Canon SL2/200D for sports/action shooting (surfing)
Started Jun 4, 2019 | Discussions
ohaya
ohaya Contributing Member • Posts: 510
Hi,
I have been doing sports/action shooting primarily surfing, and I have been using Fuji X-T2, but I also have some Canon and third-party Canon EF mount lenses (Tamron 160-600 G2) via a new Fringer "Pro II" adapter.
I had bought a used Xs-i awhile ago, to test the Canon-mount lenses on a native EF/EF-S camera, but now that I have a small set of Canon EF/EF-S mount lenses, I was thinking about getting a more modern Canon DSLR as a kind of backup for use with the Canon-mount lenses, and I am particularly interested in the SL2/200D because of the size.
This year, I am also experimenting using the LCD view finder (and a magnified hood) and a dot sight instead of the EVF, and I was reading that the 200D/SL2 auto-focus was not bad for still photo action shooting?
So, would the 200D/SL2 be suitable for what I describe?
Thanks,
Jim
 ohaya's gear list:ohaya's gear list
Olympus E-M5 II Fujifilm X-T3 Fujifilm X-T30 Sony a7 IV
Canon EOS Rebel SL2 (EOS 200D / Kiss X9) Fujifilm X-T2
R2D2 Forum Pro • Posts: 26,551
Re: Canon SL2/200D for sports/action shooting (surfing)
IMHO you'd be much better off with something like a T7i or 77D (for starters).  And skip the aiming device (use the much better viewfinder PDAF instead).
R2
jvc1 Senior Member • Posts: 2,202
The SL-2 is a great little camera but for sports action, IMO, it's buffer is too small (especially if you shoot RAW & JPEG) and it's burst rate too low.
I keep some of my favorite pictures here,
https://www.flickr.com/photos/129958940@N03/
 jvc1's gear list:jvc1's gear list
Canon EOS Rebel SL2 Canon EOS 90D Canon EF 85mm F1.8 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 60mm f/2.8 Macro USM +10 more
ohaya
OP ohaya Contributing Member • Posts: 510
R2D2,
The reason I am going to try the dot sight, in particular, is that I've been testing  this past year, on a gimbal, and from that testing, I get much less motion blur when I shoot using the dot sight vs. the EVF viewfinder.
That (very slight motion blur) was something I noticed when I was culling the images from shooting in the previous season (with tripod but no gimbal), when using the EVF, even shooting as high as 1/2000, in some cases, and I also noticed that when we got back home with the gimbal and static targets.
I am not quite sure why, but I do know that I have some physical problems with steadiness, so those might be the reason, but I notice that when I use the dot sight, I get much less motion blur.
This year, I am also trying to teach myself to shoot using back-button focus/BBF, so I am thinking that if I can try use that (BBF) together with depth-of-field then maybe the SL2/200D might be "ok enough" even if the auto-focus speed is not the greatest, it might be good enough as a backup/native EF/EFS-mount camera.
We are already carrying enough stuff (we spend 3 months in a different place where I am doing the shooting, so we have to carry a bunch of stuff on the flights to/from), and we are both getting older, so I don't really want to carry a large DSLR.
Thanks,
Jim
shenlonco Regular Member • Posts: 336
ohaya wrote:
R2D2,
Thanks,
Jim
I have the SL2 and I shot fast moving RC cars and it worked out ok, you just got to learn what method works best for you with it for action shots.
Digirame Forum Pro • Posts: 41,857
I would think so (is my guess).  I'm using an older Canon T3i (600D) camera with my Tamron 150-600mm (G1) lens for surfers.  Here's one of them from last autumn.
I don't use a tripod.  At this place I found a place to sit on some large rocks.  Then I rest the camera and lens on my legs, waiting for the next opportunity.  I'll also brace the camera and lens on my legs when I'm taking the pictures, so it's less burdensome with the weight.  At this location, I came there late in the day and had to rush to get back.  I'm looking forward to going there again with the expectation that I will have more time.
ohaya
I like your "water" pics, esp. the #1 one :).
It looks like you are shooting an 80D?  Do you know how that size is compared to an SL2?  I have seen the info and comparisons, and maybe it's the angles, but in the pics on the comparison sites, the 80D definitely looks larger, but it doesn't look that much huger than the SL2?
Thanks on the water pics.
I find the SL-2 much smaller than the 80d. See if this helps. Compare SL-2 & 80d.
The SL-2 feels smaller to me than these pictures make it look. Big difference in weight too.
As I said earlier, I shoot RAW & JPEG and find that the SL-2 buffers bogs down after 3 or 4 shots. of burst shooting. If you're shooting single shots of surfers it'll probably be fine.
God luck with your decision.
ohaya wrote:
R2D2,
Thanks,
Jim
My advice to use the OVF was due to the much higher performance of the OVF's PDAF vs. the LCD's DPAF (Live View) when shooting action.  Stability OTOH is primarily a function of technique.
R2
ohaya
FYI, I just decided to get one of the 80D refurb kits (I am intrigued/curious about the AF performance vs. the Fuji X-T2 and X-T30).  Should be here tomorrow!
Il Mostro Regular Member • Posts: 344
Great choice! 80D is a great all-rounder. I think it will serve you well -- far better than the SL2 for your action shots.  I own both.
 Il Mostro's gear list:Il Mostro's gear list
Fujifilm X-H1 Fujifilm 16-55mm F2.8R LM WR Canon EOS 5D Fujifilm X-E1 Canon EOS 6D +39 more
Great, I'm very happy with my 80d. Canon's refurb deals are great. Have fun with it.
Congrats!  The 80D is a very capable action shooter.
Enjoy!
R2
