Snorkeling trip to Galapagos: Sony FDR-X3000 or Olympus TG5/6?
Started Jun 11, 2019 | Questions
Redivivus Junior Member • Posts: 31
I will go on a trip to Galapagos in about a month. For land needs I will have a Fuji X-T3 and a couple of lenses (TBD). But I am a newbie on all underwater matters: both photography and  snorkeling.   I have a Sony FDR-X3000 with its OEM UW enclosure that I used on a previous snorkeling trip (Red Sea)  and some other "adventures"  to get some snapshot videos, but I am more keen on stills for which IMHO X3000 does not have enough controls.   So my questions is: should I
(a) Keep the Sony: the wide angle and the stabilization will ensure that I capture what I see and the IQ advantages  of the Oly will be wasted on a newbie like me.  Plus is not too hard to get single frames out of the video.
or
(b) Borrow, rent,  or buy the Oly: the IQ and controls are vastly superior and even a  newbie will get much better photos.
Any other insight into the pluses and minuses of these solution, or anything I should know/prepare pre-trip much appreciated.
Many thanks, -- Red
 Redivivus's gear list:Redivivus's gear list
Fujifilm XF 18-55mm F2.8-4 R LM OIS XF 90mm Panasonic ZS100 Fujifilm X-H1 Fujifilm X-T4 +13 more
Olympus TG-5 Olympus TG-6 Sony X3000R
Barmaglot_07 Contributing Member • Posts: 633
Re: Snorkeling trip to Galapagos: Sony FDR-X3000 or Olympus TG5/6?
Why not house your X-T3? SeaFrogs has a fairly affordable option at $655 with dome, plus $120 for a vacuum system.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
kelpdiver Veteran Member • Posts: 5,564
$800 is a lot to spend for a snorkel trip, esp at a locale that is challenging enough for scuba photography.   The iguanas are one good spot, but many of the others...seems like overkill to spend on gear.   Rent maybe, but I'd be pointing to just enjoying the views, not adding a major distraction.   Galapagos is not a great first place to try out something new.
David5833 Senior Member • Posts: 2,849
Redivivus wrote:
... I have a Sony FDR-X3000 with its OEM UW enclosure that I used on a previous snorkeling trip (Red Sea) and some other "adventures" to get some snapshot videos, but I am more keen on stills for which IMHO X3000 does not have enough controls. So my questions is: should I
or
Many thanks, -- Red
I'm not familiar with either of your choices, but IF the IQ difference is significant, it would probably not be wasted. For example, it might be more important to a beginner who isn't necessarily thinking about composition than to a veteran because if the resolution is significantly higher, you might have more latitude to crop and still produce a decent image. If the DR is greater the IQ will be better and if your image is over- or under-exposed, you may be able to correct it with less loss of quality.
OTOH, if the stills you grab from the Sony video are good enough in your opinion, why spend hundreds on another camera?
Using what you have, if you are happy with the results, is always a good idea. However, if UW still photography is something you enjoy and will have more opportunities to do in the future, maybe investing in a housing and lights for your Fuji would be the best solution.  Can you rent a housing for your Fuji?  Can you rent an Olympus?
The Olympus looks like a nice little camera and may just have enough advantages in features and usability compared to your Sony to be worth it to you.  However, it seems like a compromise for UW photography.  You need to do the research to see what the consensus is about its performance for the way you want to use it.
 David5833's gear list:David5833's gear list
Canon G9 X II Olympus OM-D E-M10 II Olympus E-M5 III OM-1 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +8 more
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
If you aren't going to have some dives in before your trip to learn how to use the gear, I would NOT get anything like a dive housing for a big camera with strobes. Keep it small and simple.  You don't want to be trying to learn anything about a camera in a place like that, which as has been said in this thread is a challenging place to dive, and snorkeling is generally more work than diving.
Perhaps this $299 housing for a smart phone?
http://www.krakensports.ca/Smart-Housing.php
Phoenix Arizona Craig
www.cjcphoto.net
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
brousseb
brousseb Regular Member • Posts: 193
I went to Galapagos last summer, I'd suggest using the Sony you have.  The visibility is not great in most places (I dove, maybe snorkelling is better) so you're going to want as wide as you can get so you can get closer to the subject.  You could always film in 4k and grab screen shots while you're reviewing the footage, then you could have video and stills.
 brousseb's gear list:brousseb's gear list
Panasonic ZS100 Panasonic LX10
