video Monitoring Cards. Years writing continuously to the same card(s), no problems.
Similarly, 24/7 video surveillance systems are best served by the Western Digital Purple HDDs (IME).  And I only buy the WD Black HDDs for my computer storage needs (to pair with my SSD drives).
R2
