T2I, is it's image quality still acceptable?
Started May 31, 2019 | Discussions
jerelee Regular Member • Posts: 455
I still use my T2I and find it does a very good job. Is there a reason for me to upgrade?
 jerelee's gear list:jerelee's gear list
Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Canon EF 70-300mm f/4-5.6 IS USM Canon EF-M 18-55mm f/3.5-5.6 IS STM Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Canon EF 50mm F1.8 STM +1 more
Canon EOS 550D (EOS Rebel T2i / EOS Kiss X4)
FooHead Contributing Member • Posts: 546
Re: T2I, is it's image quality still acceptable?
jerelee wrote:
I still use my T2I and find it does a very good job. Is there a reason for me to upgde?
Sounds like your T2I is just fine, and there's nothing wrong with that.
I'm still using my 1100D
 FooHead's gear list:FooHead's gear list
Canon EOS 1100D Canon EOS 80D Canon EF 35mm F2.0 Canon EF 100mm f/2.8 Macro USM Canon EF-S 18-135mm F3.5-5.6 IS STM +2 more
Digirame Forum Pro • Posts: 41,858
I'm still using my Canon T2i (550D) camera. The image quality is acceptable with enough available light. One reason to upgrade for me, is to get better photos under dark and rainy conditions. At the same time, I'm using a Canon T7i (800D) camera. With the newer camera the autofocus and exposure seems better. I also like to have the extra pixels when cropping. See my latest photos in the Show Your Snaps thread in which I use both cameras.
STR54 Regular Member • Posts: 297
Mine started having AF issues but those began appearing after being subjected to several high humidity/heat exposure episodes. So that was the only reason I upgraded...to the T3i. Found a good low shutter count used one and it seems adequate as seen below.
Baltimore oriole
Blue Angels in OKC
Watty dp Junior Member • Posts: 49
I upgraded from a t3i to a 77D about six months ago mainly because I wanted some of the newer features like the better focusing, better burst mode, etc but you can read about those in the reviews.
As for as the image quality I can notice a fairly dramatic improvement in the noise at higher ISOs and at least to my eyes I can barely see any noise at ISO 800 even when I compare and ISO 100 and 800 picture side by side. Even at ISO1600 the noise is pretty minor.
At least for my old T3i at ISO 100 or 200 the images seem pretty similar(to me at least) as the 77D except that the 77D has more megapixels but unless you are doing a lot of cropping or printing very large images that is barely noticable.
I bought a refurbished 77D on the Canon Refurbished web site and it came with a 18-55 IS STM kit lens for just little bit more. (The deals on that web site change fairly often and I got a good pre-Christmas sale) That lens is probably two generations ahead of the 18-55 that came with my t3i and it seems to also take sharper pictures but that is less dramatic than the ISO improvements.
I sold my T3i with the older lens so getting the newer STM kit lens may make sense if you are going to sell your T2i since it will sell better with a lens.
One thing that I was not expecting is that I really like the touch screen and I am using it a lot more than I would have thought.
adventurer69
adventurer69 Senior Member • Posts: 1,942
I am still using my T3i
 adventurer69's gear list:adventurer69's gear list
Canon PowerShot A590 IS Canon PowerShot SD880 IS Canon PowerShot SX50 HS Canon EOS M Canon EOS M50 +11 more
007peter
007peter Forum Pro • Posts: 12,933
Canon 18mp is still GR8, not worth upgrading to 24mp Canon
I remember fondly of my Canon T2i, it was my last Canon DSLR.  The IQ is still competitive in 2019, in fact, you don't notice much advantage moving up to the newer 24mp Canon sensor from 18mp.
If IQ is important to you, then I would switch to Sony / Fuji / Nikon with that uses a Sony made 24mp BSi sensor.  Sony Bsi sensor provide a noticeable improvement over Canon 18mp/24mp in Dynamic Range and offer superior high iso3200/6400 performace that plagues the canons sensor.
In either case, I would KEEP the T2i as it doesn't worth much in the used market anyways.
 007peter's gear list:007peter's gear list
Panasonic Lumix DMC-GF6 Panasonic 20mm F1.7 II
Re: Canon 18mp is still GR8, not worth upgrading to 24mp Canon
Peter, you wrote that the superior high ISO3200/6400 performance plagues the Canon sensor. Do those other brand cameras (within the same price range) do better than these at ISO5000 and ISO8000? I'm amazed how spectacular my Canon T7i (800D) camera does while it is dark and raining at high ISO with a kit lens.
Here's one example at ISO5000 while we had rain a short while ago. I took many of these under an umbrella.
Here's one at ISO8000. It was still raining a little bit.
