Intermittent Motor Noise FL360L Flash
Started Jun 7, 2019 | Questions
dickg1 Regular Member • Posts: 320
With my Panasonic FL360L mounted on my GX7, with a 30mm prime, I get a sort of a  grinding motor noise coming from the flash.  This happens regardless of the camera or flash settings.  It doesn't happen when the flash is off the camera.
It kind of sounds like its internal focusing motor is hunting for a place to be, but never finds it.
Also, what would cause the flash to jump settings, without changing any settings in the camera?
Any ideas?
diskg1
 dickg1's gear list:dickg1's gear list
Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
Panasonic Lumix DMC-GX7
JakeJY Veteran Member • Posts: 5,442
Re: Intermittent Motor Noise FL360L Flash
The only motor in the flash should be the zoom motor. With a prime it should only move to the setting suitable for your 30mm and stay there. I don't have your particular flash, but my Nikon flash also moves the zoom to widest position when you use the diffuser panel.
Did you try with a different lens and see if the same issue happens? And I presume you aren't talking about the capacitor charge up noise typical in most flashes.
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
Peter 1745 Senior Member • Posts: 2,022
I once had an unusual intermittent noise on my Olympus FL600 flash which is very similar to the Panasonic 360L flash.
The noise was coming from the zoom head motor and I found the cause to be an incorrectly seated wide angle diffuser panel. The flash head zooms out to its widest setting when the panel is deployed which is triggered by a sensor in the flash head. The incorrectly seated wide angle flash panel was causing the sensor to be triggered intermittently. The cure was to push the wide angle diffuse back into its proper storage position.
This may not be the cause of your problem but it can't hurt to check.
Peter
'Keep taking the photos'
OP dickg1 Regular Member • Posts: 320
Yup - that was the problem - thanks
dickg1
