Panasonic G7 from NTSC to PAL(restoring factory settings not working)
Started Jun 11, 2019 | Questions
johndo New Member • Posts: 10
After changing the Panasonic G7 from PAL to NTSC mode, I cannot reset the camera to PAL mode again. Does anyone else have the same issue? Pls Help!
Panasonic Lumix DMC-G7
JakeJY Veteran Member • Posts: 5,442
Re: Panasonic G7 from NTSC to PAL(restoring factory settings not working)
This thread about the exact same subject explains it:
https://www.dpreview.com/forums/thread/4334699
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
OP johndo New Member • Posts: 10
Hey JakejY,
I have tried this a lot, with only failed attempts. It does not work in my case.
Is there any other way?
johndo wrote:
Hey JakejY,
There is another EOSHD thread at comments/topic/19932-get-30p60p-on-your-pal-panasonic-cameras/ that mention the following after procedure not working on GX80:
"Make sure the camera is in P mode when you power it on. Then follow the guy's instructions but make sure to press the display button on the selection screen that appears so that "[STRICT]" disappears."
Also did you follow the instruction exactly here (it should be same as second half of video)?
https://www.dpreview.com/forums/post/61859755
JakeJY wrote:
johndo wrote:
Hey JakejY,
Thank you JakejY
Unfortunetly there is no STRICT message anywhere in the process.
Following the procedure, now it shows the exclamation mark on powering off, but doing the rest of the procedure to revert to Pal, does nothing to the framerate, it only does a master reset, asking for time, time zone and language.
Did anyone try to send the camera to Panasonic? Could they reinstall the software?
