Crystals of the Night - M32mm doing Milky Way
Started Jun 2, 2019 | Discussions
zero214
zero214 Regular Member • Posts: 238
12
Finally getting my hand on M32mm, and tried out the Milky on a clear night,
Despire seeing the faint nebula around Antares in the back of my camera, I couldn't make it pop in PP, must be doing something wrong.
The big bloat star in the upper right is Jupiter crossing the core, the nebulas in the core are so beautiful, just like crystals, I was thinking of astromodding my m6, but after seeing how much H-alpha response I can get even with one 50s exposure in the testing PP, I will keep it as it is.
I color some stars to blue to create constrast against the red nebulas in the core.
Enjoy!
44 mins data of 50s exposure, f/2.5, ISO 800, tracked using iOptron SkyTracker Pro, I do believe I can extract more details, just need a point to the right direction.
 zero214's gear list:zero214's gear list
Canon EOS R Canon EOS M6 II Canon EOS Ra Canon EF 400mm f/5.6L USM Canon EF-M 11-22mm f/4-5.6 IS STM +4 more
Canon EF-M 32mm F1.4 Canon EOS M6
Rockin_Robin Regular Member • Posts: 290
Re: Crystals of the Night - M32mm doing Milky Way
I’m always in awe of such beautiful images
 Rockin_Robin's gear list:Rockin_Robin's gear list
Canon EOS M Canon EOS M10 Canon EOS M50 Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 55-200mm f/4.5-6.3 IS STM +3 more
JasonS70 Contributing Member • Posts: 654
Awesome photo
Marco Nero
Marco Nero Veteran Member • Posts: 7,582
Enjoy!
This is quite an interesting image you've captured. That's a LOT of exposure time. (44 minutes)!! It doesn't help us that Jupiter is still on the Galactic Core because it shines so bright. In my own shots, Jupiter seemed to come up bright blue.. but that might have been my WB choice. The same happened when Saturn was in the same spot a few years ago. It was also a bright teal color in some of my shots.
I'm just guessing here but a higher ISO setting is more likely to pick up more of the Hydrogen-alpha 656nm emissions. ISO 800 may be necessary for longer exposures or stacked shots (I'm not sure). I seem to remember reading a couple of years ago that you don't really need special filters or modded sensors to reveal H-a nebulous material. You may also need to take several shots with either different WB options and/or different Kelvin settings. Light pollution may play a part in the blocking of some of the red spectrum. My use of a NiSi Natural Night Filter brought out strong reds near Crux in one of the EF-M 32mm shots I took. However, the WB setting I used may not have been ideal for separating those hues from the rest of the scene.
I don't know if this will help at all because you've managed to draw quite a lot of color out of your shot already..., but here's an article about drawing out the Red Hydrogen-Alpha nebulas from an image without a modified sensor in your camera...  I haven't directly used the information within myself, but it might yield some useful data...
http://www.astropix.com/html/i_astrop/dslr_ha.html
Marco Nero.
 Marco Nero's gear list:Marco Nero's gear list
Canon EOS M6 Canon EOS Ra Canon EOS R6 Canon EF-M 32mm F1.4 Canon RF 85mm F1.2L USM +20 more
MarioV Veteran Member • Posts: 7,089
Enjoy!
That is a beautiful image.  You mentioned making it pop, so I hope you dont mind my attempt.  All I did was use dehaze.  I think this is a good balance.
 MarioV's gear list:MarioV's gear list
Nikon Coolpix P900 Canon G3 X Panasonic ZS100 Nikon D5200 Canon EOS M100 +4 more
zero214
OP zero214 Regular Member • Posts: 238
Enjoy!
Thanks, I'll have a look into it, I just hope for a better weather to blend into the night, I guess maybe ISO 1600 would be ok to bring out the faint nebula.
zero214
Enjoy!
Hi, thanks for your suggestion, but I was looking for a the faint nebule around Antares, I guess with this much data, my PP is the problem.
zero214
The nebula does show aeound the Antares, I guess I have to keep trying new PP methods to bring it out.
