how can i check shot on my nx1000? any way that i can modify my camera?
Started Jun 9, 2019 | Discussions
AndrewIsUsingTheNX1000 Forum Member • Posts: 60
so,ive been using nx1000 for years,and im wondering to know how much shot did i take.any ideas,guys?
by the way,nx1000 is not so strong at continuous shooting,it can take only 11 pics for a press....any mods that i can thrust it to shoot more than 11 pics?
 AndrewIsUsingTheNX1000's gear list:AndrewIsUsingTheNX1000's gear list
Samsung NX1000 Canon EOS 700D Sigma 70-300mm F4-5.6 DG Macro +2 more
Samsung NX1000
Re: how can i check shot on my nx1000? any way that i can modify my camera?
Try this
https://www.dpreview.com/forums/post/58126694
Unfortunately, the only way to get deeper buffer is to use lower resolution JPEGs (for example 10MP).
OP AndrewIsUsingTheNX1000 Forum Member • Posts: 60
it doesn't work...i tried but it didn't appear anything..
Did you have adj file on the SD card?
of course i have,but it didnt work...have you ever done it before?
Yes, but my camera is not running the latest firmware.
you did read all the following threads from the "test mode" thread you sent me,right?if the firmware is the problem,any way that i can get the old firmware?i have to completely control my camera,i'll do anything if it's possible.
OK, I did an upgrade to current firmware (1.15) and the combination now does not work, and I have lost previous changes (video recording limit and shooting without a lens).
Will try some more and get back if I have success.
OK, I wasted several hours trying to get it to work with v1.15 but no luck.
The only way I managed to do it is to take v1.13 firmware and modify the string "1.13" to "1.16" to fool the camera to upgrade.
PROCEED AT YOUR OWN RISK! The procedure worked for me, there is no guarantee that it will not kill your camera and pets.
Here are the instructions:
https://github.com/ottokiksmaler/nx500_nx1_modding/tree/master/downgrade_to_nx1000_FW_1.13_hacked_1.13_to_1.16
it's been a day now.so i downloaded the fake file,it's successfully updated on my camera,but the combination didnt get me into the develope modes. i made the .adj file before that
What does your menu - settings 3 - device info say about the version?
Use the provided adj file, if you create it from normal text editor it often has additional newline character, etc, and it throws it off. It has to be exactly 12 bytes long.
I have tested again and it definitely works.
it said my version is 1.16 and it's normal.
got it.it worked,perfectly :))
Glad to help
