SeaFrog case and longer focal length focusing question.
Started May 29, 2019 | Discussions
DH007 Regular Member • Posts: 220
Hi Underwater Forum,
Im looking at a Sony FE 85mm lens for mostly above water photography (surfing mainly) and wondering if focus becomes an issue at the longer focal length with the use of the Seafrog cases.
I tried to use Digipac and everything is completely soft it's unusable. I think its mainly because the lens doesn't sit flush with the port but I'm wondering if you get the same issues generally with a dome port or is it a non issue?
Thank you in advance
 DH007's gear list:DH007's gear list
Panasonic Lumix DMC-G7 Panasonic GX850 Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +10 more
Master of the Universe Forum Member • Posts: 56
Re: SeaFrog case and longer focal length focusing question.
Hi DH007,
there is little or no use of 85mm lens which closest focusing distance is 0,8 m. There is a lot of use for 85 mm macro though. You can try with close up lens or two but that's quite like buying a better suspension when your tyres are flat.
Barmaglot_07 Contributing Member • Posts: 633
He's talking about surfing though - I doubt the 80cm minimum focus distance is a big limitation when shooting surfers.
The dimensions of 85mm f/1.8 are pretty close to those of 28-70mm, so it should fit into the same port. A dome is not needed when shooting a long lens, especially topside, plus they are cumbersome and very easy to scratch.
That said, a fixed 85mm focal length may be quite limiting when shooting something as dynamic as surfing - SeaFrogs has a port and zoom gear for 55-210mm lens; that could be a better fit.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
