23mm f/2 vs 35mm f/2 beside my 12mm
Started Jun 11, 2019 | Discussions
jvdr New Member • Posts: 2
Hi Guys,
Before I switched to Fuji I used prime lenses on my Canon DSLR. Previous year, I used a cheap XC 16-50mm on my X-T1.
Now I want to switch to prime lenses again. I bought a Samyang 12mm for Fuji, for the landscapes on my travels and some wide-angle reportage shots. Now I'm in doubt between the 23mm f/2 and the 35mm f/2 beside this 12mm. I will use this one especially for Streetphotography and on travels.
What would you recommend? Are the 12mm and 23mm too close to each other?
Gringostarr Regular Member • Posts: 481
Re: 23mm f/2 vs 35mm f/2 beside my 12mm
Look at all the pictures you took with the 16-55 and see what focal length you took the most of.
Then get a prime of that.
 Gringostarr's gear list:Gringostarr's gear list
Fujifilm X-E4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 27mm F2.8 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 30mm F2.8 R LM WR +1 more
DarnGoodPhotos Forum Pro • Posts: 11,881
Personal preference, just set your zoom to 23 and to 35 to see which you prefer for the intended types of photos. 12mm is so wide that the 23 isn’t anywhere close to it, just decide if you wider 23 our slightly longer 35.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
CeeDave
CeeDave Senior Member • Posts: 2,208
jvdr wrote:
Hi Guys,
Although I sometimes use the 35/1.4 for street...
...it usually seems a bit tight to me, and I tend to prefer the 16/1.4...
...or the 23...
Even the 16’s perspective is way different from the 12. Atypically, I also like longer lenses (than “normal”) for street, like the 90...
...or even the Rokinon 135/2...
especially for street performers. The svelte 60/2.4 is great for candid portraits, too...
Vignetting added
No simple answers! All shots from New Orleans, low rez images from a tablet.
Chris
A couple of Fuji cameras and assorted X-mount and adapted primes
 CeeDave's gear list:CeeDave's gear list
Fujifilm X-E2 Fujifilm X-H1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +12 more
OP jvdr New Member • Posts: 2
Thanks CeeDave, this overview makes it more easy to compare. I think I will appreciate the 23mm more.
dual12 Senior Member • Posts: 1,276
For me, the 23 and 12mm are not too close. But it depends what you want. There are people shooting street with 50mm and above on a crop sensor.
 dual12's gear list:dual12's gear list
Fujifilm X-E1 Fujifilm X-E3 Fujifilm X-H1 Fujifilm X-T3 Fujifilm GFX 50R +10 more
markusw Senior Member • Posts: 1,705
Tough question, lot of personal preference.
I am not in street photography, but for events and video, I combine the 12 with the 18mm f2 (a „normal wide“). Works fine. Even a 12 and a 16 could be paired, because 12 is really really wide.
On the other hand side, the 35 works already like a very short tele, giving you a different look. For street, it might be handy to snap environmental portraits - with the 12, you are within the scene.
Saying that, the 23 is for me just a compromise for single prime kits. In the meantime, I do not own one anymore.
RivkiLocker
RivkiLocker Senior Member • Posts: 1,566
The 23 and 12 are not too close but personally I love doing street with a wide and a long. My favorite current combo is the 14 and 35f1.4. I like to have the 14 on one body and the 35 on another. That said, if I am going out  with just one lens, I use the 45 on my gfx which is the same focal length as the 23.  So, I’d probably opt for the 23 if you intend to use only that. IF you intend to take two, I think the 12 and 35 make a better complement.
 RivkiLocker's gear list:RivkiLocker's gear list
Leica Q2 Leica M Typ 240 Fujifilm X-H1 Leica SL2-S Fujifilm XF 35mm F1.4 R +6 more
ikaika777
ikaika777 Senior Member • Posts: 2,632
That’s why you need to buy a 23, 35, 50/56 and just have it all. 😊
After all is said and done and your photo is hanging on the wall, no one is going to know or care what camera, lens, or what post processing you used. All they care about is if the image moves them.
 ikaika777's gear list:ikaika777's gear list
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 16mm F1.4 R WR +18 more
stevo23 Forum Pro • Posts: 24,759
jvdr wrote:
Hi Guys,
They're not too close at all. For me, 23mm is a very useful focal length, 35mm isn't very important. This is just how I seem to see things when I'm imaging photos. Others get a lot out of the 35mm focal length.
 stevo23's gear list:stevo23's gear list
Fujifilm X-Pro2 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 27mm F2.8 Fujifilm XF 23mm F1.4 R +3 more
Cagey75
Cagey75 Senior Member • Posts: 1,347
I completely agree with this.  I like to separate focal lengths as much as possible, you have plenty of room to manouvre in between.
I have the 35F2, I don't find it in any way tight, I've used it plenty indoors and took pictures of groups of people.  I really don't get this '35 is too tight' complaint whatsoever.  A 50mm on FF is ideal for street, a 35 on APSC is much the same.  A 23mm will be slightly better for taking in more of the environment, but honestly, unless you only ever shoot down tight alleyways or your idea of 'street' is to capture the whole street itself!?  a 35mm on APSC is plenty wide enough.
You should also note that the 23mm is very soft with tragic discoloration at close focus distance, if this is important to you.  You really need to stop it down to 5.6 for decent sharpness for this purpose, no matter what anyone tells you, just watch the reviews and see the proof for yourself.  It performs very good at F2 from a distance.  The 35 suffers a little from the same but nowhere near as bad.  It often has a bit of a 'glow' and softening when at CFD at F2 but is already very decent by 2.8.  Otherwise it is tack sharp at all apertures for general shooting.
 Cagey75's gear list:Cagey75's gear list
Fujifilm X-H1 Fujifilm XC 35mm F2 Venus Laowa 65mm F2.8 Macro +1 more
ikaika777
I also don’t understand the, “The 35 is too tight” narrative. The 50mm was the master of street photography back in the day.
