Does the 24-70mm f/2.8E have the grind problem?
crazydoglady Regular Member • Posts: 109
Has anyone heard of the 24-70mm f/2.8E developing the same grinding problem that affected the older G version? I want to buy one, but not if it potentially has the same issue!  I had a 24-70mm f2.8G a while ago and had to send it back. However, I miss the zoom range and considering buying the new one.
 crazydoglady's gear list:crazydoglady's gear list
Nikon D5 Fujifilm X-T3 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Fujifilm XF 14mm F2.8 R Nikon AF-S Nikkor 70-200mm F4G ED VR +7 more
Nikon33 Senior Member • Posts: 1,465
Re: Does the 24-70mm f/2.8E have the grind problem?
I have the lens, no problems so far. It is an amazing lens.
 Nikon33's gear list:Nikon33's gear list
Panasonic Lumix DMC-LZ3 Canon EOS 5D Mark II Nikon D700 Nikon D3S Nikon D810 +7 more
RoyC01
RoyC01 Senior Member • Posts: 1,158
NO. Mine is great.
 RoyC01's gear list:RoyC01's gear list
Nikon D5 Nikon D850 Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF Micro-Nikkor 200mm f/4D ED-IF +7 more
gnet158 Senior Member • Posts: 2,821
Too soon to tell.  Give it a year or two.
I got to get out and shoot more.
 gnet158's gear list:gnet158's gear list
Nikon D200 Nikon D7100 Nikon D850
RoyC01
Already have personally given one 3 years.
As always, YMMV depending on use, conditions, and storage.  I'm sure there are many first gen lens that are still doing fine.
RoyC01
So true. But in all of this time I have not read from anyone having that issue. I have read a lot of post asking the same question and they have all been answered the same way by many different owners.
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 15,621
I don't think so
I've got both the g and the e versions, and I bought the new one on vacation because the old one was rapidly developing grind.  (In a couple days it went to the point I wasn't sure I'd be able to change zoom positions soon).    That was Spring of 2016.   The g I had was about 5 years old and had extensive travel use.   The new one has no grind, so far.
When I bought the g, there were already reports out of zoom grind, and the cost to fix it.  I have not heard of a single case of zoom grind on the new version, which in itself seems quite an improvement.  Maybe Nikon has made a critical change somewhere.  It seems the new ones are more reliable.   That said, the new one now has a vr module to fail.
Phoenix Arizona Craig
www.cjcphoto.net
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +37 more
RoyC01
Re: I don't think so
It's a different lens. The focal length is the same but that's it.
OP crazydoglady Regular Member • Posts: 109
Great thank you. Not too bothered if the VR fails (so long as the lens still works!) I don't really need it anyway
Thanks for the all the replies. I bought a used one and it seems great so far
IainD Senior Member • Posts: 2,172
True. Mine is from 2010 and still as good as new.
